Old 07-16-2012, 10:00 AM   #43
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by Nitro22 View Post
I had the same issue, but I was able to blow it ALL out with an air nozzle & compressor.
And if that doesnt work...put water in and vacuum out particles. Seal and stick tube to vacuum and place into housing and leave on for some time to remove condensation.
Sent from my SCH-I800 using Tapatalk 2
xcelir8brz is offline   Reply With Quote
Old 07-16-2012, 10:06 AM   #44
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Something so simple, yet genius. I wish I had gone this route!
Did any of you BRZ guys also have a hell of a time getting the light fixture out of the bumper? I ended up taking all bolts and plastic pop rivets out of the bottom diffuser and still had to flex the bumper a lot to get that thing out of there. I was afraid I was on the verge of breaking the bumper!
cobrabyte is offline   Reply With Quote
Old 07-16-2012, 10:12 AM   #45
xcelir8brz
Yeah sort of. It took patience.
Old 07-16-2012, 12:35 PM   #46
ZILLA
BRZ #575
ZILLA's Avatar
Drives: 2013 BRZ #575
Originally Posted by W2 View Post
One key thing to note, the housing for the red fog light has 2 lenses. When you drill out the holes be careful not to get the debris in between the outer and inner lenses. If you do you'll have to bake the light to separate everything and clean. I found out the hard way.
Shop vac worked fine for me.
ZILLA
BRZ #575 SWP Limited
18x8" Drag DR-31 +48 | 235/40/18 | 6000K HID Low/High | Wrapped All Red Tail Lights | Rear Fog + Brake Light Combo Mod [Video]
ZILLA is offline   Reply With Quote
Old 08-11-2012, 01:51 PM   #47
cto424
Zilla, any condensation issues with the sockets that you used?
cto424 is offline   Reply With Quote
Old 09-04-2012, 07:13 PM   #48
ZILLA
BRZ #575
ZILLA's Avatar
none.
ZILLA
Old 09-05-2012, 03:45 AM   #49
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
hi Zilla, when u said "I ran the (+) wire from each 194 bulb to the driver side tail light harness. The green wire is the regular tail light. The red wire is the brake light. The ground wires went to the OEM ground location in the trunk.
can you tell me where that is?
thanks
Zardoman is offline   Reply With Quote
Old 09-05-2012, 04:59 PM   #50
ICEBONEZ
ICEBONEZ's Avatar
Drives: '13 WRB 6MT BRZ Limited
I finally got this done. Took a bit of time to get it wired properly -- I wanted it to look like it came from the factory.
I also integrated the blinking module.
Here's a link to video:
What is the blinking module part? Thanks!
2013 BRZ Limited WRB
ICEBONEZ is offline   Reply With Quote
Old 09-05-2012, 05:16 PM   #51
cobrabyte
cobrabyte's Avatar
I used the following brake-blinking module:
Brake Attention Flasher Module
Old 09-05-2012, 05:43 PM   #52
ICEBONEZ
ICEBONEZ's Avatar
Thanks for that! Since I liked your vid and setup so much, might as well ask which bulbs you used. I plan to do the same thing.
Old 09-05-2012, 05:54 PM   #53
cobrabyte
cobrabyte's Avatar
I used the LEDs that you can purchase at AutoZone/O'reilly's. Thought they were referenced in ZILLA's original parts list.
Old 09-05-2012, 07:15 PM   #54
Zardoman
Zardoman's Avatar
anyone know where the OEM ground is at? or just anywhere on the car body??
thanks!
Old 09-05-2012, 11:20 PM   #55
Zardoman
Zardoman's Avatar
I got mine done!!!
Thx zilla!!
Old 09-08-2012, 05:47 PM   #56
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
me want!
TOTO_86 is offline   Reply With Quote
custom, fog, fog light, foglight, rear fog light
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) -- General Topics 21 11-23-2015 03:23 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) -- General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
