GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
03-06-2023, 08:54 AM | #15 | |
Drives: GR86
Love this kind of info and analysis sharing you bring to the community. As a prospective customer, it makes me want to support your product. |
The Following 2 Users Say Thank You to nomtimesthree For This Useful Post: | KillerBMotorsport (03-06-2023), Pat (03-06-2023) |
03-07-2023, 09:19 PM | #16 |
Drives: Ocho-Seis
Is there any chance a similar baffle can be made for the first gens? The FA20 game needs KillerB!
03-08-2023, 08:46 AM | #17 | |
Drives: Mini Cooper S
03-14-2023, 03:10 AM | #18 |
Drives: It has 4 wheels
This somewhat explains why it takes so long for RTV sealant to dislodge and needs hard driving for some of the bits to dislodge. If oil is ending up in the front cover area, hard cornering transitions would likely dislodge excess sealant over time.
03-14-2023, 06:47 AM | #19 | ||
It's everywhere in the engine! Many assume addressing the lower pan section is a fix, but that is just a small percentage of where it's used. On our development engine you can see it oozing out of places on the inside and outside. |
The Following User Says Thank You to KillerBMotorsport For This Useful Post: | DocWalt (03-15-2023) |
03-15-2023, 05:11 AM | #20 |
We've got a couple units available if anyone wants a Beta unit to try out. All it costs you is installing time. Shoot us a PM if you're interested in being a tester
05-04-2023, 09:35 AM | #22 |
Drives: 2023 Neptune
Well, its over a month later. Any track data yet @KillerBMotorsport? I can hardly contain my excitement for this.
05-23-2023, 11:32 PM | #23 |
Drives: '23 GR86, '17 BRZ
Bumpity bump @KillerBMotorsport
06-02-2023, 02:35 AM | #24 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Bumping this up for a new solution @KillerBMotorsport
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
06-26-2023, 04:09 PM | #25 |
Drives: 2022 Subaru BRZ
Hi, just wanted to share some preliminary testing I’ve been doing to set a baseline before installing the prototype baffle. I made a video documenting the testing setup and the results:
The summary is: I can consistently reproduce oil pressure drops on right-hand corners, many of which are significant enough to cause concern for bearing damage. This is with low-grip GT Radial SX2 tires and minimal modifications. I’m running OEM coilovers, OEM ride height, and just have minor alignment changes on the front end from offset strut mounts and camber bolts. Rear end is entirely OEM. I’m also running a Jackson Racing oil cooler and Motul 8100 EFE 5W30 motor oil. The prototype baffle is going on my car today and I’ll be at Thunderhill 5-Mile on July 1 to test the baffle. |
The Following 27 Users Say Thank You to 900BRZ For This Useful Post: | ACT86 (06-26-2023), Arthur-A (06-26-2023), Blighty (06-28-2023), Bonburner (06-29-2023), Compelica (06-28-2023), DarkSunrise (06-27-2023), drift86 (06-28-2023), Espi (06-27-2023), fredzy (06-27-2023), Frost (06-27-2023), gcmak (06-27-2023), Gearhead23 (06-26-2023), G_Ride (06-27-2023), Jdmjunkie (06-26-2023), justinco (06-26-2023), makinen (06-27-2023), MrSkubi (06-27-2023), Mr_Brian (06-26-2023), OldBiker (06-26-2023), Racecomp Engineering (06-27-2023), RacingredGR86 (06-26-2023), raisingAnarchy (06-26-2023), simpleisbest (06-26-2023), Sport-Tech (06-28-2023), vindiesel (06-26-2023), ZDan (06-29-2023), zeroomega (06-26-2023) |
06-26-2023, 05:03 PM | #26 |
Drives: 2023 brz limited 6mt red
This video needs stickied…I know a baffle would be cheaper then this. A remade oil pan and the deeper part centered with oil pick up tube? Or a deeper high capacity oil pan to insure no drop? Even if oil is getting trapped in other parts of the engine extra capacity would negate the pressure drop would it not? Or hell a pick up tube that has a bend center of the current oem oil pan?
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
06-26-2023, 05:41 PM | #27 | |
Drives: '20 Tundra, '84 SpecE30
This is a fantastic video, thank you for taking the time to put it together. Honestly, it's giving me pause on taking delivery of the GR86 I've been waiting for in a few weeks. I was surprised to see such massive pressure drops even at less intense corners, like in your video around the 10:10 mark. It's showing around 0.9g through the right hander, yet that's still enough to lose 50% of oil pressure. |
06-26-2023, 06:36 PM | #28 | |
I have read about some modifications to pickups to remove bends (I believe this was in a forced induction FA20). They argued that the bend was causing cavitation and, thus, starvation. So in general I’m hesitant about bends unless they have significant testing, which seems lacking even in the factory FA24. In theory this pressure drop could be a result of cavitation in the irregularly shaped FA24 pickup rather than lack of oil, but it’s hard to say without more research. At this point, I’m hoping that the prototype baffle works and I keep can tracking this car for years to come. |
The Following User Says Thank You to 900BRZ For This Useful Post: | vindiesel (06-26-2023) |
Similar Threads | ||||
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 05:15 PM |
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 50 | 10-29-2022 07:36 AM |
High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 09:51 AM |
FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. | FRSH86 | Engine, Exhaust, Bolt-Ons | 2 | 04-20-2020 10:49 AM |
Compatibility: Moroso Baffle and Killer Bee Oil sump | Nightflo | Engine, Exhaust, Transmission | 3 | 04-27-2019 09:40 PM |
