Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Wheels and Tires
Old 06-22-2012, 05:58 PM   #15
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Originally Posted by ttknf View Post
There's a difference between "similar" and "same" when it comes to appearance. This is virtually identical to a FN01R-C, which is already a quality, reasonably-priced wheel, so I'm a bit confused on what you guys are trying to achieve here.
Well for one, you can't get this size/PCD combo with the 5zigen.
2nd, the weight for this 17x9 is very good.
Why bag on this vendor?
uspspro is offline   Reply With Quote
Old 06-28-2012, 10:44 PM   #16
Silp3
Silp3's Avatar
update on 255 wheel fitment?? any rubbing?
Silp3 is offline   Reply With Quote
Old 06-29-2012, 12:12 AM   #17
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Why the hate? If you love the 5Zigen's so much, go buy them, then there'll be no need for you to troll here.
spiller is offline   Reply With Quote
Old 06-29-2012, 04:15 PM   #18
bneale
bneale's Avatar
Drives: Scion FR-S
Originally Posted by Mach V Dan View Post
Forging wheels is done using a very powerful press -- tens of thousands of tons of pressure. Think of a blacksmith hammering a horseshoe -- that's a forging process. It results in a very strong finished product, but is extremely expensive to do.
Flow-form casting involves heating the aluminum to near-melting -- it's like soft butter -- and then pushing it into a mold. It's still more of a casting process than a forging, but the result is stronger than if you simply poured liquid metal into a mold.
Made in asia, by a company that produces wheels for many other aftermarket and OEM private labels.
--Dan
Mach V
FastWRX.com
Just to clarify things here, are these photos of the 17x9 rim on the stock suspension?
I'm just wondering because I'm trying to find a set of 17x9's but everytime I think I find a set, people mention they will rub at full lock.
I'd love to confirm if these 17x9's work with the stock suspension. I'm planning on buying wheels for the STX class in Autocrossing and these will be on my list if they will fit with the stock suspension (I will be upgrading this later and prefer to buy the wheels first).
bneale
bneale is offline   Reply With Quote
Old 07-05-2012, 02:01 PM   #19
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Yes.
If it does, it's so minor I didn't notice. I don't think I've had full suspension compression AND full steering lock, but that'd be hard to achieve...
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 07-22-2012, 09:53 PM   #20
sfwg
Drives: 2007 saturn ion(dd)
Any way to get a picture looking down the side of the car? Do these poke or Sink or are they flush?
2014 FRS
sfwg is offline   Reply With Quote
Old 07-22-2012, 10:28 PM   #21
BRZ88
Drives: DGM BRZ
Yes.
--Dan
Mach V
What size tires on those 17x9?
BRZ88 is offline   Reply With Quote
Old 07-24-2012, 12:34 AM   #22
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
245 or 255? Tires look a little big for a 245 on a 9" wide wheel.
Awesome job on the wheels. 17x9 @ 17.8lbs is great!
Also, do you know the total weight (wheel + tire)?
Edit: Decided to open my eyes and read over thread again... They are 255s and weigh 37.3 lbs
Entropy is offline   Reply With Quote
Old 07-25-2012, 01:06 PM   #23
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
Dan, is this the same as a D-Force wheel? I have 3 sets of the D-Force's for my racecar and I quite like them. They look exactly the same. Not similar.... same. That's not a bad thing, though. I WANT a set of the D-Force's for my FR-S!
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 07-26-2012, 11:41 AM   #24
FRSpdDmn
So, I just talked to Tom at D-Force and he confirmed that these ARE the same wheels. That's great to hear!
Is there any way you could have them made withOUT the second set of holes drilled? I really dislike that look.
Second, what do you think about a group buy?
Thanks!
-Anthony
Old 07-26-2012, 04:38 PM   #25
Mach V Dan
We've been thinking we might do a narrower (and lighter) version of this wheel specifically for the BRZ/FR-S. It would be five-hole, might be slightly less expensive, and would be a pound (or more) lighter. Probably 17x7.5".
--Dan
Mach V
FastWRX.com
The Following 6 Users Say Thank You to Mach V Dan For This Useful Post:
BadCompany235 (01-04-2013), FRSpdDmn (07-27-2012), FRSPirate (07-27-2012), Hawaiian (09-11-2012), shaunsweeney (12-31-2013), spdfreak (06-24-2014)
Old 07-26-2012, 05:34 PM   #26
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
If you did a brz/frs specific would you also offer a wider size for the rear? I would like to have staggered set up but wouldn't want 5 hole fronts with multi lug rear.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
Summerwolf (11-05-2015)
Old 07-26-2012, 05:53 PM   #27
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Hey Dan,
Are these compatible with the stock TPMS sensors?
Thanks!
RiskyTrousers is offline   Reply With Quote
Old 07-27-2012, 01:43 AM   #28
Entropy
Entropy's Avatar
Drives: GT86
--Dan
Mach V
FastWRX.com
17x7.5 +25 would fit nicely... Only 2mm outside clearance difference (inwards) from the 17x9 +42. Would be perfectly flush. It's hard to see people putting such high offset wheels on these twins! I would be all wheels of this size.
Awesome freeway encounter last night staycrushing Southern California 6 06-08-2012 06:18 PM
Awesome FR-S Reveal Video ZetaVI FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-10-2011 12:54 PM
awesome renders of ft86 WITHOUT camouflage akkxn Scion FR-S / Toyota 86 GT86 General Forum 9 10-22-2011 10:41 AM
Hennessey VelociRaptor 500: Supercharged, off-road awesome vh_supra26 Other Vehicles & General Automotive Discussions 14 02-15-2010 11:40 AM
