Tracking / Autocross / HPDE / Drifting What these cars were built for! |
12-10-2022, 10:49 PM | #15 |
Drives: 2023 BRZ
Is it really more sidewall? It has to be really close. Insignificant.
Director of Rocky Mountain 86CUP
12-11-2022, 01:59 AM | #16 |
A bit more, little over 8%.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | Pat (12-11-2022) |
12-11-2022, 09:22 AM | #17 |
Drives: 2023 BRZ
Whoops, I was thinking 245, not 235.
The Following User Says Thank You to Pat For This Useful Post: | DarkSunrise (12-11-2022) |
12-11-2022, 09:44 AM | #18 | |
FNG
Drives: 2013 Subaru BRZ
The stock differential on our cars is 4.10:1 (4.30:1 on 2017+) and we'll use that as a base. The stock tire is a 215/45-17 which is ultimately how that final drive ratio is calculated. For all intents and purposes, we'll start there. If you use a 245/40-17 you move to a FD ratio of 4.08:1. If you use a 235/45-17 you move to a FD ratio of 3.99:1 If you use a 255/40-17 you move to a FD ratio of 4.03:1 If you use a 225/45-17 you move to a FD ratio of 4.04:1 These differences do seem somewhat minor numerically but they do have a significant impact on both acceleration and top speed achievable per gear. More importantly, while understanding these numbers is very important, it doesn't mean that a lower FD ratio is necessarily bad. It all really depends on so many other factors. In the end, threads like this are largely pointless (just like the whole corner speed thread) because there are so many factors at play that you would have to have the same driver, same car, same track, same conditions and only change a single variable (like tire compound and/or size) to get any real data and that all assumes that the ultimate variable (the driver) is so consistent that none of the other data is affected by the variability of the driver. This is all fun conversation and a great way to pass the time but all these conversations can really do are offer general pointers on how to get faster given the car you have. The ultimate mod here is the driver mod. |
12-11-2022, 11:51 AM | #19 |
I don't think it's useless. There is some merit to these discussions.
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
12-12-2022, 09:51 AM | #20 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
On a totally different train of thought, isn't 225 too narrow for a 9" wheel?
I would have thought 235 or 245 would be the starting point for a wheel of that width since 225 seems to be a better fit for a 7.5~8" wheel. I'd think 225 would be stretched and not fit very well. |
12-12-2022, 11:30 AM | #21 | |
Drives: None
Again, tires work best when the section width matches the wheel width.
The Following User Says Thank You to RedReplicant For This Useful Post: | gt5759 (12-14-2022) |
12-12-2022, 11:56 AM | #22 | |
Drives: 2020 BRZ Sport Tech RS
A 4.1 final drive stays a 4.1 final drive regardless of what wheels and tires you have on the car because it still turns the same number of times vs. the input from the gearset / driveshaft, but yes, all other things being equal, going with a different overall diameter can affect the effective torque to the ground in similar fashion to changing the final drive ratio. It has to be a pretty substantial change in size to match the effect though. If I'm doing the math right, using the rough outside diameter of 25" for a 225/45R17 combo someone else posted, that would mean running about a 235/35R17 (not sure such a thing even exists) to effectively match the change in FD ratio from a 4.1 to a 4.3, so the sidewalls would be about 20mm shorter. Conversely, to effectively match the change the other way (4.3 to 4.1), you'd need to go to a 245/50R17...
12-12-2022, 12:18 PM | #23 | |
Spelling Impaired
That's why I asked. On other cars I've run 225 tires on 8" wheels and the tire casing appeared to be perfectly matched as you state. That's what led me to think 225 on a 9" wheel wouldn't be a good fit and it would lead to the casing being stretched a bit like the OEM 215's on my OEM 7.5" wheels. |
The Following User Says Thank You to Desertnate For This Useful Post: | RedReplicant (12-12-2022) |
12-12-2022, 02:55 PM | #24 | |
FNG
As for the minor differences, I would say they definitely matter. In Solo I ran 2021 and half of 2022 with 255/40-17's on my 2013 BRZ. I also did track days on those tires. Before that I ran 245/40-17's and also in the last half of 2022. What I personally observed is that the car was less "quick" in Solo and I lost about 3 mph in the back straight (GPS adjusted) by running the larger diameter tire. No other changes were made to the car that would have produced those results. I know it's minor and so are the impacts. That doesn't mean that it doesn't really matter. YMMV Last edited by RT-BRZ; 12-12-2022 at 08:11 PM. |
The Following User Says Thank You to RT-BRZ For This Useful Post: | Tatsu333 (12-12-2022) |
12-12-2022, 03:13 PM | #25 | |
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
12-12-2022, 08:31 PM | #26 | |
Drives: 2022 GR86
225/45R17 GT Radial SX2 don't look stretched much on a 17x9 wheel: I think I've seen 245/40 Michelins (PS4S?) that looked more stretched on 17x9 wheels.
Follow the build thread for my GR86!
The Following 4 Users Say Thank You to timurrrr For This Useful Post: |
12-12-2022, 08:41 PM | #27 |
Drives: None
A 225 Hoosier looks like that on a 10, lol
12-13-2022, 08:49 PM | #28 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
Slow is smooth, and smooth is fast
The Following User Says Thank You to Capt Spaulding For This Useful Post: | Pat (12-13-2022) |
Similar Threads | ||||
New Hawk HP+ Compound | RayRay88 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 07-08-2019 10:04 AM |
Compound boost. | Jaden | Forced Induction | 218 | 09-26-2016 09:36 PM |
New Hawk HP + compound | Hyper4mance2k | Tracking / Autocross / HPDE / Drifting | 24 | 11-11-2014 11:05 AM |
help im really dumb i think!!! compound issue.. | nickmerronesucks | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 05-02-2014 03:53 PM |
new R compound from Maxxis | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 02:27 PM |
