08-24-2021, 02:47 PM | #4229 |
The Stig's African Cousin
Drives: 2014 wrb brz
I boosted it last year. So roughly 12 to 13k miles.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
The Following User Says Thank You to brandonblt2 For This Useful Post: | BrahmaBull1990 (08-24-2021) |
08-24-2021, 03:12 PM | #4230 | |
Yelp guess I'll be buying an O2 sensor then and checking for any exhautst leaks. Good thing is they're not too bad at about $100 on rockauto.
08-26-2021, 03:41 PM | #4231 | |
Drives: 2015 Scion FR-S
VVT Enable Feature – BRZ/FRS/BRZ Platform We have implemented a triple check engine light blink when the VVT (variable valve timing) is not enabled. This is to inform you that the VVT is not active yet and to not drive hard until this stops. Granted that doesn't really help with your P0172, but might explain the blinking. |
The Following User Says Thank You to JGBtypeR For This Useful Post: | brandonblt2 (08-27-2021) |
08-27-2021, 08:36 AM | #4232 | |
I did get around to changing my O2 sensor. Car seems to be running better but I haven't put any real miles on it yet. Hopefully this solved my issues. You can see I really need to change my O2 sensor this is the old after 175k miles vs the new lol.
The Following User Says Thank You to brandonblt2 For This Useful Post: | BrahmaBull1990 (08-27-2021) |
08-27-2021, 10:35 AM | #4233 |
Howdy
Drives: 2020 BRZ PP
That sensor is cooked! Are you running a rich tune?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
08-27-2021, 03:34 PM | #4234 |
Yea I'm catless, plus I believe my o2 sensor might have been telling my engine to dump more fuel also.
08-27-2021, 08:41 PM | #4235 |
Drives: 2015 FR-S
Is this the primary O2 before the cat?
08-28-2021, 07:20 AM | #4236 |
Yup.
And it turns out the O2 sensor was not the fix but instead I had a single unclamped vacuum line -_- The vaccum line would expand due to heat and leak air once the engine warmed up. Which explains why the problem seemed to pop up intermittenly but what was actually happening is during the night when the engine sat the rubber would shrink due to the cold. So the car ran better at night and in the morning versus it running like crap mid day when temps were high. CEL is now off and car seems to no longer be running rich. Thanks everyone who offered solutions.
The Following 5 Users Say Thank You to brandonblt2 For This Useful Post: | Aztec (08-29-2021), B T (08-30-2021), BrahmaBull1990 (08-29-2021), CallmeDave (09-02-2021), FrickingReallySlow (08-28-2021) |
08-28-2021, 12:28 PM | #4237 | |
Drives: 2015 FR-S
Wow, great troubleshooting. Guess O2 sensors can last a long time even covered in soot
Which vacuum line was it btw? did you remember fiddling with it before Quote:
The Following User Says Thank You to FrickingReallySlow For This Useful Post: | brandonblt2 (08-28-2021) |
08-28-2021, 02:16 PM | #4238 |
The line that runs from my catch can to the supercharger. To connect the different sized hoses I have a connector. I had one side clamped but not the other. I hadn't missed with the line before but I did add a oil cooler line near it so the temps near it increased quite a bit.
The Following User Says Thank You to brandonblt2 For This Useful Post: | FrickingReallySlow (09-02-2021) |
08-29-2021, 01:51 PM | #4239 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread |
The Following User Says Thank You to Aztec For This Useful Post: | brandonblt2 (08-30-2021) |
09-02-2021, 08:12 AM | #4240 |
Drives: 13 BRZ, 07 WRX
So I replaced the bypass valve but now Im having other issues, basically rough idle and it threw a P0172 code... also noticed while not in gear if I blip the throttle it seems to hesitate a bit rev to 2k and choke a little bit...
So far when Im driving down the road its seems ok. I took a log while driving in to work this morning, could one of you guys that knows how to read this take a look? Thanks Errr also how do I share a log file.
13 BRZ Premium. 07 WRX.
09-02-2021, 11:50 AM | #4241 |
Have you confirmed your bypass valve opens as it should? Sounds like maybe something wasn't fully connected after installing the new valve.
The Following User Says Thank You to B T For This Useful Post: | CallmeDave (09-03-2021) |
09-02-2021, 12:05 PM | #4242 | |
Howdy
Drives: 2020 BRZ PP
Accepts .CSV form
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post: | B T (09-02-2021), CallmeDave (09-03-2021) |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
