Old 06-23-2022, 02:51 AM   #281
gpvecchi
gpvecchi's Avatar
Yes, and the catbacks is separated from the front pipe by a joint that allows a little movement.
gpvecchi is offline   Reply With Quote
Old 06-23-2022, 12:52 PM   #282
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
How big of a hassle are the engine mounts to swap? I get a little contact between the OP and the subframe as well (only when accelerating hard and turning left, oddly). It'd be nice to eliminate that if possible, before I crack something.
Cephas is offline   Reply With Quote
Old 06-24-2022, 02:16 AM   #283
gpvecchi
gpvecchi's Avatar
Quite easy, you just need to jack up the car, support the engine and replace them one by one.
The Following User Says Thank You to gpvecchi For This Useful Post:
Cephas (06-29-2022)
Old 10-10-2022, 06:36 PM   #284
alexmak
Drives: 2014 Scion FR-S
I was trying to find the exhaust hanger at local Subaru dealerships in the US and I found this part # 44066AJ000. It has a very similar design, I wonder if it would have a similar effect. Might be an alternative to ordering parts from Japan or Europe.
alexmak is offline   Reply With Quote
The Following User Says Thank You to alexmak For This Useful Post:
Mil_Gates (02-17-2023)
Old 05-05-2024, 03:54 PM   #285
biggie
Drives: gt86
Originally Posted by worldwidewait View Post
I noticed that the front pipe is bolted to the chassis unlike the rear muffler. Has anyone retrofitted a rubber hanger here as well?
Did anyone tried to use some rubber washer between the L-bracket and the mouting point? I'm thinking, maybe, this will transmit less vibration to the chassis.
biggie is offline   Reply With Quote
Ecutek discovery solidsnake11 Software Tuning 7 08-25-2020 07:38 AM
Submitting For EDC Discovery Project quiksiv Off-Topic Lounge [WARNING: NO POLITICS] 16 04-26-2016 10:58 AM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 03:30 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 06:58 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) -- General Topics 13 07-23-2011 08:22 PM
