Old 03-18-2013, 07:46 PM   #29
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Thanks for this, definitely doing this when it gets warmer.
Myv is offline   Reply With Quote
Old 03-21-2013, 12:35 AM   #30
foxhu
THANK you i've been looking for a diy for this!@!@! gonna do it when the weather is warmer!@!@! I can't bring it back to the dealer they will just gonna blame on the accident that i had before....
foxhu is offline   Reply With Quote
Old 03-23-2013, 12:32 PM   #31
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Just installed my gaskets from wdninja.
Lets see if this works! I'll update you guys in June/may when its warm.
Old 03-28-2013, 05:46 PM   #32
Mike86CelicaGTS
Mike86CelicaGTS's Avatar
Drives: FR-S Raven BLACK
Just downloaded the Gasket templet but its 21 inches.
Can I get one to scale?
Please...
Mike86CelicaGTS is offline   Reply With Quote
Old 03-28-2013, 09:20 PM   #33
GNS
Drives: .
What sword do you have? Hanwei, or?
GNS is offline   Reply With Quote
Old 03-28-2013, 09:30 PM   #34
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by Cody View Post
I was thinking if drilling a hole in the bottom to let it dry and then using a blow dryer. I opened the lights to paint them black, but moisture is coming from the stock gasket... Tested it.
You would think that when they make something that allows the whole trunk to fill with water they would fix it..... My entire trunk is soaked bc the water goes under the vanity guard... And through the holes in the frame .. Water is getting in the tails through the big red brake light hole....to me this seems like a manufacturer screw up.
Collect a couple silica gel packets from shoeboxes etc. and tape them onto the end of a piece of coathanger. stick it into one of the holes for the bulbs and leave it for a bit. It'll dry it right out.
Cheers
Nathan
SubieNate is offline   Reply With Quote
The Following 2 Users Say Thank You to SubieNate For This Useful Post:
Cody (03-30-2013), Superhatch (04-15-2013)
Old 03-29-2013, 01:16 AM   #35
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Please...
Here, try this. Print to "actual size":
https://drive.google.com/uc?export=d...y03Tng5eG9aUXM
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
The Following 3 Users Say Thank You to wdninja For This Useful Post:
Freeman (04-14-2013), mx5 2nr (12-16-2013), scary alien (04-13-2013)
Old 04-02-2013, 01:46 PM   #36
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Thanks again Chris for stopping by this weekend. So far, no foggy lamps.
I did however forget to plug in the pass side lamp
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-02-2013, 07:17 PM   #37
wdninja
wdninja's Avatar
You're not alone in that. I was getting frustrated that my Colin tails weren't working at first and I didn't have it plugged in.
The Following User Says Thank You to wdninja For This Useful Post:
chanomatik (01-08-2015)
Old 04-15-2013, 11:18 AM   #38
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
A handful of rainy days and a few cold morning and so far my tails are dry as a bone!
Thanks you very much for the gaskets.
BatStig is offline   Reply With Quote
Old 04-15-2013, 12:09 PM   #39
wdninja
wdninja's Avatar
Originally Posted by Apocalypso View Post
A handful of rainy days and a few cold morning and so far my tails are dry as a bone! Thanks you very much for the gaskets.
No problem, glad to help.
Old 05-02-2013, 10:18 PM   #40
dem00n
dem00n's Avatar
Drives: Scion FRS
WELL.
It didn't work.
My driver side tail has lots of water, the right gets it sometimes.
I did the thicker gaskets, even did the adhesive all around the DIY said.
I'll check the sealing again, but it was perfect when i put it in...
Old 05-03-2013, 09:35 AM   #41
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
WELL.
It didn't work.
Make sure you didn't overtighten and crack the housing when you reinstalled the lights.
Sent from my Nexus 4
Parting out HERE
Old 05-04-2013, 09:37 PM   #42
dem00n
dem00n's Avatar
Drives: Scion FRS
The housing wasnt cracked.
I doubled up the adhesive, now its nice a thick.
Should be good, i'll post again in 2 months.
condensation, diy, gaskets, tail lights
Tail Light Condensation rbrtndrws Issues | Warranty | Recalls / TSB 1033 04-16-2019 10:57 AM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
tail light Sketch575 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-11-2012 02:32 AM
Tail light replacement? alexm Cosmetic Modification (Interior/Exterior/Lighting) 5 06-05-2012 04:38 PM
