01-11-2023, 11:48 AM | #4761 |
Drives: 2016 Scion FRS Release Series 2#439
Is there any chance that the butterfly inside the S/C was gapped incorrectly before the installation or has gone out of adjustment (loose locknut) since the install?.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
01-11-2023, 07:37 PM | #4762 | |
Drives: 2015 FRS
Yes because I replaced the old faulty bypass actuator with a new one before I installed it. I followed the how to the best I could, but since I've never done one before I may have done it wrong. I adjusted it until the feeler gauge felt just right to me. Do you thing it's too open or too closed? |
01-12-2023, 10:45 AM | #4763 | |
Perhaps your tuner, or someone more experienced here can chime in.
01-12-2023, 08:22 PM | #4764 | |
The review of the log is free; if he thinks it can be made to run proper, then he'll let you know to purchase a tune. |
The Following User Says Thank You to CSG Mike For This Useful Post: | B T (01-13-2023) |
01-13-2023, 02:28 AM | #4765 |
Drives: brz 2017 hksv2
could also post here datazap log, the forum can also do reviews for free
The Following User Says Thank You to tomm.brz For This Useful Post: | Teseo (01-19-2023) |
01-13-2023, 10:20 AM | #4766 |
Drives: 86 (FR-S)
I’m interested in this as well. I don’t have the problem to the extent described, but I do get some occasional idle bounce. It seems to happen only after the car has been run for a while, is turned off, then started again shortly after while still warm.
01-14-2023, 06:44 AM | #4767 | |
So that creates the instability in rpm and afr With stock tune it s less noticeable because idle rpm after startup are usually higher than when tuned aftermarket you can ignore it if it doesnt cause any relevant problem to your drive |
01-16-2023, 04:50 PM | #4768 | |
Drives: 86 (FR-S)
The Following User Says Thank You to Jeff86 For This Useful Post: | tomm.brz (01-20-2023) |
01-20-2023, 08:56 PM | #4769 |
Hi, has anyone replaced the Edelbrock coolant reservoir from V2 version to the latest "universal" one?
https://superchargersonline.com/prod...ler-reservoir/ My V2 has been leaking and they said to replace it with above one. But design/size is quite different so need to figure out the brackets/tubes myself. Hoping someone already has experience with this. |
02-06-2023, 08:54 PM | #4770 | |
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Is the tank itself that's leaking, or the cap ? I seem to recall a leaking cap being mentioned by others. A quick search of this thread might help.
The best thing about the future is that it comes one day (and curve) at a time.
02-15-2023, 11:10 AM | #4771 | |
Drives: 2020 Subaru BRZ (Edelbrock SC)
Can you replace the gaskets by undoing the bolts, lifting the SC up with a few people, and sliding new gaskets underneath? I really don't want to disconnect the whole assembly... |
02-16-2023, 10:16 AM | #4772 | |
I believe I simply removed the six bolts, slid a pry bar between the left side runners, lifted the unit and placed a 1 1/8” wood dowl between to support it. After repairing the slave connection leak I was able to reach my fingers under the manifold to confirm the gasket was correctly in place before dropping the unit back into the heads. A successful solo repair.
02-16-2023, 10:40 AM | #4773 | |
I think it may just be the intake, ECU bracket, and injectors I would need to remove before the 6 bolts. I haven't confirmed or felt the vacuum leak there yet but I rechecked all my hoses and couldn't feel anything leaking... So I'm considering just replacing the gaskets hoping that was the issue. |
02-16-2023, 08:47 PM | #4774 | |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
