07-22-2021, 11:09 PM | #30 | |
Drives: 2022 GR86
I've attached the current versions of the "Specifications" and "At a glance" PDFs from the right section of that page. In case anyone was still unsure, the 12.5:1 compression rate is now official. |
07-22-2021, 11:16 PM | #31 |
Drives: 2022 GR86
"4-wheel disc with Electric vacuum pump power assist"
Is this different from what it was before? |
07-22-2021, 11:18 PM | #32 |
Drives: 2022 GR86
"New for 2022, the standard Tire Pressure Monitoring System (TPMS) now allows two sets of
wheels to be ID registered. This allows the owner to switch to seasonal tires without the need of changing the tires on the original wheels." Seasonal tires, of course. |
07-22-2021, 11:24 PM | #33 |
Drives: '14
Flexible flywheel... that's new right?
Always learning.
07-22-2021, 11:48 PM | #34 |
Drives: Supra MKV, FR-S
I think OG AT BRZ has an electric vacuum pump but the MT should be just using intake vacuum. Not quite sure about the benefit for switching to a electric model? More stable brake pressure when doing heel toe?
07-23-2021, 01:02 AM | #35 |
Drives: GR86 RC
and yet it is already 20kg heavier than 2012 (i couldnt help myself, had to compare the 2012 and 2022 specs line by line muahahah). which means the extra 75kg that they gained due to crash regs etc which are "almost negated by the alu roof and fenders" is really only offset by say 45kg.
other comparisons: 1. same MT gear ratios 2. same brake rotor diameters! so that means AP Essex Sprint again! 3. slightly steering angle ? (f you multiply the steering lock with the rack ratio and compare, new lock > old lock ie. 13.5 x 2.5 > 13.12 x 2.48). i probably reading too much into it here haha. 4. slightly narrower front track? new vs old = 1519mm vs 1520mm. doesnt matter cos et42 is going onto mine muahaha. 5. wider rear track. new vs old = 1549mm vs 1540mm. same et42 going on muahahaha. |
The Following 2 Users Say Thank You to Jianlun For This Useful Post: | JRitt (08-10-2021), Yoshoobaroo (07-23-2021) |
07-23-2021, 01:12 AM | #36 |
Drives: GR86 RC
Found the below from here https://motor--fan-jp.translate.goog...o=ajax,nv,elem
Aluminum front fender: -3.0kg Aluminum front housing: -3.0kg Aluminum roof panel: -2.0kg Hollow front stabilizer: -0.5kg Weight reduction of muffler: -1.6kg Weight reduction of front seat: -2.6kg Weight reduction of propeller shaft: -1.1kg |
The Following 2 Users Say Thank You to Jianlun For This Useful Post: | DAEMANO (07-28-2021), ToySub1946 (07-23-2021) |
07-23-2021, 09:22 AM | #37 | |
TRACKBREAD
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | DAEMANO (07-28-2021) |
07-23-2021, 09:58 AM | #38 | |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
everyone's an internet vehicle R&D expert. |
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post: | Tcoat (07-26-2021), Yoshoobaroo (07-23-2021) |
07-23-2021, 10:40 AM | #39 |
Drives: 2013 Scion FR-S Series 10
If that's the case, then that partly explains the weight loss.
From https://www.ft86club.com/forums/showthread.php?t=7881 OEM spare tire with liner foam= 25.8 lbs. OEM trunk tools, jack, tow hook= 5.8 lbs. That is 31.6 lbs alone. |
07-23-2021, 10:47 AM | #40 | |
TRACKBREAD
Yea the tire repair kit is way lighter. Looks like they’ve pulled out all the stops to keep it light. That said, I can’t think of a single car that came out in the last 10 years that I know comes with a spare. The inflator kit is standard now, if you even get anything at all besides runflats. |
07-23-2021, 11:03 AM | #41 |
Drives: 2014 Scion FR-S
Hope they have an accessory subwoofer again! I love my Subaru Accessory 10" Kicker.
Also kinda miffed about the lack of the spare tire. I'd rather have a slightly heavier car and remove the spare at the track . I know barely anyone has to use their spare, however, when you loose a tire 100+ miles away from home and the tow bill is $100+ you'll be wishing you had that spare.
Charlotte, NC
14 Firestorm Red FR-S |
The Following User Says Thank You to GraysonGreene For This Useful Post: | g e (07-26-2021) |
07-23-2021, 11:27 AM | #42 |
Pavement Grey
surprised they didnt increase the cargo space with the removal of the spare tire.
Typical of manufacturers though, they just fill the spare tire well with a foam block with tools and a fix-a-flat kit. |
Similar Threads | ||||
HKS Supercharger Power and Pricing Released! | ZC6BRZ | Forced Induction | 128 | 05-29-2019 02:14 PM |
**Echelon Autosports** AFE Takeda Air Intake .... Low Intro Pricing on all Pre-Orders | Echelon Autosports | Engine, Exhaust, Bolt-Ons | 0 | 07-26-2012 12:58 PM |
New Zealand BRZ Pricing released | lazyluka | AUSTRALIA | 30 | 04-25-2012 05:54 AM |
Canadian pricing released 25,990 | Mather | CANADA | 1 | 03-31-2012 12:01 PM |
