Old 03-08-2024, 06:19 PM   #15
Dboe
Drives: 2013 Red FRS
Pretty sure I have this exact same rattle. Behind the driver side dash. Sounds like a clip or screw that hits something on any decent bump. But normal roads it's silent. No luck figuring it out I guess?
Dboe is offline   Reply With Quote
Old 03-08-2024, 09:53 PM   #16
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
I pretty much have the same noise, not very loud, just a little rattle. I’m going to remove the panel below the steering wheel cause thats where mine comes from and going to line the perimeter of it with adhesive felt tape, felt tape is great to eliminate rattles if you can pinpoint them. Problem with today’s cars is wayyyyy to much cheap plastic. I’ve owned and grew up in cars from the 60s/70s that had quieter interiors than just about anything made today. Its a shame when you sit in the luxury cars at the Int’l New Car show and the interior is STILL mostly all generic plastic, but at least our twins are a fraction of their cost.
If your not first your last - Ricky Bobby
HotlavaFRSGT86 is offline   Reply With Quote
Old 03-09-2024, 06:10 PM   #17
WNDSRFR
Drives: FR-S,GTI
Originally Posted by EndlessAzure View Post
Right behind the steering wheel?
Could be the EPS coupler/bushing: https://www.ft86club.com/forums/showthread.php?t=133606
I've had this incessant rattle from the steering column for about a year now. And there's no doubt about it being the EPS steering damper. I have the new part but I'm worried I'll take the thing apart and not be able to get it back together again. I took the steering assembly down following different videos but got to the point of no return and I returned and put it back together because I didn't have enough room to work. If I removed the drivers seat I would have room.
NOPE Drivers seat is attached by some strange reverse torx things that I don't have the tool for. I tried to remove them with something that almost fit but apparently they're torqued to a million pounds.
So, anyway, I'm guessing your problem is with the GDMFing EPS steering damper thing that's guaranteed fail
Drivers side pillar rattle! (With links) Weeber Issues | Warranty | Recalls / TSB 9 01-02-2020 02:15 PM
Rattle from driver's side dash? Prog Issues | Warranty | Recalls / TSB 141 10-03-2019 11:01 PM
Drivers side rattle/vibration near A pillar? brillo Issues | Warranty | Recalls / TSB 10 08-08-2017 12:52 PM
Dash Leak on drivers side! jbsali Issues | Warranty | Recalls / TSB 2 04-01-2015 11:34 PM
Rattle in drivers side headliner-help! meadowz06 Issues | Warranty | Recalls / TSB 5 09-18-2013 10:44 PM
