Old 05-15-2016, 06:47 PM   #351
CxG
Drives: Pearl White '13 ZN6
Originally Posted by Coheed View Post
There are only 3-4 kits that are favorable to me from the budget and engineering point. As each kit has been released, I've looked for engineering weak points and potential problem areas. If you want this kit to be reliable for years to come, this is something worth considering and factoring into the cost of the system.
HKS V3 kit looks great. It doesn't require a specialized belt, and the pipe routing seems slightly more ideal than the JR kit. Aesthetically, the intercooler layout isn't quite conventional, and this asymmetrical style may turn off some. Though some reliability issues have cropped up with the blower assembly, I would hope these are a small percentage of total units sold.
Cosworth SC is great. It should be super reliable, but their kits are sold in stages that don't seem to be cost-conscious. Engineering is top notch, though I don't like the rearward relocation of the TB.
My favorite kit is the Edelbrock kit. Though weight is the biggest drawback imho. This unit is big and heavy. But the setup seems to have the best engineering, doesn't need expensive traction fluid, has little maintenance, provides higher power gains than the Cosworth and Sprintex (from what little I've seen), and should be easily 100k miles reliable. You can retain the factory exhaust manifold for emissions purposes, but make even more power should you decide on aftermarket parts.
Overall, the Edelbrock kit seems to realistically be within most people's budgets, while giving solid gains and low maintenance. Turbo kits will make more power, but as people push these cars more and more, those transmissions will start showing their weaknesses, and that's something to factor into consideration as well. Just my .02.
How can mention the edelbrock but not the harrop?
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
The Following User Says Thank You to CxG For This Useful Post:
Ornelas66 (04-14-2018)
Old 05-15-2016, 09:54 PM   #352
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Has it been released? I haven't seen any kits or threads here about it. Just a sneak peak.
Coheed is offline   Reply With Quote
Old 05-16-2016, 02:18 AM   #353
CxG
Yup it has. For sale on moto east. Don't personally know anyone that has it though.
Old 07-22-2016, 11:34 PM   #354
camelflage
Drives: pinto power
I installed the innovate/sprintex kit recently. $4500 out the door for kit, labor, and dyno tune. 210 non-intercooled. made 200 hp to the wheels with the 80mm pulley it comes with now. I daily mine and love it.
camelflage is offline   Reply With Quote
The Following User Says Thank You to camelflage For This Useful Post:
brybot (08-15-2016)
Old 01-29-2017, 10:23 PM   #355
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Noob turbo question.
I've noticed quite a few people who are running 300whp turbo kits, with no engine work done.
Previously I'd been looking at supercharger kits where I've heard that anything over 260whp is risking the engine internals.
Are turbo kits different because the setup reaches peak efficiency later in the rpm range, or are the people I'm seeing with turbo kits generally throwing caution to the wind?
Wise is offline   Reply With Quote
Old 01-30-2017, 07:15 AM   #356
CxG
1) Dynos read differently
2) SC have parasitic loss and make less power with the same amount of "boost"
3) a centrifugal SC will reach peak efficiency late so that's not necessarily the case
4) it all comes down to fuel and and tuning. 300whp on 91 is completely different than 300whp on E85
5) boosting a non turbo car without engine work is always a risk.
Wise (06-25-2017)
Old 08-06-2017, 11:36 AM   #357
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Agree with all these points but would also add that it's likely a turbo is riskier because they can "add boost" low down and fairly sharply.
IMO the 1 really great thing with any SC is the relatively simple installation and setup vs turbo options too.
I like driving!
86 South Africa is offline   Reply With Quote
Old 07-10-2018, 05:36 AM   #358
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
So for turbos that aren't CARB compliant. How do you guys get around emissions testing?
Ryan GT86 is offline   Reply With Quote
Old 07-10-2018, 07:38 AM   #359
teetsdownlow
Drives: 2015 FRS
Pay someone to oversee it or sell the car before 5 years. I suppose if you have a friend/family at a prior residence you could keep it registered in a non emission regulated state
teetsdownlow is offline   Reply With Quote
FT86 Buyer's Guide! FRS vs. BRZ Differences Detailed! [Video + High Res. Stills] Rosso_Corsa Scion FR-S / Toyota 86 GT86 General Forum 23 11-03-2013 04:10 PM
First time buyer - help! chotemaamu Scion FR-S / Toyota 86 GT86 General Forum 27 02-27-2013 12:21 PM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) -- General Topics 47 05-23-2012 12:15 PM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
