Doborder, orthojoe
Old 08-22-2021, 03:21 PM   #295
daniloneil8
Drives: FRS
Spec is
Toyota MT Gear Oil Spce.II GL-3
75W-90
Redline MT-90 vs. MTL
MTL is a low 75W, almost a 70W, at very low temperatures and a high 80W, nearly an 85W, at elevated temperatures, providing adequate viscosity to prevent wear and deaden gear noise.
MT-90 is a thicker 75W90 version of MTL. ... MT-90 is a 75W90 GL-4 and also satisfies motor oil viscosities SAE 10W/15W/40.
So, should I go with 70W85 or 75W90 ?
Easier cold shifting with the lighter MTL?
daniloneil8 is offline   Reply With Quote
Old 05-13-2023, 02:34 AM   #296
r4mr4m3024
Drives: gt86
I can't find the original gaskets. I found these replacement gaskets for the transmission and differential. Is this correct?
A ABSOPRO 12 pieces car oil drain screws seal 12157-10010 for Toyota Corolla https://amzn.eu/d/duyZD2A
r4mr4m3024 is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) -- General Topics 51 05-04-2012 07:54 PM
