Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
10-01-2014, 02:00 PM | #15 | |
Drives: 2015 Series.Blue
10-01-2014, 04:53 PM | #16 |
Time Traveller
Every time powder coating wheels is mentioned, inevitably there will be a following post about the annealing that practically never happens. Why? IDK.
10-01-2014, 06:41 PM | #17 |
10-01-2014, 06:46 PM | #18 |
Time Traveller
10-01-2014, 10:26 PM | #19 |
Drives: RX-7 / BRZ
I did some powder work while in tech school (blower and alternator cover.) I still have the gun/equipment the only thing keeping me from playing with it again is the oven's costs. I was thinking about tig welding up an oven and using a couple of the 1800watt infared heat lamps for curing paint/powder to heat it. Thoughts?
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
10-02-2014, 03:45 AM | #20 | ||||
Drives: 99 3000GT VR-4
I am not the expert on heat lamps, but I have seen enough coaters ditch them in favor of an oven. I know that there are powder coating factories that use them in a conveyor style and turn out thousands of parts a day, but they have the resources to perfect their procedures. |
10-02-2014, 09:44 AM | #21 | |
Drives: 14 BSP Edelbrock BRZ
If it did the Jenny McCarthy's of the world would be correct. The powdercoaters I have worked with generally do wheels at 350 for a longer time, but I really think that is to make people feel better. 400 degrees for 20 minutes should not be anywhere close to changing the crystal structure of aluminum alloy wheels. |
The Following User Says Thank You to toast For This Useful Post: | DAEMANO (10-02-2014) |
10-02-2014, 10:44 AM | #22 |
10-02-2014, 02:24 PM | #23 |
I hung the wiper arm with it bent backwards and sprayed the hinge area first, I then grabbed the un-sprayed ends (wearing gloves) of the wiper arm and bent it the normal way and finished spraying the whole thing.
10-02-2014, 08:26 PM | #24 | |||||
Yet statistically that happens all the time... You're not helping your point. Quote:
Yep, just rather people be aware of the risks so they can make better educated decisions. Quote:
True. Much like Rota wheels having a bad reputation that is undeserved. Quote:
Not aware of OEM wheels being powder coated. Much like chrome plating aluminum weakens the metal so the OEMs don't do it. They achieve the look with a chrome plated steel veneer usually (Dodge is well known for this). The wheel that failed was a forged center from a 3 piece wheel. I'm unsure on the exact process it went through for powdercoating, but the wheel failed soon after, and the car was simply on the highway when the wheel came apart. Quote:
Annealing can occur at temps that low, it's the temperature and the time it's at that temp that really matters. Not trying to sidetrack the thread on this... |
10-05-2014, 03:51 PM | #25 | |
My thought on wheels that are weakened by powder coating is that the coater is using too high of an outgas temp. Aluminum wheels are often baked in the oven before coating to outgas them. The temps and time need to be higher than that of the powder, it is done so that the wheels do not outgas when you are actually coating them. I have seen some people using 500 degrees for an hour and I believe that may be where the issue is. I'll post it up on the site if I do the tests. |
10-24-2014, 11:58 PM | #26 |
Just bumping this up to see if anyone else is interested in powder coating.
12-16-2014, 02:29 PM | #27 |
If you would like some clarification on the exact steps needed to prep a part for powder coating, check out this article: Prepping for Powder Coating - Step by Step
Also feel free to ask your powder coating questions. |
05-29-2015, 03:49 PM | #28 |
Learn the correct spraying techniques and how to overcome orange peel and other defects when powder coating.
http://www.powdercoatguide.com/2015/...wder-coat.html |
Similar Threads | ||||
Powder Coating in NC? | ChilOut | Southeast | 6 | 06-30-2014 06:04 PM |
Powder coating on LI | klittl06 | NY / NJ / CT / PA | 7 | 06-09-2014 02:11 PM |
Powder Coating | MATTrocity | Hawaii | 3 | 05-07-2014 03:40 PM |
Powder coating? | Trac Toy | CANADA | 9 | 12-04-2013 07:34 AM |
So Cal powder coating | Plxdjake89 | Southern California | 4 | 09-02-2012 04:30 PM |
