06-12-2015, 04:53 AM | #29 | |
Drives: 14 Subaru BRZ Limited WRB
Hmmm so I followed the hks link from, https://www.japanparts.com/parts/detail/43635 and it lists the oil cooler as discontinued? I did a little more research on hks website and I also found this oil cooler which seems to be a updated unit. http://www.hks-power.co.jp/en/produc...oling/db/15613 Under remarks it lists that the 6AT as "not tested" I'm guessing they meant that literally and not fitment wise? Which would be the better/recommended of the two? |
06-12-2015, 09:31 AM | #30 | |
Sarcastic SOB
I also bough a 19 row oil cooler/sandwich plate as oil temps will rise dramatically after spirited driving.
The Following User Says Thank You to wbradley For This Useful Post: | 10Stars (06-12-2015) |
06-12-2015, 09:37 AM | #31 | |
I noticed you also have a 15 wrx, I'd love to hear your opinion on how your current car is now compared with your 15 wrx if you don't mind. |
06-12-2015, 09:54 AM | #32 | |
Sarcastic SOB
I got my oil cooler from CX racing for $369. US$ (quite a bit more once landed here in Canada after shipping, duties, taxes, conversion). A few parts were short shipped but when I do install it I will write a brief review. I also bough a small 7 row oil cooler to substitute for the missing one for the supercharger. The '15 WRX is a totally different animal. It's the family/commuter car with a sporty twist. Just installed an HT style front lip. If I didnt have the FR-S I am sure I'd have gone for the STI. The WRX gets MUCH better mileage that an STI and still handles great.
06-17-2015, 12:10 PM | #33 |
Sarcastic SOB
IMPORTANT QUESTION: LHD HKS owner
ANyone that has a LHD car,
The install manual I am referencing is the online PDF for the V2 but I have a V1. It is the same either way. When facing the car looking under the hood, which side of the supercharger is the traction fluid inlet and which side is the outlet? The manual is horrible for illustrating this and some photos are RHD and it is unclear. I recently added in a traction oil cooler and filter which were missing from the unit I bought used. The oil appeared to be moving in the reservoir normally. Took the car out for a test run and after a few minutes there was a high pitched sound and the supercharger seized, stopping the engine. I have removed the belt from the pulley and I cannot rotate the pulley manually at all in the proper direction or otherwise. The car cannot be started as there is so much resistance on the belt it cranks literally inches. I probably killed the supercharger and need to confirm I had the inlet/outlet reversed. Once confirmed, next step will be to try and find someone who can open the supercharger once removed and if repairable, rebuild it. Otherwise I will need a new blower and who knows what that will cost me. Any idea if this is rebuidable if not mortally damaged helpful as well.
06-17-2015, 12:50 PM | #34 |
Drives: White brz series blue
I was wondering what this kit sounds like, is there a supercharger whine to it while driving?
06-17-2015, 04:04 PM | #35 |
Drives: Toyota Frs
Is this kit CARB legal?
Thanks |
06-19-2015, 12:33 PM | #36 |
Drives: 2013 FR-S, HKS V2 S/C
wbradley: sorry to hear! with the s/c mounted, the oil pump inlet is on the lower right-hand side of the drive. The oil pump outlet is on the lower left-hand side. The picture in the manual isn't the greatest, I'll agree, but the plumbing layout is accurate.
HKS does offer some service parts: http://www.hks-power.co.jp/en/produc...ch/product/727 But from your description, unfortunately you'll probably require a new s/c. Kckc1: the s/c doesn't have a traditional whine like a roots type blower, mostly due to HKS' unique traction-drive system. We've run ours with a Racing Suction filter and through the stock air box and with the RS filter, you could hear a little "swissssh" from the intake air, but no whine. Through the stock air box you can hardly tell it's there. surfuxalot: No. Not yet anyway. |
06-19-2015, 01:14 PM | #37 | |
Drives: Scion FRS
just curious as to what's the difference between the 2 types of traction oil? 12002-AK029 12002-AK030 and which one is included in the V2 kit? Cheers, |
06-19-2015, 02:05 PM | #38 |
AK029 is included with the kit and should be fine for 97.2% of the users in the USA.
AK030 is for cold weather use only [-20C / -4F]. |
06-19-2015, 08:17 PM | #39 | |
Sarcastic SOB
06-20-2015, 08:32 PM | #40 |
Drives: Not a FRS for now
Hello, I'm just curious if anyone has dropped a HKS Supercharger into an automatic?
06-24-2015, 09:24 PM | #41 |
Touge worship
Drives: Forester STi SG9
Its been done numerous times here in Japan, some of them are garage race cars, one of them I know is a 2.1 HKS stroked Supercharged AT, it doesn't offer as much power as the manual, but it works perfectly !!!
06-24-2015, 09:35 PM | #42 | |
Touge worship
Centrifuge Superchargers, whoever build them, don't whine ... they, at the best, emit a sound similar to turbochargers, just much quieter. HKS engineered their unit a long time ago based on Rotrex design, and revised it from ground to make it more reliable and efficient. Better educate people with the right information, not just some marketing fairy-tales, and once again, i love HKS. |
The Following User Says Thank You to HaDDeS For This Useful Post: | CxG (03-17-2016) |
Similar Threads | ||||
Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4306 | 04-18-2024 06:23 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
