Old 04-05-2013, 09:45 PM   #29
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
tracking it and logging tomorrow, it gonna be hot so lets see what happens
Huehuecoyotl is offline   Reply With Quote
Old 04-06-2013, 08:19 AM   #30
mad_sb
Drives: 2013 Asphalt FR-S
I ran a set of the okada coils on my evo with meth. They honestly did not work any better than stock. IIRC they are just modified stock coils anyway.. At least they wee for the 46G3.
Old 04-12-2013, 02:52 PM   #31
fishek
Drives: H8R FR-S
Got the CEL and same OBD code on track. Car has never had an aftermarket tune. Took it to the dealer. They said they will replace the coils and put an order. Waiting for them to arrive. Have another track day in a week, will see how it goes.
If you want to make a small fortune in motorsports, start with a large one
fishek is offline   Reply With Quote
Old 04-12-2013, 06:14 PM   #32
Carwhisperer
Drives: A lot of supercars.
This code is going to be quite common for the track guys and for the people who drive it hard on the streets. I can see it now. My car has been at the dealer for 2 days now. But as soon as I got this code, the car would pop several times from the engine bay under moderate to WOT accerlation in low - mid RPM range and especially going 70 mph on the highway in 6th.
Andd just found out I had a injector leak causing the 1st cyl to malfunction which is why the PO351 popped up for me.
Carwhisperer is offline   Reply With Quote
Old 05-08-2013, 05:29 AM   #33
subaruferrucci
Drives: FR-s
i just had this cel pop up for me this weekend on the track. i have LW pully and header back
subaruferrucci is offline   Reply With Quote
Old 05-08-2013, 08:47 AM   #34
mad_sb
Do you have a tune?
How many miles on the car?
How many track sessions?
What Fuel?
What Specific Code (which cylinder)?
I'm trying to understand if this is a heat related issue breaking down the coilpacks or bad injector seals causing lean condition (i think this could over heat the coil pack over time as well).
Old 05-08-2013, 03:45 PM   #35
subaruferrucci
Drives: FR-s
no tune on the car was running 93 octane fuel and it was a p0351.
10k miles on it and before i hit the track it was about 9500
i did maybe 3-4 30min sessions with 30-60mins min between the sessions on day 1 and about the same on day 2 and i made sure to do cool down lap. and i got the light on both days and cleared it but the car ran fine.
i even changed the the oil to 5w-30.
i am going to take it to the dealer ship and see what they say
Old 07-18-2013, 04:28 PM   #36
Carwhisperer
Just got this CEL again... what scares me is that this is the same CEL I got right before I started having DI leaking and popping under acceleration.
Old 07-18-2013, 06:00 PM   #37
Simmons
Simmons's Avatar
Drives: 2022 BRZ
When I got the code, I changed the coil and plug on number 1 cylinder and it fixed it.
Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 07-19-2013, 09:42 PM   #38
FT86RGV
Just got the same code today. P0351. Turned on while I was flooring it in 4th on the on-ramp of the highway. I have an ecutek tune. If I flash it back to stock and take it back in to the dealer will they replace it under warranty?
FT86RGV is offline   Reply With Quote
Old 08-02-2013, 08:50 PM   #39
Carwhisperer
Got this code again. Stock ecu. happened shifting into 4th gear. Only get it when I shift under WOT.
The Following User Says Thank You to Carwhisperer For This Useful Post:
DjDATZ (06-13-2017)
Old 08-06-2013, 09:12 PM   #40
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I just got this code today.. didn't hear a pop or anything. Whats everyone's advice? Flash to stock and hit the dealer up for new coils?
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 08-06-2013, 09:15 PM   #41
xjohnx
Grip>Slip
xjohnx's Avatar
I'd try to have the coil/plug replaced, as well as have them check out the DI seals. Good luck on the last part though.
Old 08-06-2013, 09:22 PM   #42
Batman
Easy, Tiger.
Batman's Avatar
I have friends that are techs there, so it's no problem getting seals checked while they are in there. My issue is making sure it's all under warranty, because having those friends also has made the service manager 'distrusting' of me and my mods
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
