Old 01-06-2014, 04:33 PM   #29
Bad Habits
Bad Habits's Avatar
Drives: br zed
Originally Posted by ML View Post
I'm sure he would do anything for enough money! My car was used to proto the kit so everything was comp'd. So in retrospect;Yes, Yes I do think it is worth it.
Thx. Think this might be the first mod on my car. If the weight savings is 20+ pounds and to get rid of what should have never been there to begin with (imo) I'm good with the price. Did you sound deaden anything, notice more noise with the factory seats etc gone? Thanks for the answers.
Bad Habits is offline   Reply With Quote
Old 01-06-2014, 04:35 PM   #30
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I did, but my car is prepped for weight reduction so it was loud to begin with. It actually helps the noise issue when installed vs. nothing at all. I believe for a relatively stock vehicle, the noise wouldn't be a huge issue.
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
Bad Habits (01-06-2014)
Old 01-06-2014, 04:56 PM   #31
Bad Habits
Bad Habits's Avatar
Drives: br zed
Originally Posted by BRZTimeTrials View Post
@TheBatman, that's pretty cool! There is some NVH added with this setup. It'd be interesting to hear the difference with extra insulation.
Originally Posted by TheBatman View Post
Yeah it's $130 more though so.., trying to figure out whether it makes more sense to buy that or spend the money on some dynamat instead
I too am curious if there is more noise vs the stock interior. I priced out dynamat and other products and came to a similar price to cover only the delete but I would rather do it myself over a weekend. Personally if I go this route the only part I would sound deaden on the seat delete would be the partition from the trunk to the interior. Other than that I would do all the exposed metal I could get to.
Old 03-22-2014, 08:43 PM   #32
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any more members with this setup installed? Any comments on noise?
Old 05-01-2014, 03:50 AM   #33
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
NOW... if a molded piece of styrofoam/harder foam was available that would fill the bottom seat void that would provide excellent support for the delete base as well as ensure to deaden any sound from where the bottoms once were. That would be a nice option to see?
Old 05-01-2014, 04:30 AM   #34
CoupedUpSubie
Drives: 2013 BRZ Limited
I built my own using 3/16"(IIRC) plywood and covered it with felt. Road noise with mine isn't much over original. It also is sturdy but the idea of doing a foam insert would allow for more strength and easier integration of storage.
To anyone thinking of making their own, if you have no concern for strength buy one like this unless you are really good at working with wood.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 05-01-2014, 07:31 AM   #35
Model Citizen
Lacking brains
Drives: frz
I made my own too with plywood, wood and sub box fabric, basically just used the front seat base brackets attached to wood to hold a face plate, then created a hinge and support area at the rear attached to inner mounting points.
It makes a great storage box, cost barely anything, and even before bracing was strong enough for me (240+) to get on the center of it on hands and knees putting all weight at the middle. I've got no worries about it being strong enough to hold some wheels distributed over its surface.
Road noise did go up pretty noticeably, at a later date I may address that.
Model Citizen is offline   Reply With Quote
Old 05-01-2014, 07:46 AM   #36
CBR600RR
Drives: Raven Black
Do we have official weight saving numbers yet?
Old 08-19-2014, 05:37 AM   #37
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Bump!
Thinking of getting this (;
Carlitoz3 is offline   Reply With Quote
Old 09-30-2014, 09:38 PM   #38
Fastbrz
Drives: Wrb brz
Bump for weight results
Fastbrz is offline   Reply With Quote
Old 10-05-2014, 03:29 PM   #39
mrbbs
Drives: GT86
Any idea what the rear seat belts and mounting weighs?
mrbbs is offline   Reply With Quote
Old 10-05-2014, 05:08 PM   #40
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Yes, see this thread. Somewhere around 7 lbs. Second post.
http://www.ft86club.com/forums/showthread.php?t=42284
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
civicdrivr (10-06-2014)
Old 10-07-2014, 05:32 PM   #41
vividracing
vividracing's Avatar
Great write-up! Thank you!
vividracing is offline   Reply With Quote
Old 10-08-2014, 10:02 PM   #42
inertia
inertia's Avatar
Thank you OP for the write up.
I am trying to perform weight reduction mods as well. Airbags, sensors, rear seat-beats, and brackets will be removed. Does anyone know is what the purpose for these wires?
inertia is offline   Reply With Quote
diy, rear seat delete, weight, weight loss
Rear Seat Delete kit ender2664 Cosmetic Modification (Interior/Exterior/Lighting) 53 10-04-2017 02:10 PM
REAR SEAT DELETE SUB BOX NYCsubaruBRZ NY / NJ / CT / PA 19 01-28-2014 02:38 AM
Company in NC wants to make a rear seat delete Lonewolf Southeast 33 12-23-2013 05:44 PM
Rear seat removal? Shizuma BRZ First-Gen (2012+) -- General Topics 34 04-01-2013 03:36 AM
