07-16-2015, 02:01 PM | #295 |
Maximum toe out will be with the LCA level, any movement in either direction will cause toe in. You'd have to see where the LCA was at the height you had it aligned at.
The toe link is shorter than the LCA, and is in front of the rear axle.
The Following User Says Thank You to wparsons For This Useful Post: | fika84 (07-16-2015) |
07-16-2015, 02:01 PM | #296 | |
Frosty Carrot
Drives: The Atomic Carrot
Link to MX-5 Forum Our geometry will have a toe curve, but if you design suspension appropriately, the curve can flatten across a significant range (as with the Miata). I suspect that our suspension was designed similarly. Edit: Found the toe curve on an S2000. It's got a spread of 5/16" throughout the 5-1/2" of travel.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club Last edited by Shankenstein; 07-16-2015 at 04:27 PM. |
The Following User Says Thank You to Shankenstein For This Useful Post: | fika84 (07-16-2015) |
07-19-2015, 07:08 AM | #297 |
i'm sorry, what?
Drives: Canada
soOoooo
experiment time car currently has toe out in the rear, OEM everything I put a plank on two jackstands at around center height of the wheel and measured the distance between the tire and plank (back and front of tire) with no spare in the car and an empty tank then I loaded my trunk with 100 lb of weight and asked my dad (~220lb) to stand in it as well. under compression the car goes into negative camber, so the distances from the plank increase... and the front of the tire increased by 1.2~3mm more than the back, meaning the front of the tire tucked in more than the back, which means toe-in under compression given my initial settings. I hope
The Following User Says Thank You to 7thgear For This Useful Post: | fika84 (07-20-2015) |
07-30-2015, 12:21 PM | #298 |
i'm sorry, what?
Drives: Canada
do we know the length of our scrub radius in the front? (distance between OEM wheel centerline and the strut inclination where they meet at the ground?
07-30-2015, 01:56 PM | #299 |
Not that I know of.. These guys have the data, but they charge for it... http://www.morsemeasurements.com/
07-30-2015, 02:15 PM | #300 |
Drives: 2015 FRS
Subscribed! I will read through later. I did suspension design in FSAE for 4 years. Psyched for this one and hope I can contribute.
The Following 2 Users Say Thank You to SkiRideDrive For This Useful Post: | fika84 (08-03-2015), Shankenstein (07-30-2015) |
09-23-2015, 06:13 PM | #301 |
Drives: S60R/Corvette
Not sure if I'm missing something but the OP has the rear motion ratio around .85 and links another thread that has it around .75.
From a sketch I built off the factory 3D model I have the MR changing from .768 at 2" of bump to .758 at 2" of droop so its .763 at at OEM ride height.
Ryan M.
Strange Engineering Director of Suspension Development |
The Following User Says Thank You to RBbugBITme For This Useful Post: | Shankenstein (09-23-2015) |
09-23-2015, 09:38 PM | #302 | |
Frosty Carrot
If you see any other areas we can improve, don't hesitate to speak up.
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
01-18-2016, 04:09 PM | #303 |
Junior
Drives: a car
Uh this hasent been updated in quite some time, but quick question. struts; are they simple or complex harmonic motion?
01-18-2016, 04:33 PM | #304 |
College level analysis = simple
Real world analysis = complex
Ryan M.
The Following User Says Thank You to RBbugBITme For This Useful Post: | cdrazic93 (01-26-2017) |
01-18-2016, 04:37 PM | #305 |
Junior
Drives: a car
I had a feeling itd be complex, currently my SHM and motion equations are of only the first and second order normal diff eq lol
04-22-2016, 10:30 AM | #306 |
Drives: 2014 BRZ Sport-tech
Hey guys, I have slight rubbing between my rear tires and fender on the outside. I'm wondering if installing whiteline rear upper control arm bushing will be enough to get the tire tucked in. I'm currently running 17x9 +35 with 255-40-17 RS3 on coilovers and SPC rear LCA. Anyone know how much maxing out the UCA bushing will tuck in the top of the tire?
06-24-2016, 11:58 AM | #307 |
Frosty Carrot
Ran across an interesting blog post from a Miata dude who talks about developing a semi-active suspension system.
LINK to Article Basic idea is to use valves to open bleed paths (compression and rebound, with check valves to keep each path independent). "Skyhook" theory is simple enough, since you support/stiffen the vehicle to resist roll and pitch. I'm betting that we could develop a simple feed-forward system that uses gyroscope data with some filtering/dead zones to keep things robustly stable. A potentiometer could let you dial in the aggressiveness of valve opening. Here's another thread about similar topics: LINK to Miata.net Tein's EFDC Active Pro does modify damping... but this type of system is pretty slow and uses motors on the adjustment knob. Ohlins has a similar system: LINK to SportRider
10-17-2016, 01:10 PM | #308 |
Drives: BRZ WRB
I searched for "rear lateral link" in this thread and didn't find any results.
Do we know how this link affects rear toe and caster under suspension travel? The link in question is the left green arrow |
Similar Threads | ||||
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 350 | 02-02-2013 01:52 PM |
Need opinions on two new items we're developing! | yospeed | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 12-03-2012 02:13 AM |
Chances of Someone Developing 5x114.3 HUBS (not spacers)? | Entropy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-04-2012 03:35 PM |
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) -- General Topics | 68 | 02-14-2012 07:16 AM |
