Old 12-22-2012, 12:40 AM   #15
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
Originally Posted by Noz View Post
Why is that RSX so fast on the straights?
The RSX belongs to my good friend. It has 242 hp at the wheels with 184 tq. It's quick!
Mark Slide Squad is offline   Reply With Quote
Old 01-28-2013, 01:26 PM   #16
Snoopy_TXR
Snoopy_TXR's Avatar
Drives: 2013 Raven FR-S & 2005 BSP X-Runner
Thank you for your review! This thread really helped answer my questions.
Snoopy_TXR is offline   Reply With Quote
The Following User Says Thank You to Snoopy_TXR For This Useful Post:
Mark Slide Squad (01-28-2013)
Old 04-09-2013, 10:08 PM   #17
Snoopy_TXR
Snoopy_TXR's Avatar
I finally got my wheel alignment done today and did some hard cornering to test the Buddy Club coilovers. All I can say is WOW!! Hats off to Buddy Club! These are the Shizz!! With my set up, the car handles like a gokart. I have the Buddy Club racing specs set to 6 clicks and the ride quality for daily driving is still good. I am running 17x9 RPF1 +35 wrapped in Dunlop Direzzas Z1 Star Spec 245/45/17. The only con I can think of about the Buddy Club Racing Spec is the height adjustment. Right now I am running on the lowest height and it is only about a full inch drop. I would like to run at least a quarter of an inch lower. Here is a crappy picture I took on my phone.
Old 04-10-2013, 12:20 PM   #18
Mark Slide Squad
Looks great! Did you adjust just the spring perch? or the lower mount also? You should be able to get it lower if you adjust the lower mount and in conjunction with the spring perch. If that's still not enough for you, you can remove one of the threaded red lock nuts which will get you about another 1/4". If you lower it more though, it will adjust your toe again. It shouldn't affect your toe THAT much though, it wouldn't be enough to justify a new alignment. Glad you like the coilovers!
Old 04-11-2013, 01:15 PM   #19
Snoopy_TXR
Snoopy_TXR's Avatar
I didn't adjust the spring perch because I didn't want to preload the spring but the lower mounts were set to the lowest. I didn't think about removing the middle thread lock to sit a little lower. I'll give that a shot the next time I do any mods on the suspension. Thanks!!
Old 04-21-2013, 10:58 AM   #20
nemes
Drives: scion frs, corolla, gsxr750
How much did u drop ur car?
nemes is offline   Reply With Quote
Old 04-21-2013, 04:09 PM   #21
YDNA
YDNA's Avatar
Drives: Raven FR-S
so the lowest these go is a one inch drop? the spring rates arent bad for dding is it?
YDNA is offline   Reply With Quote
Old 04-21-2013, 04:16 PM   #22
fatoni
its not really the spring rate that dictates how serviceable the car is for daily driving but the shock damping.
Old 04-21-2013, 08:00 PM   #23
Snoopy_TXR
Snoopy_TXR's Avatar
Correct! In the city I live in, the streets are smoother so I can ride on a stiffer setting but where I work, the streets are crap so I just leave them on a softer setting for a more comfortable ride. On the weekends I turn up the stiffness so I can enjoy the way the car performs with the Buddy Clubs.
Old 04-23-2013, 09:35 PM   #24
Snoopy_TXR
Snoopy_TXR's Avatar
An inch. If you are planning on going lower, I would suggest you do not get the buddy clubs.
Old 04-23-2013, 11:10 PM   #25
Pete156
I like to eat!
Did you buy a special tool to adjust the rears easily?
Pete156 is offline   Reply With Quote
Old 04-23-2013, 11:31 PM   #26
Snoopy_TXR
Snoopy_TXR's Avatar
No extra tools were needed. The kit came with the tools to adjust the height.
Old 04-24-2013, 12:43 AM   #27
qijian
Drives: FRS
good reviews and info in here. I got the RSDs for my civic and height adjustment was always a problem for me when I wanted to go lower... but then again the RSD are more function > form. Might just get these again for the FRS.
qijian is offline   Reply With Quote
Old 04-24-2013, 01:20 PM   #28
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Hey @mark_Slide_Squad, is that really only an inch lower than stock? It looks like a lot more than that
campy is offline   Reply With Quote
Buddy Club Racing Spec Coilovers - SpeedFactory Style - Good Photos and Video. FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 03-25-2016 05:22 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
First set of Buddy Club Racing Spec coilovers! jdmitr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-28-2013 05:59 AM
Buddy Club Racing Spec coilovers, anyone install them yet? Mark Slide Squad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 06-28-2013 02:17 AM
Buddy Club Spec II is coming- seeking a car for test fit AAI motorsports Engine, Exhaust, Transmission 38 01-03-2013 08:30 PM
