10-26-2022, 08:03 AM | #337 |
Drives: 2013 Scion FRS
TWS T66-F 18x8.5 +42
Looks like it clears.
10-26-2022, 01:38 PM | #338 |
Drives: '17 CWP Limited w/ PP
10-26-2022, 01:53 PM | #339 | |
Drives: 2017 BRZ PP, 2004 WRX
Yes, the wheels will fit. However the brakes are not a direct bolt us as far as I know. If you're looking to plop some 2022 wheels on a first gen PP, they should bolt right on. Picture source: https://www.ft86club.com/forums/show....php?p=3489094
11-02-2022, 02:59 AM | #340 |
Drives: 2022 GR86
2022 GR86 Base (17" wheels) with PP Brembos installed.
From the owner: "No spacer used. It fits and is probably OK for street. Too tight for track."
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post: | RedReplicant (04-03-2023) |
11-02-2022, 03:12 AM | #341 |
Drives: 2022 GR86
I just checked and the top post in this thread has over 150 entries, that's incredible!
When I was starting, the largest list I've seen was ~10x smaller... Thanks everyone for your contributions, and please keep them coming!
11-02-2022, 11:45 AM | #342 |
FT86Club Official Vendor
Drives: Launch-Year Whiteout FR-S
You can add all of the new APEX VS-5RS forged fitments to the list.
17x8.5" ET44 17x9" ET35 17x9" ET48 17x9.5" ET40
The Following User Says Thank You to APEX Race Parts For This Useful Post: | Tatsu333 (11-02-2022) |
11-02-2022, 08:20 PM | #343 | |
waiting on yellow gas
Drives: 2017 BRZ Series.Yellow #247
11-03-2022, 01:28 PM | #344 | |
The 17x9" ET35 is certainly the easier fitment between the two, as it really just requires a little negative camber to prevent any rubbing (camber spec is determined by ride height, tire size/model). This fitment also offers quite a bit more inner clearance to the suspension, which means it clears the PP/TRD Sachs struts and a wide variety of aftermarket coilovers without the need for spacers. This fitment also has no problem clearing the front tire rods at full lock. The 17x9.5" ET40 is really engineered for more hardcore track enthusiasts that want to maximize tire sidewall support for wider compounds. The fitment requires more attention to detail, but yields fantastic results with the proper supporting mods. More aggressive camber specifications are going to be required to prevent rubbing the fenders under suspension compression, but with track oriented wide wheel & tire fitments like this it is always still possible to scrub the inner plastic fender liners. This wider fitment will sit ~11mm closer to the suspension in comparison to the 17x9" ET35, so aftermarket coilovers with a slim silhouette are a requirement. Furthermore, the wheel can make contact with your front tie rods at full lock. - Ryan
11-06-2022, 06:50 PM | #345 |
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
ROTA Grid 8x17 et42 5x100 Matt Bronze. 225/45r17 tires.
11-15-2022, 06:48 PM | #346 |
Drives: MY2018 GT86
Hello,
Do WedsSport TC105X 17x8.5 +43 clear PP calipers? Thank you |
11-19-2022, 07:02 PM | #347 |
Drives: 2022 BRZ
Enkei TFR 17x9 +45 with 12mm spacer. This is with Brembo BM4, which is much wider than a PP caliper. You can probably run with a much smaller spacer, like 5mm, but it would be very sunk in.
11-24-2022, 06:36 PM | #348 |
Drives: 2018 Subaru BRZ with Perf Package
Hello! Long time lurker here. Here is my first contribution:
Sparco Podio 18x8 +45 with 235/40/18 clears the Brembos and OEM perf package struts. Plenty of clearance |
The Following 3 Users Say Thank You to cicada For This Useful Post: |
01-05-2023, 06:55 PM | #349 |
Drives: 2019 BRZ Sport-Tech RS
Does anyone know if the base 17x7.0 ET48 factory wheels clear the Brembos if we use a spacer?
01-11-2023, 01:39 PM | #350 |
Drives: 2017 Brz
Anyone know if the new Koenig Heliograms will fit over our Brembos?
Tags |
brz, performance package, wheels |
Similar Threads | ||||
Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 08:46 AM |
Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 08:06 AM |
Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 08:31 AM |
What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 05:15 PM |
