BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
11-08-2022, 09:55 PM | #15 | |
Drives: 2013 subaru brz turbo
11-08-2022, 10:04 PM | #16 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
11-08-2022, 10:15 PM | #17 | |
Look man the car gets 18 mpg rn combined and all I wanted to know was if a tune to lower fuel injection on normal driving or anything of that sort would net me more mpg. That is all. |
11-08-2022, 10:32 PM | #18 | |
The Dictater
Long answer noooooooooooo. If you can give a link to the post, maybe someone can help. Edit: Ok, I can probably tell you what's wrong. Compression is too low. Valve springs too stiff. Probably more engine internals set for power and not efficiency. Wheels too wide, and you could probably put on touring tires rather than performance tires which I assume it has. Don't know about turbo sizing but smaller is usually more efficient.
Also: "Build Thread" Last edited by Spuds; 11-08-2022 at 10:44 PM. |
The Following 4 Users Say Thank You to Spuds For This Useful Post: |
11-09-2022, 01:16 AM | #19 | |||
has a funny hat
Drives: 2014 BRZ Limited
Here is the hard truth, if gas prices and fuel economy concern you, it’s out of your budget. Unless you have real money in college, you shouldn’t have a modified car. But, if you absolutely have to own this BRZ, your solution is to sell the built engine and turbo kit and replace it with a stock engine. Then, if it has any other aftermarket parts on it that’ll kill fuel efficiency (e.g. park bench wing, heavy wheels, wide tires, body kits, etc.) you need to remove them. No amount of tuning is going to fix the fuel economy without blowing the engine the first time you step on the gas. |
The Following 3 Users Say Thank You to pope For This Useful Post: |
11-09-2022, 11:29 AM | #20 | |
Of course putting a stock engine in it will lose "car scene" street cred and Instagram likes so the car is useless if that is done. Of course it is also hard to be part of the crowd when your Super Car is sitting behind the garage with a tarp over it because you tried to down tune it and blew the engine up but can't afford repairs. But it appears we are all just...
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | pope (11-09-2022), soundman98 (11-09-2022) |
11-09-2022, 12:21 PM | #21 | |
has a funny hat
https://www.reddit.com/r/ft86/commen...turbo_brz_mpg/ |
The Following 4 Users Say Thank You to pope For This Useful Post: |
11-09-2022, 12:24 PM | #22 | |
I have never been there and don't plan to now.
The Following User Says Thank You to Tcoat For This Useful Post: | DarkPira7e (11-10-2022) |
11-09-2022, 08:07 PM | #24 |
Drives: 2013 frs red
If you're concerned with fuel economy, you probably won't be able to afford another motor, which will be needed at some point.
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Jdmjunkie (11-09-2022) |
11-09-2022, 09:11 PM | #25 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (11-09-2022) |
11-09-2022, 09:12 PM | #26 | |
ProCrastinationConsultant
almost like he's trying to find the answers he wants instead the answer he needs...
The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (11-09-2022) |
11-09-2022, 09:52 PM | #27 |
Drives: 2018 Subaru BRZ Limited
Whats the point of having a turbocharged car if you never drive it in boost?
11-09-2022, 09:58 PM | #28 |
Be SuRe To LiKe AnD sUbCrIbe!!!!!!!!!!!!!!!!
The Following 6 Users Say Thank You to soundman98 For This Useful Post: | Apolllo (11-09-2022), DarkPira7e (11-10-2022), Jdmjunkie (11-10-2022), NoHaveMSG (11-10-2022), Spuds (11-10-2022), x808drifter (11-09-2022) |
Tags |
brz, mpg, part, question, turbo |
Similar Threads | ||||
Help figuring out my brake problem | Jfheisenberg | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 05-10-2022 02:07 PM |
Where to purchase 2017 86 Parts | Slammedsteve | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 12-14-2016 11:42 PM |
Need help figuring something out | Jrevans1992 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-30-2016 12:56 PM |
Need help figuring out if I can afford an FR-S. | BrianFRS | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-31-2014 08:55 PM |
website/store to purchase pre-painted body parts | supramkivtt2jz | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-30-2013 09:13 AM |
