12-04-2012, 11:28 AM | #29 |
NASA SpecE30 Racer
I mentioned it earlier. I have about $2200 total invested in the project. If you wanted new calipers it would be closer to $3000 invested.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | 1strwdcar (12-04-2012) |
12-04-2012, 11:39 AM | #30 |
Drives: 2013 scion frs Whiteout
12-04-2012, 01:44 PM | #31 |
First 86 Driver Baby!
Drives: FR-S, Flex
Looks great man! I can't wait to get back in town and meet up!
12-04-2012, 02:23 PM | #32 | |
Drives: Attitude
And if you're buying used calipers you have a good chance at fucking that up. The fasteners on the opposite end brake bleeder ports SHOULD be red Loctite'd in...so you would want to torch them before trying to get 'em out and swapping. Since it's an all aluminum caliper...every single one of the threads on them is very fragile; most actually have had the mounting ears mangled. |
12-04-2012, 02:33 PM | #33 |
NASA SpecE30 Racer
They were definitely red Loctited on mine, but I didn't use any heat nor mess up any of the threads or heads on the bolts. I have definitely used a torch previously to heat up red Loctite on some wheel studs to remove them, and it works great.
- King Tut
12-04-2012, 02:41 PM | #34 |
Damn that sucks the rear is basically just for looks, maybe a bit better modulation and better cooling at extremes but IMO the stock rear brakes are very good as is.
12-04-2012, 02:47 PM | #35 |
I like seeing OEM stuff used. Any idea of what all the parts end up running?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
12-04-2012, 03:06 PM | #36 | ||
Drives: Attitude
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | swift996 (12-05-2012) |
12-04-2012, 03:10 PM | #37 |
Great write up as usual
Glad to see your BRZ is looking better than ever now. |
12-04-2012, 03:55 PM | #38 |
NASA SpecE30 Racer
I still like the simplicity of pad swaps and the availability of pad options for the STI rear calipers. Go with a more aggressive rear pad if you want to get more use out of the rears.
- King Tut
The Following User Says Thank You to King Tut For This Useful Post: | omegared19 (12-17-2012) |
12-05-2012, 12:24 PM | #39 | |
Taking Corners
Drives: 2014 FR-S Whiteout Monogram
I don't think that is something that is switched by just swapping the bleeders, is it? Brakes really aren't my area of expertise, so I'm all ears. Looks great either way, I may go this route! |
12-05-2012, 12:37 PM | #40 | |
Drives: Attitude
12-05-2012, 12:59 PM | #41 |
Drives: '13 BRZ Ltd WRB
Bleeders need to be swapped when keeping calipers on the same side as STi (bleeder must be at the top for air to escape). Swapping side to side would reverse the piston orientation.
Just rotating the caliper to the front of the rotor does not change which piston is leading/trailing since the rotor still spins the same direction. Feel free to correct me if I'm wrong. No personal experience here, just picturing it in my head.
12-05-2012, 01:31 PM | #42 |
NASA SpecE30 Racer
Swapping the calipers side to side was if you wanted to keep the bleeders in their original location and then the pistons are in the wrong orientation. If you swap the bleeders then you keep the calipers on the same side as the STI, then you are good to go with the pistons in the proper orientation. If you look at a picture of an STI and my car you will notice they are oriented the correct way.
- King Tut
The Following User Says Thank You to King Tut For This Useful Post: | nix (12-06-2012) |
Tags |
brakes, caliper, sti, swap |
Similar Threads | ||||
STI front brakes on BRZ (confirm) | michael317 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 123 | 05-23-2016 12:41 PM |
GTS Front Brakes + Rotors + Pads | GC GTS Aero Kit | Australia Classifieds | 2 | 11-16-2012 05:20 AM |
R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 10:08 AM |
