Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-10-2014, 08:24 AM | #15 | |
[ame="http://www.youtube.com/watch?v=bbgjRBT4ltM"]Triplex Suspension Explained - /Inside Koenigsegg - YouTube[/ame] |
04-10-2014, 09:18 AM | #16 | |
Drives: 2013 FR-S Ultramarine
04-10-2014, 09:22 AM | #17 |
04-10-2014, 11:26 AM | #18 |
The koenigsegg setup is completely different as it's an actual part of the suspension. It actuates with compression, extension, roll etc. A bar mounted to the chassis can't even begin to do the same thing, dampers and flexibility don't make it magical.
Nathan |
04-10-2014, 01:46 PM | #19 | |
Junior
Drives: a car
It's all in the physics.
04-10-2014, 02:05 PM | #20 | |
04-10-2014, 04:05 PM | #21 |
It's not that hard to understand why the flexible STi bar work like it does. Compresses during corners but retains independence in vertical movement.
That being said I got a Grimmspeed bar during their GB and I'm happy with it. It's simple, does what it's supposed to do, and won't get in the way of any camber plates. And it makes a handy place to mount my reservoirs to. The bar in the OP honestly looks a little too convoluted and more for show than actual performance with all the sections bolted together. There are a number of camber plates which also wouldn't work with it. |
04-10-2014, 06:28 PM | #22 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Which camber plates are you refering to? Ive never seen a subaru front strut top camber plate that goes outside of the strut top hole so there must be something I don't know about.
And the convoluted design keeps it away from the A/C line. The material thickness they used for this bar also makes it look a bit strange, but its much beefier than something like a Cusco bar that has 1/8" steel strut top mounts. The mounts on this MATSU bar are 1/2" thick excluding the recessed bolt holes. |
04-10-2014, 06:49 PM | #23 |
Well. Ground control for one. It's likely many of the job raising type would have an issue.
04-10-2014, 07:10 PM | #24 |
Drives: FD
Strut bars effectiveness has always been a debate on car forums. BUt the bar does look good, I like that it's all black, price is good too
04-10-2014, 07:51 PM | #25 | |
Suspension is there for a reason so it can absorb those bumps. |
04-10-2014, 10:05 PM | #26 | |
Junior
Drives: a car
04-10-2014, 11:27 PM | #27 |
Drives: FR-S Whiteout
04-11-2014, 12:50 AM | #28 |
Drives: blue sardine
I don't believe there was consensus. There was some support for this design as well.
The Following User Says Thank You to major quicknap For This Useful Post: | finch1750 (04-11-2014) |
Similar Threads | ||||
GrimmSpeed Strut Tower Brace - Review | Gopherboy6956 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 49 | 12-16-2019 12:33 PM |
Strut Bar Review: AEM Strut Bar Thoughts and Experiences | wu_dot_com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-08-2019 04:33 PM |
Grimmspeed hood strut review | whataboutbob | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 03-30-2017 11:30 AM |
Grimm speed hood strut review | BRAWL | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 02-28-2013 08:34 PM |
FT-86 SpeedFactory Strut Tower Brace Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-07-2013 04:31 AM |
