07-14-2022, 07:33 AM | #29 |
Drives: ‘13 AT FRS
It’s not really that.. it’s getting the majority of the benefits an aftermarket intake would cost for nothing but maybe 5 minutes of your time. Since you refuse to see what is in the video.
5-10whp throughout rpm without filter (some spots it’s 0 gain because I know you will use that to be dismissive) 0-1whp gain without filter and k&n dropin Unlike the first gens.. the stock filter flows quite well and there’s no benefit of an aftermarket one aside from potential sound. Last edited by Ogt; 07-14-2022 at 07:44 AM. |
07-14-2022, 07:44 AM | #30 | |
There was little benefit to the first gen as well. It also was a very effective system right from stock. The new ones are not much different. Getting 5-10 on a dyno is well within the variance of each pull so not really showing anything anyway. Expecting a 10HP increase from removing just one part of a filter is just not realistic. The 2016 facelift cars got a 5HP increase from improved intake, exhaust, tuning and other tweaks so how is it reasonable to state double that increase from removing a thing carbon overlay?
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | ROFL it's Waffle (07-19-2022), weederr33 (07-20-2022) |
07-14-2022, 08:52 AM | #31 | |
Drives: 18 Brz (Sold) / 22 BRZ
Engineering explained did a similar testing on other platforms and got similar results. I saw also this being done on BMWs with similar results. The change will not be effective IF the intake is not a bottleneck, but data shows that this is not the case for those (my best guess, OEM develops the system without the filter as globally I don’t think is needed, and then slap the filter because CAFE) |
07-14-2022, 09:00 AM | #32 | |
Not disputing it will make some difference just the degree of difference. The JDM is probably tuned slightly differently as well so how much of that 4HP is tune and how much is actual mechanical filtration. Wishful thinking is wishful.
07-14-2022, 09:26 AM | #33 | |
My opinion that this was done more as a clickbait. In the video, he admits that the real number should be 4hp. |
The Following 5 Users Say Thank You to Stonehorsw For This Useful Post: | CaptainFenderbaum (08-08-2022), CincyJohn (07-14-2022), DocWalt (07-19-2022), DylanJZA (07-22-2022), Tcoat (07-14-2022) |
07-14-2022, 09:57 AM | #34 | |
Drives: 2022 MT Neptune GR86 Prem.
The important thing that I take away from this video, is that despite how much folks love their oiled K&N filters and "cold air" intakes (which actually take in hotter air than the original intake), if you want to do something to your intake/filter set-up, taking out the useless charcoal diaper is definitely the first (and probably the only) thing you should do. Last edited by CincyJohn; 07-14-2022 at 10:34 AM. |
The Following User Says Thank You to CincyJohn For This Useful Post: | Ogt (07-14-2022) |
07-14-2022, 10:26 AM | #35 | |
07-14-2022, 10:33 AM | #36 |
The Following 2 Users Say Thank You to CincyJohn For This Useful Post: | Ogt (07-14-2022), Stonehorsw (07-14-2022) |
07-14-2022, 01:30 PM | #37 |
Drives: "I drives like a Porsche"
I hate California. Lived here all my life it’s a shit hole. And everyone who runs it is a grifter.
07-14-2022, 01:35 PM | #38 | |
The thing is that making outrageous claims gives people expectations that just are not going to be met. All in all four does not equal ten. Everybody can get as defensive as they want I am not insulting the fucking thing just trying to clarify a very simple point.
07-14-2022, 01:38 PM | #39 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Stonehorsw (07-14-2022), weederr33 (07-20-2022) |
07-14-2022, 02:52 PM | #41 |
And everybody may as well get used to the fact that the rest of the world (including the other States) are all headed down the same road. California is just leading the charge.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (07-14-2022) |
07-14-2022, 03:54 PM | #42 |
Drives: 2013 frs red
Some states don't have as much industrial pollution so vehicle emissions aren't as critical.
Similar Threads | ||||
My First Run Impressions and Testing Results with (knockoff) Billet Power Blocks | Tatsu333 | Engine, Exhaust, Transmission | 9 | 09-16-2022 06:43 PM |
ACE Header Independent Testing Results and Review - 199.6WHP on CA 91 Octane | CounterSpace Garage | Engine, Exhaust, Transmission | 849 | 08-26-2020 04:44 AM |
Objective CLD (sound deadening) Testing Results | TOOSTUBBORN2FAIL | Electronics | Audio | NAV | Infotainment | 9 | 03-23-2016 06:41 PM |
Motor Oil Testing Results | Rocket.BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 06-30-2014 10:48 PM |
Air filter Testing | Fast_Freddy | Engine, Exhaust, Transmission | 0 | 06-06-2013 01:21 AM |
