Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
07-19-2023, 03:56 PM | #15 | |
Drives: 17 Asphalt 86
If ride quality is your goal, yellows or eibach pro kit are probably a safer bet. Sidenote lots of threads buried with lengthy discussions on it. Page two RCE chimes in a one point. https://www.ft86club.com/forums/showthread.php?t=70600 |
07-19-2023, 04:32 PM | #16 |
Drives: 2018 BRZ
I am running camber bolts, but they are not needed if you are not interested in the extra camber. The 20mm drop of the RCE Yellows is well within stock toe adjustment, and will gain you a small amount of camber front and rear, but that shouldn't hurt tire wear in normal driving.
07-19-2023, 04:34 PM | #17 | |
Drives: 2018 Subaru BRZ Limited
Sent from my SM-S908U using Tapatalk |
07-19-2023, 09:14 PM | #18 |
Drives: 2018 BRZ
I'm with double camber bolts and Pedder's offset top hats for over -3 degrees. With just the camber bolts I think I had about -2.2 after lowering and around -1.8 before lowering. You should be perfectly fine with just the lowering springs.
Similar Threads | ||||
Lowering my car | Silver Cervy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 80 | 06-30-2016 06:51 PM |
Lowering, with lip kit? | YamahaR86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 11-17-2015 07:09 PM |
Lowering my frs | mikltov | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-14-2014 01:30 AM |
I'm lowering my car soon.. | USN.Spence | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-18-2014 01:38 AM |
lowering the car | jarviz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 11-02-2012 03:49 PM |
