JonMotoring
Old 06-12-2015, 07:28 PM   #29163
jeffsides
AZ FRS 86
jeffsides's Avatar
Originally Posted by Campo View Post
Piggly's to North Phoenix to Prescott to Jerome and back. 284 miles just over 5 hours.
https://goo.gl/maps/muxba
Piggly's to North Phoenix to Wickenburg to Prescott to Jerome and back. 311 miles almost 6 hours
https://goo.gl/maps/x1JBp
I can't see the link. I'll leave it up to you guys which route. Thanks 👍🏼😄
Sent from ARIZONA86 HQ
@AZFRS86
Old 06-13-2015, 01:23 AM   #29164
NinjaRxMan
NinjaRxMan's Avatar
Originally Posted by GTO5005 View Post
What is the route we are going to take for the cruise, I am on E85 so I was looking to see if I can go.
Sorry guys, my only plan is to go through Prescott Valley over to Jerome, have lunch and Jerome and then make it back to the valley. If one of you would like to map it out and post it up that would be awesome I'm just busy at work. Please help!
https://goo.gl/maps/au362
This is the most straight forward one I can think of.
Start in Tempe, then meet north valley folks near 101/I10, then Prescott to Jerome and back.
For E85 users, this will be too far to go on one tank because AFAIK there is still no E85 up north.
https://goo.gl/maps/mEiLt
and this one adds The Rollercoaster between Yarnell and Prescott. One of my favorite motorcycle rides.
I forgot you're starting at Piggleys...
lemme fix the links
I can't see the link. I'll leave it up to you guys which route. Thanks ������
Hey guys,
Since you guys are heading Northbound at 8:30am from Piggly's, @GTO5005 and I thought we could all meet up in the Albertsons parking lot at I-17 and Carefree Hwy (3130 W Carefree Hwy Phx, AZ 85086) for the northside peeps...Maybe around 9:15am. it takes about 45min to get there from Pigglys. At this location we can decide if we want to take the Wickenburg route too. What do you guys think?
The Following User Says Thank You to NinjaRxMan For This Useful Post:
jeffsides (06-13-2015)
Old 06-13-2015, 03:27 AM   #29165
GTO5005
Drives: White Scion FR-S
I took the map and marked the most northern E85 station, along with Albertson's parking lot that ninjarxman was refering to. The E85 station is pretty tight so I wouldn't swing the whole group up that way, just those who need it. There is a gas station in the Albertson's plaza parking lot for those wanting to top off their tanks before heading out.
Phantom ESC 1.5 Dump Conversion, Borla Headers, TRD Exhaust, OFT E85 Tune
GTO5005 is offline   Reply With Quote
The Following 2 Users Say Thank You to GTO5005 For This Useful Post:
jeffsides (06-13-2015), NinjaRxMan (06-13-2015)
Old 06-13-2015, 03:35 PM   #29166
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
What weight oil do you guy use for the summer heat? I'm about to change mine and I can't decide of I want to stick with the 0w20 or go a little heavier (to either a 5w20 or 5w30).
I've got after-market headers on, and through they are ceramic coated, I've lost the stock heat shielding. So I know it's getting extra hot under there in this 100 degree weather.
Jar is offline   Reply With Quote
Old 06-14-2015, 06:39 PM   #29167
jeffsides
AZ FRS 86
jeffsides's Avatar
Size:  323.5 KBName:  ImageUploadedByTapatalk1434321565.377239.jpg
Size:  271.3 KBName:  ImageUploadedByTapatalk1434321571.427873.jpg
Size:  159.1 KBName:  ImageUploadedByTapatalk1434321585.932301.jpg
Size:  312.0 KBName:  ImageUploadedByTapatalk1434321594.617279.jpg
Size:  392.8 KBName:  ImageUploadedByTapatalk1434321605.950025.jpg
@AZFRS86
The Following 2 Users Say Thank You to jeffsides For This Useful Post:
Gusha0426 (06-15-2015), NinjaRxMan (06-16-2015)
Old 06-14-2015, 09:13 PM   #29168
Campo
Campo's Avatar
Drives:
Most of our collective community track testing has proven the stock fill and weight to still be best.
But you could ask five different people and get 10 different answers about oil.
Tapatalk - because smoke signals would be too easy.
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
The Following User Says Thank You to Campo For This Useful Post:
Jar (06-16-2015)
Old 06-15-2015, 02:25 AM   #29169
Wyattkb
Drives: 2014 Whiteout FRS
I have been running Motul 300v 5w30 with great success. Last summer I hit the track and saw oil temps hitting 280F+ Ran 8000 miles on that fill after. Sent it in for a UOA and it came back fine.
Since then I have installed an oil cooler and continue to run the 5w30. The temps rarely exceed 200F in traffic/freeway driving in the summer 100F+ weather. On track I was able to keep temps down around a safe level so the car would not pull timing, unfortunately my OFT corrupted the logs so I don't have any hard data from the track.
I send in every oil change for a UOA and have been able to get 10k miles out of my last change (not recommended, I just wanted to see how long I could make it last since each fill is $100). I have only ran Motul 300v 5w-30 after the stock fill. All data shows good results. So I personally recommend it if you can afford it.
Wyattkb is offline   Reply With Quote
The Following User Says Thank You to Wyattkb For This Useful Post:
Jar (06-16-2015)
Old 06-15-2015, 12:25 PM   #29170
Juggles
Drives: 2013 FRS
Track tests on diff weights came back recently... I'll try and find the data sheet post here if I get some free time today.
Based on 7 laps on track, the "best" was 5w30. It held the needed psi once up to max heat.
If forced induction, w40 looked to work better. Personally I use the european blend of mobil 1 0w40. Car starts up nicely, and once up to heat still fairs well.
Best oil is always the oil you change
However if you are not tracking, 0w20 should be fine. 5w30 might fair well here in our hot summers, especially if you like to push the gas at times.
A zen master once told me "Do the opposite of everything I say", so I didn't.
Juggles is offline   Reply With Quote
The Following User Says Thank You to Juggles For This Useful Post:
Jar (06-16-2015)
Old 06-15-2015, 12:26 PM   #29171
Juggles
Drives: 2013 FRS
Anyone here running a mishimoto oil cooler? My new subaru oil filter wont fit on...im sort of boggled... its the same part # of the one that is currently on there..... /confused at such a simple item.
jeffsides (06-15-2015)
Old 06-15-2015, 09:36 PM   #29172
jeffsides
AZ FRS 86
jeffsides's Avatar
Got all my racecar parts on order. 😊😎👍🏻
@AZFRS86
nelsmar (06-16-2015)
Old 06-15-2015, 11:32 PM   #29173
beastinator
beastinator's Avatar
Drives: 2014 WRB BRZ
[ame="https://www.youtube.com/watch?v=ngaeb1jARAY"]Need For Speed Gameplay E3 2015 Trailer - YouTube[/ame]
Need for Speed E3 trailer.
beastinator is offline   Reply With Quote
The Following 2 Users Say Thank You to beastinator For This Useful Post:
Campo (06-16-2015), jeffsides (06-15-2015)
Old 06-16-2015, 11:10 AM   #29174
Campo
Campo's Avatar
Drives:
Tease.... What'd you get?!?
I bought @Bonks86 5AD 19s and getting new rubber this week. Now I can dedicate the Enkies to the track and get them dedicated tires.
~Raoul Duke
jeffsides (06-17-2015)
Old 06-17-2015, 03:01 AM   #29175
jeffsides
AZ FRS 86
jeffsides's Avatar
Speed By Design turbo with all the goodies, flex fuel set up and new wheels/tires. I'll be having a tech day for my car for once! 😄
@AZFRS86
Campo (06-17-2015), NinjaRxMan (06-17-2015)
Old 06-17-2015, 11:58 AM   #29176
jeffsides
AZ FRS 86
jeffsides's Avatar
@AZFRS86
