Old 12-20-2015, 03:24 PM   #29
vramsaran
Drives: BRZ Limited WR blue
EVANS WATERLESS COOLANT ...
Do it once and not have to worry about it ever again. Well aside from checking coolant level in overflow tank
vramsaran is offline   Reply With Quote
Old 03-15-2017, 03:44 AM   #30
reeves
Originally Posted by GrimmSpeed View Post
B.) Changing your coolant
1) Safely lift and support the vehicle. Refer to owner’s manual for preferred method.
Didn't see anyone answer this, but when you lift up the car to drain the coolant, does the car still have to be leveled to properly drain all the coolant out? Or is it fine to just jack up the front end?
reeves is offline   Reply With Quote
Old 03-15-2017, 11:50 AM   #31
stevesnj
stevesnj's Avatar
Here's what the repair manual says... I suspect the steps assume the vehicle is on a lift lifted evenly
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
KalbiCool88 (03-16-2017), reeves (03-15-2017)
Old 03-16-2017, 05:40 PM   #32
ysu
Drives: Toyota 86 GTS Auto
I'm not sure - but I can tell you about when I've replaced my radiator.
Car up on jack stands, level, system fully drained by the described method.
Then as I've removed the lower radiator hose, quite a bit of extra fluid came out (half a liter maybe).
Maybe the car would drain better if slightly tilted towards the front-right. Maybe.
Or maybe it does not matter much, unless you're changing to some magical fluid that requires a full flushing of the system.
If you jack the front only, you may get a lot more fluid left in the system. Or not. You can always try.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
The Following 3 Users Say Thank You to ysu For This Useful Post:
CockpitCruiser (11-15-2021), reeves (03-18-2017), stevesnj (03-16-2017)
Old 03-18-2017, 05:14 PM   #33
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I take it to replace all of the coolant you need 7.2liters (for manual trans) or 2 gallons? I should buy 2 gallons then, yes?
ajcarson11 is offline   Reply With Quote
Old 03-23-2017, 07:00 AM   #34
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Yes, two gallons. Napa sells Pentofrost coolant that's usually cheaper than the branded stuff. P/N AIC 8115207
Trueweltall is offline   Reply With Quote
Old 03-23-2017, 04:42 PM   #35
ajcarson11
Thanks for the tip! Does Pentofrost meet the same quality standards as the Subaru Blue?
I imagine that there are several coolants that are fine to use -- but I don't see a general consensus on what can be used outside of Subaru Blue. It's $60 for two gallons (of which I'll gladly pay) but if I can save a few dollars for a coolant that is of the same quality I'd rather do that.
Thanks!
Old 03-23-2017, 10:14 PM   #36
Trueweltall
Yes, it meets the same quality standard.
http://www.pentosin.net/specsheets/Pentofrost_A3.pdf
I suggest getting something like the Uview Airlift tool to make the job easy as cake. You can check the system for leaks and then fill it with ease without worrying about air pockets. (just make sure you clamp the overflow tank hose when you do this or else it will show that you have a leak)
Old 12-16-2018, 10:39 AM   #37
maicolp
Drives: toyota gt86 1st edition
What about sucking it off with a pump from the top??
maicolp is offline   Reply With Quote
Old 02-13-2019, 02:09 PM   #38
Silverz
Drives: Black frs
So if you only got 5 quarts out, what did you do wrong?
Was I suppose to unscrew the bleeder screw to get the rest out?
Silverz is offline   Reply With Quote
Old 04-10-2023, 07:47 AM   #39
mausr
Drives: GT86
My question would be the same(ish).
Here on the other side of the pond, Subaru blue is unobtanium even at Subaru dealerships, however, Toyota sells the blue coolant in one liter bottles. Price is quite high, thus I would like to know how many bottles I need to buy.
In my experience, the OEM provided coolant quantity refers to the full amount of coolant and such amount is not necessary for coolant change.
Does anybody measured the actual amount was necessary during the coolant change?
mausr is offline   Reply With Quote
Old 05-29-2023, 08:15 AM   #40
mausr
Drives: GT86
Coolant change has been done: 5 liters were more than enough.
The Following User Says Thank You to mausr For This Useful Post:
Wally86 (05-30-2023)
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Changing Premium to Limited? zygrene BRZ First-Gen (2012+) -- General Topics 32 10-09-2012 11:58 AM
Checking out your own car Bu-Tang Scion FR-S / Toyota 86 GT86 General Forum 18 06-11-2012 10:41 PM
Mixed day today checking out my DGM Phaedrus29 BRZ First-Gen (2012+) -- General Topics 61 06-03-2012 11:30 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
