Old 12-17-2022, 12:28 PM   #29
Nick Dugdale
Nick Dugdale's Avatar
Drives: 2015 Subaru BRZ
Here is my official live updated 86 weight sheet - (Google Sheets Document)
I'll be updating this sheet as I find more weight to remove. We are on track to compete within 'NASA TT5' for the 2023 season at 2,550 lb. MCW.
Standby.
"The vision manifests the reality." NASA TT5 Silver 2015 Subaru BRZ Limited
Nick Dugdale is offline   Reply With Quote
The Following 3 Users Say Thank You to Nick Dugdale For This Useful Post:
new2subaru (04-16-2023), RedReplicant (12-18-2022), RT-BRZ (12-18-2022)
Old 12-18-2022, 02:51 PM   #30
RedReplicant
Drives: None
Another non-Hoosier convert?
RedReplicant is offline   Reply With Quote
Old 12-18-2022, 11:37 PM   #31
Nick Dugdale
Dave looks like he is saying the RC-1 is the obvious choice.
The Following 4 Users Say Thank You to Nick Dugdale For This Useful Post:
Jdmjunkie (12-19-2022), ML (12-19-2022), RedReplicant (12-19-2022), RT-BRZ (12-19-2022)
Old 04-16-2023, 03:28 AM   #32
Nick Dugdale
2023 NASA TT season update
This season I was able to achieve my (2,550lb) mcw in the Subaru BRZ for NASA TT5. From my understanding this is a milestone that hasn't been reached before within the US for TT/ST competition purposes. That is a pretty cool objective to claim if you ask me.
Secondly, since I dropped my min weight down to 2,550 pounds (1,156kg) I was able to run the 'MAXXIS RC-1' compounds this season along with a front splitter. I decided on running the legal 255/40/17 size compounds on my 17x9's and this is what I think about the setup for this season.
My personal feedback on the MAXXIS RC-1 compound
So far I have put 18 heat cycles on my first ever set of MAXXIS RC-1's. I found out that the MAXXIS RC-1 compounds have a quick regressive performance fall-off trend as opposed to a progressive-proportional trend of other race compounds on the market making these compounds ideal for W2W racers and short burst sprint shootout competition such as hillclimb. I found myself avoiding tire scrub on the out laps due to maintaining cooler patch temps in order to optimize performance longevity throughout my sessions. I am going to be honest, the MAXXIS RC-1 does not care for the heat. The compounds seems to prefer a temperature threshold of between (48-76F) from my experience. (Roughly a 30 degree temperature variation window where these compounds will perform at their optimal.)
In Conclusion
The MAXXIS RC-1 is a solid contender to the 100tw market with loads of user feedback providing the driver with consistent control and predictability while thrashing on the absolute edge every time. The MAXXIS RC-1 is a fun predictable mule of a tire but doesn't seem to maintain its performance on a sun soaked track where drivers compete the majority of the time throughout a season.
The peak grip performance is found on the out lap and tends to falls off abruptly after a few hot laps depending on the track and conditions (so try not to scrub much). The performance falloff is simply "abrupt" after a few hot laps which means TT drivers must get their flyer laps in within the first ~4 laps or its fighting an uphill battle to capitalize on the loss of grip performance to turn a fast lap after that.
Who these compounds are best suited for
• Super Touring (w2w) racers
• Hill Climb sprinters
Pros and Cons as it pertains to Time Trial competition
PROS
• Predictable
• Slip control
• Braking
• Pressure variation
• Longevity / wear
• Life consistency (environment dependent)
• High speed grip in most temperatures
• Medium speed grip on cool track
• Initial grip performance
CONS
• Acceptable steering feedback
• Medium to low speed grip on hot track
• Hot track performance
• Rapid regressive fall-off (warm environments)
ML (04-16-2023), RedReplicant (04-16-2023), RT-BRZ (04-16-2023)
Old 04-16-2023, 11:15 AM   #33
RedReplicant
Drives: None
I've run them for a few years and I completely agree with your assessment, I am super gentle on them on the out lap and I've got a couple of laps at most. Time needs to happen in the first or second session of the day too (assuming you're already consistent on the given track).
Old 04-16-2023, 04:01 PM   #34
Nick Dugdale
The MAXXIS RC-1's are great compounds for the money. I just wished they worked for my driving style and overall class setup especially running in warmer climates.
From a comparison stand point the FA20 in the 86 falls on the lower end of the power spectrum (both HP/TQ), as it relates to the overall TT5 field. I am glad I tested the MAXXIS RC-1's this season but I am forced to revert back to a Hoosier R7 since the car demands the extra grip and consistency to contend with the high power competition. End of day I will be sacrificing wear / longevity and budget for a better overall option for the car as it stacks up in class.
Revised 2023 NASA TT5 classification will reflect:
• 2,750 (lb) MCW
• 4'' Front splitter penalty
• 225/40 Hoosier R7
• Spherical joint penalty
• A-arm penalty
• 257mm with weight greater than 2,749 (lb) bonus
Ballast Project
I teamed up with a local metal market in South Carolina to cut n punch (10qt) 1/4'' 19.1 lb plates to flatten out the R/L weight ratio. I stacked 152 (lb) of plate in the passenger compartment on the OEM reinforced seat mount location utilizing a static 8.4 (lb) 'PLANTED' seat bracket and high grade hardware. The rest of the ballast with be in the form of fuel (~60 pounds in tank) as well as bell plate in the trunk to make an effort to balance out that F/R weight distribution. A huge benefit to this setup is that the weight is placed in ideal areas of the chassis and I will no longer suffer from fuel starvation. (I am working on revising the ballast design as we speak.)
(Corner balance / alignment Wednesday before I leave for NASA Mid Ohio this weekend.)
RedReplicant (04-16-2023), RT-BRZ (04-17-2023), villainous_frx (04-17-2023)
Old 02-10-2024, 08:02 PM   #35
Nick Dugdale
*UPDATE* I have plans for a motor swap this season. Still have my sights locked on NASA TT5/ST5 competition end of year.
True FA20 weight below:
Here is the FA20 out of the 2015 BRZ sporting an 10lb aftermarket flywheel and OEM clutch still on the engine.
Weight excludes fluids, AC compressor (+10lb) , injector covers (+5lb) and exhaust manifold (+15lb), OEM flywheel (+10lb)
My FA20 weight: 315 pounds as shown
OEM FA20 weight ~355-360 pounds
The Following 8 Users Say Thank You to Nick Dugdale For This Useful Post:
cueball89 (02-12-2024), DocWalt (02-15-2024), gt5759 (02-15-2024), new2subaru (02-20-2024), pope (02-16-2024), RedReplicant (02-10-2024), Stonehorsw (03-03-2024), villainous_frx (02-12-2024)
Nicks white gt86 Rallye Nick Member's Car Journals 6 02-17-2016 12:13 PM
Weight Savings Idea: BoostCap + Solar Panel vs Battery MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 10 10-25-2014 07:43 AM
Suspension Weight Savings Tansey86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 02-26-2013 05:16 PM
More weight savings (wheel content) GTB/ZR-1 Tracking / Autocross / HPDE / Drifting 5 11-12-2012 10:03 AM
How's this for weight savings? (battery content) GTB/ZR-1 Tracking / Autocross / HPDE / Drifting 11 11-05-2012 10:27 PM
