Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-29-2023, 10:42 AM | #29 | |
Drives: 2013 Scion Frs
The driveway concrete is very porous and much easier to clean oil off compared to the garage concrete - not nearly as porous. I noticed two new spots yesterday. It was parked in the street. I drove it all weekend without any leaking. This is really confusing. IÂ’m wondering if these spots form at startup. IÂ’ll have to monitor. The catback exhaust sometimes leaves water spots on startup, but evaporates quickly. Never there when I return from driving. |
08-29-2023, 11:54 AM | #30 |
Also, last visit to the mechanic was on a day where it was 110 degrees and I used the AC. When it was on the lift the mechanic mentioned AC condensation. There was a large puddle on the ground and it was still dripping out of the hose. The puddle was much larger than IÂ’ve observed in comparison to our other two vehicles.
The Following User Says Thank You to Stevedave For This Useful Post: | soundman98 (08-29-2023) |
09-07-2023, 03:44 PM | #31 |
I drove the car for 3.5 hrs straight and since then the car has been leaking much more. I suspect it’s not transmission fluid. Things have been hectic to say the least. Plan is to get it on stands in the garage, take lower panels off and do a full inspection. I’ll report findings and take pics
The Following User Says Thank You to Stevedave For This Useful Post: | soundman98 (09-07-2023) |
Similar Threads | ||||
Transmission Synchro/Output Shaft Noise After a Concerning Sound | Rybot | Engine, Exhaust, Transmission | 7 | 07-01-2022 11:06 AM |
Leaking diff. At pinion seal, after replacing Throwout Bearing | dc2stud | Engine, Exhaust, Transmission | 7 | 02-19-2020 05:23 PM |
Any DIY fix for leaking window seal? | lupindub | DIY (Do-It-Yourself) Guides | 9 | 04-03-2018 09:28 PM |
Output shaft bearing | mhiscott | Engine, Exhaust, Transmission | 10 | 08-09-2016 06:04 PM |
AT Transmission rear seal leaking. | CircuitJerk | Issues | Warranty | Recalls / TSB | 6 | 10-31-2013 03:41 PM |
