06-19-2018, 11:03 AM | #4593 |
Drives: 14' Raven M/T - 02' is300
06-19-2018, 11:47 AM | #4595 |
pessimistic skeptic
Catless header will probably cause CEL. You generally need special tune for an aftermarket header to take advantage of the performance benefits. I would stick with the stock header with JR carb tune which is an excellent tune anyway for the stock engine.
06-20-2018, 09:33 AM | #4596 | |
Drives: 2013 Subaru BRZ Premium
Sent from my XT1650 using Tapatalk |
06-26-2018, 10:24 AM | #4597 | ||
Drives: 2015 FRS
Wanted to touch base on these posts I made. I ended up taking it to TRL to have some inserts installed as well as a new tune/FF kit. I want to say I'm not 100% positive but I believe a tune fixed the problem. Seems to run flawless at any point of the RPM band after a new FNG from delicious |
06-26-2018, 12:07 PM | #4598 | |
06-26-2018, 10:22 PM | #4599 |
Drives: Fast track beast
Anyone running water/meth with their kit?
Sent from my SM-G965W using Tapatalk |
07-03-2018, 05:16 PM | #4600 |
2013 Subaru BRZ with Jackson Supercharger Noise
Hey guys, hope your all doing good! I'm new around here and I just bought a new to me 2013 Subaru BRZ with 30K miles. I'm loving the car so far. But I am having a bit of an issue/worry. The Jackson Racing C38 supercharger is making a fairly loud whining noise. I had the car looked at by a shop that have personally installed Jackson Superchargers before and they claim that it's fine. As time goes on however, I would really like to get some opinions from you guys who have them specifically on your motors. The kit has only been on for about 15k miles and a little under 2 years. I am planning on changing the oil soon and see if that helps since it's part of the maintenance for it. The belt seems ok and it seems to operate properly in the sense of making power and what not. It has a Delicious Tune as well. The only real worry for me is the noise in the clip. Any help would be much appreciated. I'm completely new to superchargers, I've only ever had turbos on past cars. So forgive me if this is a newbie question. I just only remember roots style superchargers making a lot of noise. Thanks guys! Glad to be in the community!
07-03-2018, 05:37 PM | #4601 |
Video is low quality, but sounds normal to me.
07-03-2018, 05:59 PM | #4602 |
Yeah, same here, sounds perfectly fine.
So no one has any experience with water/meth kits? I don't have easy access to E85 anymore, which is why I'm considering it. Sent from my SM-G965W using Tapatalk |
07-03-2018, 06:11 PM | #4603 | |
Drives: 2015 Scion FR-S 1968 Camaro BB402
These units are pretty loud at idle, the Rotrex dev manual says you’ll get a shrill suction noise with an open element filter (such as the K&N one provided by JR). It’s normal. Mine sounds the same, but I didn’t hear whining in the video. ________ ~refer to username~ |
07-03-2018, 06:33 PM | #4604 |
Good Job Subaru!
Drives: '17 BRZ, '24 CX-50
Considering whether or not I should pick up ACE A350's and a tune or just wait a little bit and save up for a C38 kit once the CARB tune is available on my 2017.
Anyone have issues with the kit on the CARB tune for a daily? I'd love more power but want to do it reliably as possible. Are there any considerations to be made when winter driving in cold temperatures with the JRSC, from an oiling perspective or otherwise? (Temps can hit as low as -25°C in the winter in the GTA).
07-03-2018, 06:58 PM | #4605 |
Drives: Subaru BRZ
Buying a used C30 kit - what to look out for? Any way to verify the kit is complete (is there a comprehensive parts list?)
I can't seem to find one in the manual
'16 SWP BRZ
07-03-2018, 07:33 PM | #4606 |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
