BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
11-26-2020, 07:53 AM | #29 | ||
And I also think it to be fairly durable since it was designed specifically for motorsport purposes: "The 1,618 cm3 12-valve engine meets the World Rally Championship’s Rally 2 (formerly R5) regulations, following Toyota’s negotiations with the sport’s governing body to allow a three-cylinder format. Atsunori Kumagaya, who led the development project, explained: “We preferred this engine due to its light weight and compact size making it simple to install, while the lack of exhaust gas interference made it easier to obtain power.”" Quote:
Type 3 in line cylinders Valve mechanism DOHC 12-valve with VVTi Fuel system D4S - Direct & indirect injection Supercharging Turbo Displacement (cm3) 1.618 Bore x stroke (mm) 87.5 X 89.7 Compression ratio (:1) 10.5 : 1 Max. power (DIN hp/ kW) 261/192 Max. torque (Nm) 360 Emissions level Euro 6d Temp Last edited by salty_91; 11-26-2020 at 11:21 AM. |
11-26-2020, 12:12 PM | #30 | ||
Drives: Q5 + BRZ + M796
The actual engine in the WRC car is modified: Quote:
Incorrect. The specs: The FA20 is 86x86 which is a shorter bore and stroke than the Yaris motor. The FA24 has the same 86mm stroke as the FA20, so the stroke is shorter than the Yaris, but it does have a larger bore of 94mm. The point is the Yaris has an extra 4mm of stroke, which means piston speeds are higher for any given RPM. The bore is larger on the FA24, but the Yaris could have heavier pistons considering the specific output of the Yaris engine is higher than the FA24, and each cylinder has to manage much more . Think about it. The Yaris is making more hp with less cylinders, so each rod and piston is working harder. If they bother were tuned for 400hp, the Yaris would be dealing with 133hp per cylinder, but the FA24 would be dealing with 100hp per cylinder—about 30% less. At 400hp, the Yaris would be putting out 250hp per liter. The FA24 would be putting out 167hp per liter—about 33% less stress per liter. If the FA24 put out 250hp per liter it would be making 600hp. Three cylinder engines also have a power stroke every 120 degrees vs 90 degrees of crankshaft rotation, and they are less balanced, so they require more balancing shafts. Considering the strength needed in the powertrain, the extra stroke and the engine imbalance, the rpms are lower. Because there is less cylinders, each cylinder sees higher pressures per hp. Because there is less displacement, the engine has to work harder to attain the same output like a short man having to lift the same weight as a big man. For all these reasons, I would rather have the FA24. I get why some would want that engine. It is lighter, it does have more power from the factory, it has a tunable turbo, and it may have strong internals, so it might have some overhead for tuning. We don’t know, but what we can guarantee is the FA24 will be an improved FA20, which is already a good thing from my perspective, as others and I have doubled the power with stock internals. I can’t wait to see what the FA24 can do.
11-26-2020, 03:26 PM | #31 |
Drives: Dodge Patitas
I thought that 3-cyl turbo sounded sweet. Sounds like a 6-cyl!
11-26-2020, 05:21 PM | #32 |
Drives: 86 (sold), 370Z
The Following 4 Users Say Thank You to Red-86 For This Useful Post: |
11-26-2020, 05:27 PM | #33 |
I am actually glad they didn’t use the GR 3 cylinder. Much as I think the twins could use a turbo without detracting from the experience, I don’t think the lower redline, ‘rally’ style 3 banger in the GR Yaris is the right one. I like the fact they stick with a flat 4. It’s distinctive.
If anything, I wish back in 2012 they had put a Subi flat 6 in (e.g. the EZ30D/3.0R). People mistakenly think it is heaps heavier, but in fact it is actually only a few kg heavier than the FA20, and would have provided the power and torque to turn the twins into front engined Cayman hunters. I know it was never part of the original design brief, but a man can dream, right? |
The Following 2 Users Say Thank You to Red-86 For This Useful Post: | Irace86.2.0 (11-26-2020), sato (11-29-2020) |
11-26-2020, 06:18 PM | #34 |
Don’t dream. Swap it.
11-26-2020, 06:21 PM | #35 | |
Drives: 2017 Toyota 86
11-26-2020, 06:44 PM | #36 | |
I'm cool with that. If our European brothers and sisters had to miss out for the sake of the rest of us, so be it. And funnily enough, it looks like they could well miss out on gen 2 entirely anyway.
Given the poor sales of the twins in the EU (when you see the steep prices you will understand) it is fascinating to think of what a different car it could have been from the beginning if they had decided to cater entirely to the rest of the world and rule out the EU from the get-go. As I said, I understand it wasn't part of the design brief. They wanted a NA H4, and that's what they got. But I can still daydream about a H6 twin that never was... |
11-27-2020, 09:15 AM | #37 | ||
And if it's properly balanced with the shafts I don't care about it's natural imbalance - I've driven 3 cylinder mini cooper and it felt perfectly smooth, not much difference with the 4 cylinder cooper s engine (which is b48 and btw powers junior Supra). And if we go on with bmw engines - this yaris 3 cylinder is actually very similar to bmw s55 engine (though split in half), which powers m3 and m4 - both have the same stroke (89.7 - yaris, 89.6 - s55) and same power per liter ratio (261/1.6=163 hp; 493/3=164 hp). And s55 is highly tunable. But anyway I share your excitement on fa24 (though skeptical of it's being enough). Last edited by salty_91; 11-27-2020 at 01:41 PM. |
The Following User Says Thank You to salty_91 For This Useful Post: | Irace86.2.0 (11-27-2020) |
11-27-2020, 05:51 PM | #38 | |
And finally there's a difference between twins: Toyota gets a self-developed low displacement turbo three, while Subaru stays stick to it's iconic flat engine. These are two different audiences and everybody is happy |
11-28-2020, 01:56 AM | #39 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
Silly to wish for them to increase production and development costs on a car that doesn't make them much money or bring more brand awareness even. The 3 cyl isn't even developed for longitudinal mounting.. How many people prefer Fiata engine over Miata in the ND?? They are discontinuing the Fiata in Japan if that says anything.. Admittedly I would love to see Toyobaru give everyone the middle finger and come out with a limited edition hi-po varient that ends up costing as much as a Supra just to say they did it...they sure could afford it, but in reality the whole project from the start has been a pointless love child just to reward the 100 enthusiasts who care for shit like this.. Last edited by HKz; 11-29-2020 at 12:16 PM. |
11-29-2020, 08:25 AM | #40 |
If they do make a real limited edition release, I just hope they do not simply add 5hp or add a body kit and call it a win. Mazda made a big improvement (almost 30hp) on the Miata engine s few years after the ND introduction.
11-29-2020, 12:08 PM | #41 |
It also took them almost 30 years to do that increase. So for the Quintuplets that means a couple more decades and two more generations before they have to act to do what Mazda did.
11-29-2020, 12:10 PM | #42 |
Tags |
engine, swap |
Similar Threads | ||||
Toyota GR Yaris | JD001 | Other Vehicles & General Automotive Discussions | 888 | 01-18-2024 03:34 PM |
Toyota Yaris WRC announced | vh_supra26 | Other Vehicles & General Automotive Discussions | 55 | 08-12-2017 05:59 AM |
Dedicated to those who are in a YARIS! do to them having issues with there FRS/BRZ | 86'ing | Issues | Warranty | Recalls / TSB | 23 | 09-15-2012 04:57 PM |
FR-S vs Yaris/Tercel, yes you read that right | regal | FR-S / BRZ vs.... | 2 | 08-13-2012 11:43 AM |
2012 Toyota Yaris | Dark | Other Vehicles & General Automotive Discussions | 13 | 10-10-2010 11:57 AM |
