Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-31-2023, 02:07 PM | #15 |
chicken tonight
+1 Straight hole and tap are critical. If the tap is started crooked, game over.
08-31-2023, 03:29 PM | #16 |
Drives: 2015 Subaru Brz Limited
That metal plate betweent the starter and the bolt entry point. I'm guessing that's a ground for the harnesses so without that pressed against the block the car will probably not start or have other issues?
08-31-2023, 03:32 PM | #17 |
Drives: Crapcan
I can't visualize this right now. I will take a look when I get home, or maybe someone else can answer this before hand.
09-01-2023, 08:58 AM | #18 | |
Drives: 2013 frs base
There wasn't enough room for a drill. I used a "T" handle on the drill bit and was able to bore out the hole manually. Aluminum is soft so it wasn't too difficult. Tapped it, screwed in the coil, and was good to go. You don't have to worry too much about getting the hole straight because the existing hole is already straight. |
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (09-01-2023) |
09-01-2023, 01:07 PM | #19 |
Drives: Crapcan
I had a friend strip a cam cap thread on an EJ25 and he got the helicoil off using the existing hole. Was not a fun repair. I can't remember what insert I used to fix it but it was just big enough OD to work. The cam cap bolts on the EJ have a tapered shank so it was super important that it was perpendicular to the head. I have a tap guide block somewhere that I used to fix it.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (09-01-2023) |
Similar Threads | ||||
Starter button | gcranston | Interior Parts (Incl. Lighting) | 4 | 08-17-2022 02:13 PM |
Starter swap? | Wil | Engine, Exhaust, Transmission | 1 | 07-27-2016 07:50 AM |
2013 BRZ replacement starter, correct part help | sftateofmind | Issues | Warranty | Recalls / TSB | 25 | 07-21-2016 10:12 PM |
ONR Starter Kits | u/Josh | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 11-05-2013 11:47 AM |
self-starter | jarviz | Engine, Exhaust, Transmission | 16 | 09-14-2012 11:45 PM |
