05-31-2014, 04:18 AM | #15 |
Drives: 2012 WRX, 2003 RSX Type S
4AGE with the big port intake 20 valves, cheap, light, 1.6L and high reving if buit right. 10k rpm like the Atlantic formula 1 engine
05-31-2014, 07:05 PM | #16 |
Drives: white frs
06-04-2014, 01:08 PM | #17 |
Drives: 2013 DGM BRZ
"Don't ask me...I just work here"
06-07-2014, 06:46 AM | #18 |
Drives: 2014 Firestorm FR-S
how would the paperwork with the dmv work out since theres more cylinders (2JZ) than the FA20??? i heard its a long process. because getting a 2JZ down to hawaii is fairly cheap in my opinion so it seems like a reasonable choice. its just the paperwork and fabrication needed that i would be worried about.
06-07-2014, 04:52 PM | #19 |
Drives: 2door coupe
Don't quote me on this, but I believe you are supposed to get recon if the motor you install has a different number of cylinders.
06-09-2014, 04:06 AM | #20 |
Drives: 2008 AR Toyota Vitz S [XP90]
Yeah you need Recon if the engine you are swapping in has more or less cylinders than the factory motor. So swapping in an I6 into a car that was equipped with an H4 from the factory requires Recon.
06-09-2014, 04:38 AM | #21 |
What's recon?
06-09-2014, 05:17 AM | #22 |
1. Reconnaissance
2. Reconstruction. In this case I'm assuming the second. Sent from my GT-N5110 using Tapatalk |
06-09-2014, 05:38 AM | #23 |
86 Fanatic
Drives: 2013 firestorm 86
Go bad ass and get a LS6
06-09-2014, 05:46 AM | #24 | |
Is it just something that needs certification?
06-09-2014, 02:15 PM | #25 | |
Drives: 2door coupe
http://www.i-club.com/forums/hawaii-...-192672/page8/ post 118 has the updated info |
The Following User Says Thank You to toogood131 For This Useful Post: | s2d4 (06-09-2014) |
06-11-2014, 06:15 AM | #26 |
Oh that was a good post. Recon is basically a certification saying that the modifications done to your vehicle are legal. Once you get that, you can get your safety check. You cant get Safety if you dont have Recon and the Safety inspector says you need Recon. The post had pretty much all the info you need to know if you need Recon or not and how to pass.
One thing that people dont seem to know about Recon is that it doesnt transfer with the car to new owners. So if you bought a car with Recon, you need to bring it down to the Recon department to get it recertified. The Recon permit wont transfer from the previous owner to you. So if you read an ad saying the car has Recon, it doesnt really mean much. |
Similar Threads | ||||
Engine swap JDM EJ25 STI engine | FRSToyota86 | Engine Swaps | 25 | 11-20-2013 01:56 AM |
Engine Swap | Whiteoutjames | Engine Swaps | 21 | 02-25-2013 09:54 AM |
Engine Swap | hybrid35 | Southern California | 0 | 01-07-2013 01:04 PM |
4-aGE engine swap on FR-S | bacon_cheese_beer | Engine Swaps | 13 | 12-15-2012 03:29 PM |
Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 03:58 AM |
