07-29-2023, 07:17 PM | #4873 |
Drives: 2013 FR-S Series 10
return it to stock and sell it. i sold my 2013 with 75k for almost 20k on carvana. the used car market is a sick joke and has been for a few years
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
07-30-2023, 08:36 PM | #4874 |
Drives: 13 BRZ, 07 WRX
I’ve been getting some hesitation and stumbling only when I tip in the throttle a bit more than normal like trying to take off at a light fast. No other issues. It stumbles and then goes…
13 BRZ Premium. 07 WRX.
07-31-2023, 03:06 PM | #4875 | |
1st86 Driver!
By the way, the current offer from Carvana on mine (2013, 221,000 miles) is $545. A year ago it was around $5,000 with 205,000 miles on it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | B T (08-01-2023) |
08-01-2023, 11:03 AM | #4876 |
Drives: 2016 BRZ Hikari
So a quick update for anybody running Gates RPM belts. I’ve been searching for one for a while and after speaking with someone directly at Gates, they’ve discontinued that line. The HD line is still being manufactured but is heavily backordered at the moment.
Anybody else have any belt recommendations? I’ve been running the Continental Elite 060995 and am having a rib sheared off about once a track day. I’m going to try an 060990 which is a bit shorter to see, but what I’m seeing happen is under heavy load the tensioner is pushing the stretched belt up into the pulley above…
2016 BRZ Hikari Edition @BRZHikari1 Build Thread: http://www.ft86club.com/forums/showthread.php?t=107326 |
08-01-2023, 11:44 AM | #4877 | |
Wes
Instagram: @gt86ws
08-01-2023, 01:21 PM | #4878 | |
08-01-2023, 01:27 PM | #4879 |
Have one on the way already as well, hopefully that helps. Glad to hear you haven’t had any issues
08-02-2023, 09:11 PM | #4880 |
Drives: GR86 (Sold) -> C6 GS Edelbrock SCed
How old are your spark plugs? If you are running a PD supercharger, you will need to replace spark plugs quite often, as superchargers are known to use up spark plugs much faster than NA cars. Some people I know who own FI cars, replace spark plugs once every year, as faulty spark plugs can really make FI cars lose power and run poorly.
08-05-2023, 11:59 AM | #4881 |
Drives: 2020 Subaru BRZ (Edelbrock SC)
Reposting for visibility:
I have an Edelbrock E85 BRZ and recently on the highway, the Shaft Select Lever Pin sheared off and misaligned my shifter H pattern. Here are photos: https://imgur.com/a/aVicQQL I drove the car again today and at high rpm's and the entire shifter rotated on me. Freaked me out... It feels closer to normal now but still in an odd spot where you can accidently shift into reverse Did something internal break? I am concerned because I thought the transmission could handle the SC/E85 combo. I wanted to go to an 8/6 meet & drive tomorrow but now I'm feeling sketched out that I broke something major. Please help!! |
08-06-2023, 06:19 PM | #4882 |
Drives: 2016 Scion FRS Release Series 2#439
Likely only damaged at the shifter base. Only pulling out the console and shifter will tell the story. But if it’s acting as funky as you say I’d not dare drive before resolution.
Good luck! The
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
08-12-2023, 12:53 PM | #4883 |
Drives: 2017 BRZ Limited, White
2017 BRZ with idle problems (CEL and Traction)
I've got a 2017 BRZ. Put the Edelbrock supercharger in July 2019. Used their tune with no prob.
Tried the Delicious tune. Also no prob. UNTIL about 2 years ago. At some point after I reflash the ECU -- could be 10 minutes, could be 2-3 months -- these happen: * Car won't hold an idle RPM -- goes between 500-1000 * Throttle response is crazy in 1st -- sometimes it's non-responsive, sometimes RPM drops as I add throttle. I need to rev the car to about 2k RPM to start moving * At some point after that, the CEL and Traction lights come on Reflashing temporarily solves the problem (with either tune). As does pulling the battery for 10 minutes. And, the problem will be intermittent... some drives are fine, then 5 minutes later the throttle response is totally out of whack. My usual mechanic spent a month with the car as was stumped. ANY suggestions? Thanks. Last edited by xeroshoes; 08-13-2023 at 04:29 PM. |
08-12-2023, 02:21 PM | #4884 | |
Drives: 2016 BRZ Hyper.Blue
Sent from my Pixel 7 Pro using Tapatalk |
08-14-2023, 12:16 PM | #4885 | |
I noticed even putting the belt back on, the spring on the new tensioner was much much stronger.
The Following User Says Thank You to Hikari1 For This Useful Post: | B T (08-15-2023) |
08-14-2023, 12:17 PM | #4886 |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
