Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-01-2012, 03:32 PM | #15 | |
Drives: 12' Jeep Rubicon 08' 997 Targa 4S
I'll probably get it tuned by darin who was at titan. Well screw the sound then if I go turbo, I want best spool up to power ratio, gtx series or efr ftw |
12-01-2012, 03:39 PM | #16 |
Drives: it has 4 wheels and a motor
you'll plenty of time to make your reasearch, then in 1 year you'll get your car and you can start modding.
12-01-2012, 04:24 PM | #17 | |
I Love custom Turbo kits
Drives: Limited BRZ
Maybe a couple WHP.. Maybe... It will Cost you a LOT? Its a myth.... Let's stop it from spreading
The Following User Says Thank You to Sportsguy83 For This Useful Post: | ngabdala (12-01-2012) |
12-01-2012, 06:02 PM | #18 |
NP... I think your kit looks like it's gonna be the shizzle from what I have read so far in the thread.
12-01-2012, 06:08 PM | #19 |
Drives: 2013 Scion FR-S Whiteout 6MT
Correct me if im wrong, but with FI, isnt the UEL a moot point regarding the "boxer sound", wont that be lost at the turbo? This will be my first turbo boxer, so im not speaking from experience, i come from supra knowledge
12-01-2012, 06:13 PM | #20 |
Not necessarily. Have you ever heard a STi or WRX with a turbo back exhaust?
12-01-2012, 11:05 PM | #21 |
Drives: tata nano
12-01-2012, 11:50 PM | #22 | |
Drives: 2013 "AVO Orange" FR-S
I think that one thing that is being lost in the big debate between UEL/EL is that that all is based on data taken from WRX's and STI's, which had a much, much longer path from exhaust port to turbocharger. This made pressure loss and pulses more important in efforts to retain spool response. However, with the UEL setup we are using it differs drastically from those cars in that it's an incredibly short distance from exhaust ports to turbo, and the gains in response/pressure will far outweigh the gains of lengthening the exhaust manifold piping just to make it equal length. |
The Following User Says Thank You to AVOturboworld For This Useful Post: | Sportsguy83 (12-02-2012) |
12-01-2012, 11:59 PM | #23 | |
KCCO From Canada
Drives: Asphalt FRS
Avo does make a good point for it's turbo system though i cant deny that. but say D3 would benefit from EL vs. UEL |
12-02-2012, 12:44 AM | #24 | |
Drives: 2003 Subaru Outback
12-02-2012, 01:22 AM | #25 |
With the time you have to decide on what you want, there will be more experience regarding lower compression engines in this car and how much boost is required to pump out the numbers you want from pump gas. If you have E85 available there are setups already hitting 400+ relatively reliably. Hell in a year you might now even want a BRZ because something else might come out from Nissan or maybe even mazda...I doubt Honda will do anything exciting as far as competition for the twins, they still need the new NSX to launch...just as overhyped as the original, if not more.
12-02-2012, 03:57 AM | #26 | |
KCCO From Canada
Drives: Asphalt FRS
More power from less boost would be better for our FA20 with sky high compression, no? Especially for us guys that can't run E-85. 94 is all i get here good gas but doesn't take timing like e-85 would. |
12-02-2012, 04:13 AM | #27 | |
Drives: '06 AM V8V Coupe
The Following User Says Thank You to serialk11r For This Useful Post: | FreshFRS (12-02-2012) |
12-02-2012, 04:38 AM | #28 | |
KCCO From Canada
Drives: Asphalt FRS
supercharger is my plan as i like throttle response over bigger dyno numbers. A rotrex C38-91 mounted between the A/C and alternator (flip HKS's design) and the stock intake manifold (with A/W integrated somehow) raised up (with custom pieces moulded to lengthen from the top of the inject placement to the bend to keep factory contours) as high as i need to run an intake duct under it routed the same way as Innovates supercharger (with a wider, shorter section under the actual manifold for consistent airflow. it would be only a custom silicon elbow from supercharger to throttle body. tuned at say 9psi (spinning about 65kRPM at redline) would be perfect IMHO :happy0180: |
