08-29-2013, 11:51 PM | #15 |
this is a perfect place and time.
So Turbowski and I will be doing our install video on the Ohlins Road and Track. I know Mike does not like it but suspending that for a moment understand the build goal is a near perfect street car that has little compromise for the track. It needs to be almost OEM on the street or better not raising any red flags to casual drivers or the hard core. But when on track can do 80% of what a track prepped car can achieve without changing much of anything. Impossible right? Thats the goal. so the road and track on paper is one of the better kits for this purpose. Yes its not double or triple adjustable but it doesnt need to be for a street car. So onto the questions, pre load do you really want to play with it? Ride height, they recommend 20mm front 15mm in rear I think it is too much for our area. Would a 15mm 10mm or less hurt that much. How long to let settle before corner balancing and final alignment? Damper settings, typically firmer in front than rear?
The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
08-29-2013, 11:59 PM | #16 |
Drives: FR-S Whiteout
I would assume Ohlins will include instructions on how to set the preload, no?
08-30-2013, 12:03 AM | #17 |
Kuruma Otaku
Do you guys have any thoughts on working/teaching about the concept of 'frequency' into more ordinary suspension discussions?
I understand it is something that you need to sort out for each car, but ballpark figures for average weight models with stock springs could be used as the baseline. (Stock Imprezaru F/R 5kg/5kg Relative Stiffness 60/70 CPM* vs Modded FRZ 4.5kg/6.3kg RS 106/111 CPM) It would introduce the concept of 'relative stiffness' to readers so new-to-suspension people could start to develop a better/more accurate understanding than just quoting F/R spring rates, since it takes spring rate, mass and motion ratio into a single figure. *Cycles Per Minute. Or Hertz could be used.
Because titanium. |
08-30-2013, 12:10 AM | #18 | |
they do but I guess the question is why is adjustable if there's only one way to really do it?
08-30-2013, 12:25 AM | #19 | |
Just curious, does the instruction also tell you to measure the sag of the suspension and to adjust according to that. I suppose you can do that if you are, again, anal about your suspension. [/points to self] |
08-30-2013, 10:26 AM | #20 | ||
I don't recommend playing with preload. Just get it snug...a few mm. It doesn't change things as much as people think unless you really go to town. It has zero effect on spring rate, which is a common misconception. 15mm drop front and 10mm drop rear would be fine. Should settle within a day. Drive it carefully. Damper settings front vs rear...don't think about it in those terms. The front and rear damper do not have the same valving for Ohlins so click 5 on the front is not click 5 on the rear. Same neighborhood maybe. You need to find a setting that is firm enough that the car isn't bouncy but soft enough so that it doesn't crash over bumps. Do your best to separate the front and rear of the car in your head. Quote:
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Dezoris (08-30-2013) |
08-30-2013, 10:27 AM | #21 | |
Soon. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Dimman (08-30-2013) |
08-30-2013, 10:48 AM | #22 | |
Not very much bumpsteer on this chassis up front, little bit in the rear. IMO the 20mm lowering number just plain depends on a lot of things. For springs, yes. For coilovers, much more going on and firmer springs can make certain problems less of a problem. I'm a big fan of front control arm bushings. We have so many in the rear for our car I'm not sure where to begin. The subframe bushings are awesome. I like the camber bushings but they suck to install and adjust as everyone knows. The difference between our car with essentially everything replaced and a stock car is massive. So much more connected. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Calum (08-30-2013) |
08-30-2013, 10:54 AM | #23 |
Drives: Some rust bucket
How do you find the balance of lowering the car's center of gravity (lowering the car) and not destroying the factory suspension geometry? Is one more important than the other? For example, is keeping the factory suspension geometry (stock ride height) better than a lower center of gravity?
What exactly gets ruined when you lower the car too much? Can you provide some examples? Is it the fact that the front struts gain positive camber when you lower it too much? Is there any weirdness with the wheels under compression? For example, do the rear tires toe out/in under compression? Thanks! |
The Following User Says Thank You to ayau For This Useful Post: | RJasonKlein (02-19-2017) |
08-30-2013, 10:55 AM | #24 |
I'm not in the market but just curious. Years ago, when I had Tein RAs on my Miata, I couldn't find anyone local (San Francisco Bay Area) to do rebuilds on them. Are there any shops in CA that rebuilds Teins now? I was very happy with the RAs but found local support to be limited from the race shops.
One reason why I went with Ohlins is because Performance Shock is nearby and they do rebuilds of them (along with Koni, Motons, Penske)... http://performanceshock.com/index.php?main_page=product_info&cPath=1&products_ id=677 Thanks, |
08-30-2013, 10:59 AM | #25 |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I'm looking foreward to understanding about 9 words in this entire thread.
The collaboration will be a formidable one, for sure
Nick K.
NASA ST5/TT5 #130 Southeast Region |
The Following 6 Users Say Thank You to forwallblakmail For This Useful Post: | CSG Mike (08-30-2013), jonbonazza (01-05-2014), nofferman (08-05-2018), racecaresuaceb (04-09-2014), Racecomp Engineering (08-30-2013), ScionOfHorus (03-25-2015) |
08-30-2013, 11:02 AM | #26 | |
But, lets say we have 2 springs of equal and linear spring rates. One spring is compressed an inch the other left static. Wouldn't the compressed spring offer more effective rate then the static one at the next inch of compression? Sorry, not here to argue. You are right, you should just go by whatever Ohlins recommends. Carry on. |
08-30-2013, 11:26 AM | #27 | |
Add another 4 dampers if you don't want to compromise at all. - Andy |
08-30-2013, 11:33 AM | #28 | |
The spring constant for both springs doesn't change, and unless there are unequal forces acting on them, they will both absorb energy (compress) proportionally. Compressing a spring 2 in vs 1 in means you have to exert twice the energy. If you want to compress it 3 in, you have to exert triple the energy. This is, of course, assuming an ideal spring, and most quality springs are pretty close to ideal for all intents and purposes. |
The Following User Says Thank You to CSG Mike For This Useful Post: | solidONE (08-30-2013) |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
