Old 03-27-2014, 09:11 PM   #463
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by shiv@vishnu View Post
Hi guys,
50% done with testing. Should have the lasts bit wrapped up on Monday since tomorrow is my day off
Will post the following Crawford Power Block dyno results:
Stock tune VS custom tuned
NA full-bolt on VS ESC w/full bolt on
Cheers,
Shiv
I think you deserve a day off
86-tundra is offline   Reply With Quote
Old 03-27-2014, 09:23 PM   #464
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Cheers,
Shiv
To make sure I understood.
Stock car + blocks vs stock car + blocks + tune?
If so, could you lay down a bone stock baseline vs bone stock stage1 as well for comparison?
Would show the progression/value nicely.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-27-2014, 09:30 PM   #465
akyp
Drives: 2012 86
Originally Posted by Boxer486 View Post
Thx. I can say these will not fit under a Hotchkis strut bar. At least for sure with the engine cover on.
I just took a look at my engine bay. It probably won't fit the TRD CF strut tower bar unless the sound tube is removed.
akyp is offline   Reply With Quote
Old 03-27-2014, 09:35 PM   #466
Luis_GT
You should get rid of the sound tube anyway...
The Following 6 Users Say Thank You to Luis_GT For This Useful Post:
86-tundra (03-27-2014), ck-GT86 (03-27-2014), DAEMANO (03-28-2014), FR-Slide (03-28-2014), OICU812 (03-28-2014), Tim_Asphalt_FRS (03-28-2014)
Old 03-28-2014, 03:01 PM   #467
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
@Crawford Performance @shiv@vishnu
Excuse the ignorance, but would using the BPBs (aka lengthening the IM runners) = a decrease in real world gas mileage?
leicaboss is offline   Reply With Quote
Old 03-28-2014, 03:53 PM   #468
jeebus
Drives: 2015 Mustang GT (on order)
I don't see any reason why except in the area of the powerband where more power is made.
jeebus is offline   Reply With Quote
Old 03-28-2014, 04:47 PM   #469
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Weight
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
P@ul (03-28-2014), wparsons (03-28-2014)
Old 03-28-2014, 04:49 PM   #470
leicaboss
Coffee Snob
leicaboss's Avatar
Haha, well I was asking because in other applications - changing the intake manifold completely (for a perf. oriented one) would often result in a decrease in gas mileage.
Old 03-28-2014, 05:20 PM   #471
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I will let you know in about a week.
Will drive to Chuckwalla
Track day
Drive home
Should be ~400+ miles of data to work off of.
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
Crawford Performance (03-28-2014), DAEMANO (03-28-2014), leicaboss (03-28-2014), nycbrz (03-28-2014)
Old 03-28-2014, 05:25 PM   #472
leicaboss
Coffee Snob
leicaboss's Avatar
Track day
Drive home
-alex
Alex thank you. Your brake build looks super good btw.
The Following User Says Thank You to leicaboss For This Useful Post:
mav1178 (04-07-2014)
Old 03-28-2014, 06:39 PM   #473
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Omg. I keep buying parts for my car. This forum is toxic!
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following 6 Users Say Thank You to Boofneenee For This Useful Post:
makinen (03-28-2014), Mathewgzlz (03-28-2014), MikeM7 (02-01-2015), Sojhinn (03-28-2014), StormMcCloud (03-28-2014), Yobiwan (03-28-2014)
Old 03-28-2014, 07:16 PM   #474
jupillam
jupillam's Avatar
Drives: White out Scion Frs
Its so call "cancerous"
jupillam is offline   Reply With Quote
Old 03-28-2014, 08:29 PM   #475
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
when people talking about this product "holding up" after a tune. Are they trying to imply that the ecu will adjust and the gains will no longer be there? Are they saying the ECU will learn out the gains?
FRS
Old 03-28-2014, 10:16 PM   #476
nelsmar
That typically happens if your are throwing air across the maf sensor differently than stock skewing the AFR and giving a lean mixture. This is why a number of people asked for AFR plots. This is why intakes "lose" power over time because eventually the ECU retunes tot he correct AFR. I am wondering how much power will stay after adjusting the cam profiles, and not so much "learning". I'll have dynos tomorrow, dyno is at 10:30AM.
My flickr - Canibeat
Local magazine scout
The Following 8 Users Say Thank You to nelsmar For This Useful Post:
akyp (03-28-2014), Boofneenee (03-28-2014), Craig (03-28-2014), FrsDuke (03-28-2014), Luis_GT (03-28-2014), Mike86 (03-29-2014), mxsled (03-28-2014), nycbrz (03-28-2014)
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
