Old 07-16-2014, 06:41 PM   #15
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
*bump* anyone have the info? Thank you!
OnionTou is offline   Reply With Quote
Old 07-21-2014, 12:38 PM   #16
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
I dropped mine also when installing. I was lucky enough to loosen a few bolts for the underbody plastic and it was sitting right there. Give it a shot you may get lucky.
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
Old 09-02-2014, 11:43 PM   #17
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Thanks for this, converting to Evans Waterless Coolant.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 02-08-2015, 12:12 PM   #18
Iddoit2er
Drives: S
Is it normal that my coolant reservoir is empty at less than 30K miles? The filler neck is also dry.
Iddoit2er is offline   Reply With Quote
Old 02-08-2015, 05:31 PM   #19
nunonuna
nunonuna's Avatar
It seems factory didn't make sure to bleed all air out of the cooling system. I had same thing happened, but after I filled more in, coolant level is steady.
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
IBill4You (05-04-2015)
Old 05-14-2015, 02:51 PM   #20
1Cor10:23
1Cor10:23's Avatar
@GrimmSpeed thanks for this post! When you say that coolant should be up to filler neck in radiator...what does that look like? As in, you should see coolant up to ~1 inch or so below the radiator cap?
Old 05-14-2015, 03:53 PM   #21
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
It takes few minutes if you remove water pump hose (driver side).....Warn! you cannot remove all coolant from engine and climate unit. At least you will remove 5/5.5 Lts.
Trap63 is offline   Reply With Quote
Old 06-12-2015, 01:55 AM   #22
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Thanks! Didnt see this, i was scratching my head here googling. My fluid is yellowish and watery. The bottom of mine was so dirty i could barely notice the little door, so i used this to get as much fluid as i could:
Gets like 80%??? My guess out. It was plugged in through radiator and reservoir, also had a mini hand pump that u push and it sucks out fluid.
Thanks for the write up.
Packofcrows is offline   Reply With Quote
Old 06-12-2015, 10:37 AM   #23
stevesnj
stevesnj's Avatar
I went to a machine shop to get a head milled and the machinist said that after 30+ years the number 1 reason for head failure is improper coolant (non OEM) and not changing it every 2 years or once a year. He said failure to use proper coolant is the most common cause followed by neglect. He also said the coolant breaks down and looses it's molecular properties to protect the metals internally within 2 years. So no matter what I will be changing with the Blue coolant every 18 months which seems like a good length. This is going to be my DD so I gotta keep it in tip top shape!
I also discovered that the blue stuff is pre diluted to 50/50 mix. Most likely it has distilled water in the coolant. If you need to add to a low cooling system level and only have water, use only Distilled water. House water is a bad idea. Distilled water is like $.80 gallon.
Capacity from the service manual just for reference and requirements for non OEM coolant. Organic coolant anyone? :P
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
15limited (12-20-2015)
Old 08-10-2015, 04:35 AM   #24
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hello to all!
Just a quick question about the coolant.
Here in Italy seem is impossible to find the Toyota/Subaru Blu stuff 50/50 so i searched other products.
Motul advice is this:
https://www.motul.com/it/en/products...inugel-optimal
Go for it?
Thanks!
Jackal84 is offline   Reply With Quote
The Following User Says Thank You to Jackal84 For This Useful Post:
mashal (08-11-2015)
Old 08-11-2015, 12:05 AM   #25
mashal
DADA
mashal's Avatar
Drives: 2013
I use motul, 60/40 mix
mashal is offline   Reply With Quote
Old 08-17-2015, 05:42 AM   #26
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hello!
Did you drain all the coolant before put the motul?
Thanks!
Old 08-19-2015, 01:05 AM   #27
mashal
DADA
mashal's Avatar
Drives: 2013
Originally Posted by Jackal84 View Post
Hello!
Thanks!
Yes sir
Sent from my A0001 using Tapatalk
Old 09-28-2015, 07:54 PM   #28
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Toyota Blue, Subaru blue, Nissan Blue, Infiniti Blue, and Honda blue coolant are all the same - manufactured by the same company with the only difference in branding labels.
KalbiCool88 is offline   Reply With Quote
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Changing Premium to Limited? zygrene BRZ First-Gen (2012+) -- General Topics 32 10-09-2012 11:58 AM
Checking out your own car Bu-Tang Scion FR-S / Toyota 86 GT86 General Forum 18 06-11-2012 10:41 PM
Mixed day today checking out my DGM Phaedrus29 BRZ First-Gen (2012+) -- General Topics 61 06-03-2012 11:30 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
