Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-14-2020, 03:57 PM | #323 | |
https://motioncontrolsuspension.com/buyers-guide/ https://motioncontrolsuspension.com/...tions-pricing/ Along with the four options there they also have single and double non-remotes set up for OE springs to be compatible with SCCA Street class autocross. Prices don't include springs or top hats iirc. I don't know if they do direct sales as I've heard they'll typically point you to a vendor to buy through. |
04-14-2020, 07:29 PM | #324 |
Drives: FR-S Whiteout
You got a point there. If there is not one default setting, then I guess he's offering to share how his is set up for him?
Intent > Content
cowardice is the mother of cruelty. |
04-15-2020, 06:48 AM | #325 | |
Only happy when it rains.
Drives: series.blue
maybe take a look at the mod you are trying to get to notice you and realize he hasn't been on the forum since September of 2018? |
The Following User Says Thank You to why? For This Useful Post: | solidONE (04-16-2020) |
04-16-2020, 04:43 AM | #326 |
Intent > Content
04-24-2020, 01:53 PM | #327 |
Drives: 17 Asphalt 86
Are TRD or RCE yellows more closely matched with the 2017 86 springs?
I have not been able to find the exact spring rates on the 2017 springs. I know they were brought to a more neutral balance. |
07-03-2020, 10:01 PM | #328 |
Drives: 2019 BRZ
10-12-2020, 05:26 PM | #329 | |
Drives: 06 Exige, 17 BRZ PP
I dont have a definitive answer, other than there was some material claiming "15% higher front, 10% lower rear" Which would make it essentially even, or about 3.1k front and 3.15k rear. But dont forget the 1mm bigger rear swaybar that the 17s got. |
03-02-2021, 01:31 PM | #330 |
Drives: 16 FRS
Anyone looking to buy tein flex z coilovers im getting rid of mine.
11-30-2021, 01:38 AM | #331 |
Drives: 2020 BRZ Sport Tech RS
It appears that nobody is maintaining this topic anymore (I.E. updating the info on the first page), but if anyone can update it with this info, great!
I inquired with ST Suspensions what the spring rates of the ST XA coilovers are, and they are 230 lbs./in. (4.1K) front and 285 lbs./in. (5.1K) rear. They will lower from 0.8 - 2.0" front and rear. According to the documentation, the XTA's (with the front camber plates) are 6.1K front and 5.1K rear, and also drop from 0.8 - 2.0" front and rear. NOTE: technically, KW and ST list their spring rates in N/mm. The XA's are 40 N/mm front and 50 N/mm rear, while the XTA's are 60 N/mm front and 50 N/mm rear. Weirdly, the XTA's front springs are 30mm shorter than the XA's if the documentation is correct. I can't understand why that would be... EDIT: I also looked up the documentation for KW coilovers. For the V1's and V3's, the springs for both are listed as 40 N/mm front and 50 N/mm rear (approx. 4.1K / 5.1K), which doesn't match what's on the first page of this topic for the V3's. Both will also lower 0.8-2.0" front and rear. For the Clubsport 2-way and 3-ways, the springs for both are listed as 60 N/mm front and 70 N/mm rear (approx. 6.1K / 7.1K), again with lowering ranges of 0.8-2.0".
Last edited by Tatsu333; 11-30-2021 at 01:53 AM. Reason: Added N/mm info and KW V1 and V3 info |
The Following User Says Thank You to Tatsu333 For This Useful Post: | Yoshoobaroo (11-30-2021) |
12-31-2021, 08:26 AM | #332 | |
Track Day Junkie
Drives: 2022 BRZ Limited
I have a 2022 BRZ and am looking for confirmation from more than one source that 99% of typical first gen coilovers fit the second gen cars. Did find this great thread! Could you explain what you mean by "again with lowering ranges of 0.8-2.0" Are these typical 7" free length 2-1/4" springs and the ".8-2.0" the adjustability range of the coilover body? They start out with a .8" drop? Thanks! Last edited by Scargod; 12-31-2021 at 08:39 AM. |
12-31-2021, 11:47 AM | #333 | |
The main spring length on all the mainstream, road-focused (I.E. non-Clubsport / XTA) KW and ST coilovers is 200mm (about 7.87"). KW Clubsports have 170mm (about 6.7") long main springs front and rear, and ST XTA's have 170mm long springs in front with 200mm long springs in the rear. Inner diameter for the springs is listed as 61mm (around 2.4"). All the KW and ST coilovers have helper springs as well, which just serve to keep the main springs in place under full suspension droop.
02-01-2022, 05:32 PM | #334 |
One update of note - I spoke with KW regarding the idea of running their spring spacers to increase the maximum ride height for V1/V3 coilovers (and presumably ST coilovers as well) closer to stock ride height for winter driving.
They said that running the 15mm spring spacers would be OK, and there would still be sufficient droop/extension travel. Anything more than that, they wouldn't recommend (EDIT: their next size of spacer is 30mm FWIW, so it's quite a difference). With the 15mm spacers, ride height would be within about 5mm of stock ride height at the highest setting, and still drop as much as 35mm below stock at the lowest setting.
Last edited by Tatsu333; 02-04-2022 at 10:56 AM. Reason: Added note about next size of spacer available from KW |
Similar Threads | ||||
Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 03:59 PM |
Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 12:52 PM |
