Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Hawaii
Hawaii Aloha!
Old 06-19-2015, 03:13 PM   #15
LANI86
Drives: 2015 Scion FR-S
Based on the locals, coilovers will NOT get you through the RECON. Too stiff.
LANI86 is offline   Reply With Quote
Old 06-20-2015, 01:47 AM   #16
root
Drives: Raven FR-S
My Hachi passed with ridiculously stiff coilovers. Later found out they were defective from the factory. Anyway, part of the recon is the "bounce" test, which is pretty subjective on the inspectors part. They'll put body weight on part of the car and see if there is "sufficient" suspension movement.
Clear side markers, you can prob get by running them on street, you most likely wont get pulled over just for them, but when you go to Recon, do not have them on. Recon does check for DOT lenses all around. Safety check is also supposed to check, but it may get by some places. Recon no longer limits wheel sizes, but tread cannot extend out beyond body and no rubbing.
So any "crazy" suspension can pass as long as you have the paperwork proving its at OEM alignment specs, and there is a "reasonable" amount of suspension movement. Oh, I think there might have been things about bottom of suspension components extending too low.
root is offline   Reply With Quote
Old 06-20-2015, 02:49 PM   #17
keonigt
Drives: 2022 BRZ
Thanks man!
When did you happen do get your recon? My friends said that the driver is the one to do the bounce test not the inspector.
keonigt is offline   Reply With Quote
Old 06-28-2015, 03:03 PM   #18
LANI86
I know clear corners are not acceptable, but has anyone here have a stock FR-S with just the JDM clear corners and passed the regular inspection? I don't think you need RECON for it so it's just the matter of having it approved or not right?
Old 06-28-2015, 06:02 PM   #19
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I believe would be the safety check inspection and not RECON.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 06-28-2015, 06:12 PM   #20
LANI86
Do you know if they will pass the safety inspection or no?
Old 06-29-2015, 02:11 AM   #21
REAV3R
Former Boost Junkie
REAV3R's Avatar
Drives: Ultramarine FR-S
I have clear markers on mine; passed with no issues.
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." ~ J.Clarkson
REAV3R is offline   Reply With Quote
Old 06-29-2015, 11:29 AM   #22
LANI86
I see. That is of course the safety inspection correct? and I don't need to go through RECON for it right, but obviously it probably won't pass with them on...
Old 06-29-2015, 12:39 PM   #23
86geek
86geek's Avatar
No RECON for clear side markers. As stated it will pass safety inspection.
Old 07-13-2015, 01:06 AM   #24
LANI86
Got another question. The 1.0 series yellow TRD FR-S runs the TRD lowering springs on the car w/ stock struts. If I get these installed by the dealer does anybody know if would still require RECON?? Some of the base FR-S here in socal come factory equipped with the TRD lowering springs, wheels, intake, and some other goodies. Can't seem to solve this question myself and would appreciate it if someone can provide an advice. Thx.
Old 07-13-2015, 02:01 PM   #25
Sunrise161
Drives: 2015 FR-S RS 1.0
Recon for RS 1.0
Lani,
My RS1.0 needed a recon, the dealer got it done before I took delivery. It listed the lowering springs as well as the cat-back exhaust.
Sunrise161 is offline   Reply With Quote
Old 07-13-2015, 04:44 PM   #26
LANI86
Originally Posted by Sunrise161 View Post
Lani,
Are you series?!?!
So what did they do? Just an alignment or added camber bolts???
This RECON thing is absolutely ridiculous.
Old 07-14-2015, 03:35 AM   #27
Sunrise161
TRD RS1.0 Recon
Are you series?!?!
I don't know if an alignment was done after the spring install, if it was necessary I'm pretty sure the dealership would have done it. However, I'm pretty sure camber bolts weren't installed.
People ask me all the time why I have a recon sticker on a brand new car. When I tell them that it came that way from the dealership, it always blows their minds.
Old 07-19-2015, 04:03 PM   #28
LANI86
If I do a 10 series/ Monogram headlight conversion (yes, it has DOT stamp as these are OEM), will that require Recon or prevent me from passing the safety inspection?
RECON permit in HAWAII LANI86 Issues | Warranty | Recalls / TSB 6 06-22-2015 09:23 AM
Alcohol Fuel Producer's Permit Luckrider Other Vehicles & General Automotive Discussions 3 01-12-2014 11:36 PM
My carry permit got me out of a ticket! MonkeyBoy Off-Topic Lounge [WARNING: NO POLITICS] 4 12-28-2013 05:51 PM
Studying for Learner's Permit driver's knowledge test PACMAN Other Vehicles & General Automotive Discussions 2 01-02-2012 11:17 PM
