BT, dpfarr
Old 03-20-2020, 07:30 AM   #3417
losito92
Drives: 2017 Series Yellow BRZ
So to put the new bypass actuator you basically have to uninstall the whole supercharger and install again? And if that one is bad you would have to uninstall again that sounds really annoying
losito92 is offline   Reply With Quote
Old 03-20-2020, 08:29 AM   #3418
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Nah, I think once the updated valve and bracket assembly has been installed and adjusted, if the valve ever needed to be replaced, it would just be the valve like we are currently doing. It's that initial bracket change and adjustment that requires the SC to be removed, but still annoying nonetheless.
BirdTRD is offline   Reply With Quote
Old 03-23-2020, 04:04 PM   #3419
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
I want to throw in my 2c here, for anyone that's interested:
I've been running the updated BPV since early January and it's been fantastic. All the issues with the previous model have been fixed, including the weirdness when its super cold outside. I did have to remove the SC to access the brackets to do the install correctly, so I ended up handing it over to a shop.
From what I was told by Edelbrock, the unit was designed to be quite a bit more robust than the previous model. It's also physically larger. The theory is that this is a one time fix for the BPV issue, so you shouldn't have to keep replacing it like the older units. I guess time will tell, but so far it's looking promising.
localhost is offline   Reply With Quote
The Following 5 Users Say Thank You to localhost For This Useful Post:
B T (03-24-2020), BA9092 (03-23-2020), Mad1723 (03-23-2020), Side (06-13-2020), StraightOuttaCanadaEh (03-23-2020)
Old 03-30-2020, 08:41 PM   #3420
B T
Got my replacement kit from Edelbrock today. It was missing 2 M6x1.0 lock nuts and included two useless bolts. It did not include a new jam nut for the actuator stop, but the old one can be reused. I'd suggest maybe getting another lock nut to take it's place. The bracket is the same as the old one with the exception of having 2 mounting holes instead of 3. The new actuator is much beefier. It got dark before I finished installing, but you will need to manual vacuum pump to accurately gauge the mounting position. The feeler gauge not so much. I'll have a spare actuator of the old style to resell.
B T is offline   Reply With Quote
The Following 2 Users Say Thank You to B T For This Useful Post:
BA9092 (03-31-2020), CSG Mike (04-08-2020)
Old 04-15-2020, 08:52 AM   #3421
B T
For those of you who have moved to smaller pulley, did you feel much difference?
Old 04-16-2020, 01:48 PM   #3422
taiguy
Drives: 2013 Black BRZ Limited
Originally Posted by B T View Post
deets?
Edelbrock part number 15001. You can call their e-commerce department or any dealer.
taiguy is offline   Reply With Quote
Old 04-16-2020, 05:53 PM   #3423
Z06ZN6
Drives: 2017 Toyota 86
If we ever get out of this hostage situation here in CA I will let you know..... 3.00 pulley on the shelf waiting to go on.
Z06ZN6 is offline   Reply With Quote
Old 04-17-2020, 02:20 AM   #3424
jslack
Drives: 2017 Red subaru BRZ Limited
Hey guys. I just got my kit last week to install. Does Edelbrock now send the kits with the new bypass actuator now installed or do I need to also purchase that and install it before putting the kit in the car. TIA
jslack is offline   Reply With Quote
Old 04-17-2020, 10:41 AM   #3425
B T
The bypass valve come with the kit. As far as which version you have, you'll be the one updating us on whats included now.
Old 04-17-2020, 11:56 AM   #3426
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I believe the new style valve is larger and mounted to the bracket with 2 nuts whereas the old style has 3. If you have the old style, I wouldn't install the SC until you get the new style, which I would push the dealer or Edelbrock for if you bought it as new.
Send a pic.
The Following User Says Thank You to BirdTRD For This Useful Post:
B T (04-20-2020)
Old 04-17-2020, 02:16 PM   #3427
All new kits should have the new bypass.
Old 04-17-2020, 03:16 PM   #3428
BirdTRD
Simply Forgotus
BirdTRD's Avatar
CSG Mike (04-17-2020)
Old 04-17-2020, 04:15 PM   #3429
jslack
Ok I took some pictures and from what you have described, it looks to be the new bypass valve, only 2 screws holding it.
[IMG][/IMG]
Old 04-17-2020, 08:35 PM   #3430
BirdTRD
Simply Forgotus
BirdTRD's Avatar
[IMG][/IMG]
Sure does. Looks like you have a job to do!
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
