Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
03-11-2017, 09:22 AM | #337 |
Drives: 2013 satin white brz limited
04-20-2017, 06:33 PM | #338 |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
My friends, I am insanely stupid and need to be walked through this.
I've drilled the holes and run the wires into the trunk, I can disassemble the dash and trim to run the wires up to the HU. At the end of my harness, I have this red wire, black wire, and yellow RCA input. This is the harness from SVXdc, I purchased it years ago. At the end of the Rydeen harness, there's that little plug where it splits off into two disctinct cables. At the end of one cable I have a red wire and an RCA output. At the end of the other part I have this: Would someone please tell me what to connect where, and do so like you're talking to a toddler. I can do a lot with cars but electronics make my brain melt. Thank you for indulging me on this. Last edited by XanRules; 04-20-2017 at 06:44 PM. |
04-21-2017, 09:09 PM | #339 | |
Drives: 2015 BRZ
It's been awhile, but I believe I soldered the red wire at the RCA end to the power lead on the SVXdc harness. Then I put some extra heat-shrink on the red power lead at the ground end (to make sure it wouldn't short on anything) and affixed the ground wire to one of the bolts holding down the factory amplifier under the trunk liner. |
The Following User Says Thank You to ethan160222 For This Useful Post: | XanRules (05-16-2017) |
04-21-2017, 09:20 PM | #340 | |
Drives: 2015 BRZ
Rydeen Duo on BRZ Limited
I snagged a copy of the guide I used way back when: https://www.dropbox.com/s/dttgavatkl...6CLUB.pdf?dl=0 Last edited by ethan160222; 04-21-2017 at 10:17 PM. |
04-23-2017, 11:01 PM | #341 | |
Drives: GTS 86 auto
GTS86 Auto (Australia)
05-28-2017, 07:01 PM | #342 |
Drives: DGM BRZ
Finished my install today. Thanks for the walk through!
07-07-2018, 08:11 PM | #343 |
I've been having a connection problem for the last year or so. 2013 BRZ.
Sometimes the camera will work when I put it in reverse, and sometimes it doesn't and the "R" for reverse won't even show up on the dash. I currently have the adapter harness connected via 12v in the trunk via the amp, and I have it connected behind the head unit via a 12v? cable. I believe my camera is a knockoff as the 6v cable on the adapter doesn't do anything. I can even get everything to work without anything plugged in behind the headunit, but still intermittent. Only using the wires behind the headunit never works, which is how I believe most people are installing theirs? Any feedback would be appreciated. |
01-22-2019, 06:28 PM | #344 |
Drives: 2014 BRZ
I'm running into trouble getting the Duo2 to work with my Pioneer AVH-X5800BHS.
I have the RCA cable connected to the brown R.C.IN port. I connected the ground wire to bolt under the rear driver-side seat. I tried splicing the ground-end power wire to the Remote line on my Alpine MRV-V500 amp, but I'm not getting any image. I tried disconnecting from the amp and connecting to the RCA-end power line to a purple wire back of the HU that was labeled "Reverse Trigger," but no luck there either. I've read that a couple people tapped a pink wire in a driver-side panel, but I haven't been able to find it. Any advice would be appreciated.
Similar Threads | ||||
DGM BRZ limited on the way? | Coheed | Member's Car Journals | 16 | 04-11-2013 02:09 AM |
My LR BRZ Limited | epson1 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 11 | 09-08-2012 02:18 PM |
BRZ Limited Available | JohnATL | Southeast | 3 | 08-12-2012 11:32 AM |
Want to buy a BRZ Limited AT | kgc | Northwest | 1 | 06-16-2012 11:45 PM |
DGM BRZ Limited (man) available | Mitchs_86 | BRZ First-Gen (2012+) -- General Topics | 6 | 06-14-2012 12:50 PM |
