Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-15-2023, 08:47 AM | #15 |
Drives: 2013 frs base
No. This much oil is left in the pan after draining then removing the Fumoto.
The Following User Says Thank You to blsfrs For This Useful Post: | Teseo (08-15-2023) |
08-15-2023, 11:58 AM | #16 |
Drives: frs
Fucking Christ, thats like 2 quarts. Imagine that amount + oil cooler
08-15-2023, 02:12 PM | #17 | ||
Drives: 2023 BRZ
The Honda S2000 we just sold was the first car where there was a big deal over tightening the filter to a torque spec instead of "yeah, that feels pretty tight". So, on the BRZ, I need to revisit that? Which of course means I need a filter wrench that the torque wrench plugs to. Hey, at least I won't be back on the forum asking "hey, where is the oil filter on this car?"
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
08-15-2023, 02:35 PM | #18 | |
Drives: 22 BRZ limited
08-15-2023, 03:33 PM | #19 |
Maybe a pint. The container is a Hillshire Farms lunchmeat container. I don't remember if it was oven roasted turkey or honey ham. It's not very big. Some folks commented that they cut the threaded end of the valve, so it did not protrude into the pan.
08-15-2023, 08:54 PM | #20 | |
ProCrastinationConsultant
though as with any oil filter, they're always difficult to get off. i highly recommend the motivx filter wrench adapter. so much nicer than the flimsy stamped steel pieces. https://www.amazon.com/dp/B09JRNWYR2...v_ov_lig_dp_it this funnel kit is also on my to-get list. https://www.amazon.com/dp/B09X23RHL9...v_ov_lig_dp_it i got a motivx complete kit for my tacoma(raw filter in an oem housing; kit included filter drain tube, filter housing wrench, and funnel) that includes those 2 things, and it makes the process even less painless than it was before.
08-16-2023, 08:17 AM | #21 | |
Drives: 2023 BRZ
Very well, back to hand-tighten then. Thanks for the links to those tools, both are now bookmarked! So far, I'll pass on the Fumoto valve, I am seeing enough web pages on "my Fumoto valve leaks!" and, even if a tiny % of those sold, it's simple enough to use a wrench on the drain plug.
The Following User Says Thank You to tiger1964 For This Useful Post: | soundman98 (08-16-2023) |
08-16-2023, 08:43 AM | #22 |
I've had 5 vehicles on fumoto valves(2 on the same valve) with no leaks so far. Only thing I do different is using the factory crush washer instead of the fiber one it came with.
The Following User Says Thank You to dragoontwo For This Useful Post: | blsfrs (08-16-2023) |
08-16-2023, 02:33 PM | #23 |
Drives: '22 BRZ
There's plenty of oil left in the pan even with the stock drain, the stamped piece that's welded in to carry the threads is pretty tall.
The Following User Says Thank You to DocWalt For This Useful Post: | blsfrs (08-17-2023) |
08-16-2023, 11:06 PM | #24 |
The Dictater
Drives: '13 Red Scion FRS
After draining with the fumoto valve, the engine still takes about 6 quarts. Every time. For 7 years. With no issues.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | blsfrs (08-17-2023), soundman98 (08-17-2023) |
10-26-2023, 11:53 AM | #25 | |
Drives: 2023 BRZ
10-26-2023, 12:54 PM | #26 |
Drives: 2023 BRZ
OK, done with the 1000 (actually 1226) mile 1st oil change. A few thoughts:
* 29 ft/lb on the drain plug? Uh, someone at the factory might have set it at something much higher, but I got it off. Interestingly, my torque wrench's lowest setting is 26 ft/lb and I wonder if accuracy is less consistent at that end of the range? Anyway, felt right. * They say ensure not to double up the crush washer. Looking at the plug, I was not so sure, just a silver line under the threads that might have been paint scraped off. After a couple of minutes with a paring knife -- yup it came off, that was the crush washer. * My Harbor Freight "race jack" got under there, but could not get the car high enough to set either pair of jack stands in the correct spot. I could get another jack but... don't raise the bridge, lower the river. So, Amazon sent jack stands with a lowest setting of 9.5" (only 2 tons, though). Worked like a charm. * Wow, 0-20 is really low viscosity compared to, say, straight 40 weight. Just pulling the dipstick out, a few droplets went everywhere. Fortunately had a bottle of spray detailer handy. That said, 0-20 is I guess thick enough, it took a long time draining until the last drip-drip-drip ended (20 minutes?) * 5.3 quarts did not do it. More like 5.7 quarts. The suggested screw-in funnel works great, I recommend getting one -- the clear window means you can really know when the bottle is more or less empty.
10-26-2023, 01:35 PM | #27 |
it was likely put on with 29 ft lbs at the factory, but the paint made sure that it wouldn't come off.
Similar Threads | ||||
Need Help Sourcing An Engine | Sojhinn | Issues | Warranty | Recalls / TSB | 2 | 08-04-2017 09:43 PM |
Help Sourcing Wheels and Matching with Louvers | marchocais | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-04-2015 10:40 PM |
Thoughts on sourcing custom turbo kit | raven1231 | Forced Induction | 16 | 10-22-2014 01:34 PM |
Sourcing new TRD parts | Brandon__ | AFRICA | 8 | 01-28-2013 03:28 AM |
Where will you be sourcing parts for your FRS/BRZ? | neveronlinefrs | Southern California | 9 | 03-17-2012 05:50 AM |
