Old 08-23-2012, 01:27 AM   #43
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
all requested links added! thanks guys!
imravenit is offline   Reply With Quote
The Following User Says Thank You to imravenit For This Useful Post:
Sigh-on-Rice (08-23-2012)
Old 08-24-2012, 07:38 AM   #44
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
BRZ Nav unit fix available
There is a fix available for the poor ability of the BRZ Nav unit that comes standard in the US to get the car's GPS location:
http://www.ft86club.com/forums/showt...d=1#post399807
DSPographer is offline   Reply With Quote
Old 08-28-2012, 09:21 PM   #45
egraphic
Drives: Blue Scion FR-S
Originally Posted by imravenit View Post
OUR BELOVED FRS/BRZ LISTS OF PROBLEMS!! SO I THOUGHT I'D MAKE A COMPILATION OF THE PROBLEMS THAT THIS CAR IS HAVING AT THE MOMENT!! SO MAYBE WE CAN EASILY TRACK UPDATES TO ANY SOLUTIONS OR HOW TO FIX THE PROBLEMS STATED BELOW!!
CHIRPING (CRICKET) NOISE
http://www.ft86club.com/forums/showthread.php?t=9836
http://www.ft86club.com/forums/showthread.php?t=12422
http://www.ft86club.com/forums/showthread.php?t=8678
http://www.ft86club.com/forums/showthread.php?t=9837
http://www.ft86club.com/forums/showthread.php?t=9686
TRUNK WONT OPEN
http://www.ft86club.com/forums/showthread.php?t=12024
POWER LOSS AFTER GAS FILL UP
http://www.ft86club.com/forums/showthread.php?t=12899
RPM FLUCTUATION
http://www.ft86club.com/forums/showthread.php?t=12479
FLYWHEEL RATTLE
http://www.ft86club.com/forums/showthread.php?t=12429
P0328 ENGINE CODE
http://www.ft86club.com/forums/showthread.php?t=11427
RATTLE/SQUEAKS IN BRZ
http://www.ft86club.com/forums/showthread.php?t=7181
RESONANCE AT 70MPH
http://www.ft86club.com/forums/showthread.php?t=10986
REAR DECK NOISES
http://www.ft86club.com/forums/showthread.php?t=13451
VIBRATING SHIFTER
http://www.ft86club.com/forums/showthread.php?t=11503
PASSENGER'S AUTO WINDOW SCROLL
http://www.ft86club.com/forums/showthread.php?t=11702
TPMS LIGHT ON & OFF
http://www.ft86club.com/forums/showthread.php?t=10602
RATTLING IN CERTAIN GEARS AT LOW RPM
http://www.ft86club.com/forums/showthread.php?t=8112
BRZ NAV SYSTEM GPS SIGNAL ISSUE
http://www.ft86club.com/forums/showthread.php?t=9157
DEALERS FORGETS GROMMET CAUSES WATER
http://www.ft86club.com/forums/showthread.php?t=11523
WINDOW SQUEAKING
http://www.ft86club.com/forums/showt...hlight=problem
CEL ON AFTER 2K MILES
http://www.ft86club.com/forums/showthread.php?t=10069
STARTING (TURNING OVER)
http://www.ft86club.com/forums/showthread.php?t=7453
IDLE ISSUE
http://www.ft86club.com/forums/showthread.php?t=8285
CLUTCH ENGAGEMENT
http://www.ft86club.com/forums/showthread.php?t=11266
DOWNSHIFTING RATTLE
http://www.ft86club.com/forums/showthread.php?t=11479
INTERIOR RATTLE
http://www.ft86club.com/forums/showthread.php?t=10868
THUD IN REAR WHEN SHIFTING
http://www.ft86club.com/forums/showthread.php?t=11275
http://www.ft86club.com/forums/showt...t=transmission
http://www.ft86club.com/forums/showthread.php?t=8841
RATTLING NOISE UNDER THE HOOD
http://www.ft86club.com/forums/showthread.php?t=8344
STRONG ODOR ON HIGH RPM'S
http://www.ft86club.com/forums/showthread.php?t=10817
TAILIGHTS CONDENSATION (MOISTURE)
http://www.ft86club.com/forums/showt...ighlight=water
SYNCHROS
TAPPING SOUND ABOVE 70 MPH
http://www.ft86club.com/forums/showthread.php?t=11080
I KNOW THERES STILL A DOZEN I HAVE LEFT OUT BUT I'LL CONTINUE TO UPDATE THIS THREAD IF THERES ANY NEW PROBLEM!
I would add this as a "dealer oversight" (not a "problem" - all FR-S's seem to ship with the stereo set to the default setting of "TC" vs. "FR-S". As a result, the stereo sounds terrible, underpowered and like it's not using all eight speakers. All, the front-rear balance is set to 100% front.
I don't have my manual (car's in the shop for the CEL issue) but I seem to recall the setting information is on page 53. May be mistaken, though. So, this one is user-correctable.
egraphic is offline   Reply With Quote
Old 09-03-2012, 02:35 PM   #46
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by ruskymx View Post
Positive. I added arrows to the pictures to show where the line is that I'm talking about. It definitely in the paint and not shadows or anything. It's visible when there is direct sunlight on that side of the car. As you can see in the pictures, it doesn't follow the body lines and is a little wavy. I'll see if I can get an HD video of it if the sun ever comes back out today.
Here's bigger pics with no thumbnails
Ruskymx
QC inspectors probably caught a paint imperfection (crater, dust, etc.) during final inspection and diverted your car off the assembly line for a spot fix. There are standby painters who even out imperfections and manually respray. This is how it was done when I worked at the Toyota NUMMI plant's paint shop. You could complain to the dealer who sold you the car and they'd have a local body shop repaint it or you can insist on a car replacement which would need escalation to the regional/corporate level (similar to what the user Tanuki did regarding a body weld but your case might be more difficult to justify since it's not frame/structure related).
Old 09-10-2012, 11:55 AM   #47
ZDRxHz
Drives: 2013 Scion FR-S Raven Black Pearl
Shift knob top coming loose on my car after 5k.
ZDRxHz is offline   Reply With Quote
Old 09-11-2012, 04:11 PM   #48
hyperpunx
Has anyone experienced this issue?
I have an Automatic, and when gunning the car from either a standstill or from 25-35mph, the engine sounds like it drops and then revs up (not a smooth acceleration up...) I will post a video of this later today or tomorrow... but thought I would throw it up on this forum for any thoughts off the bat.
My last 6 vin are: 705214
Thanks!
hyperpunx is offline   Reply With Quote
Old 09-11-2012, 04:35 PM   #49
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Did you tighten it? It should twist right on (and twist right off if you want to change it). Or is it loose as in the whole thing seems like it's going to fall apart?
Thanks!
Hmm, sounds like a vacuum issue. I got the idea from this thread who has something similar: http://www.ft86club.com/forums/showthread.php?t=16997
Books is offline   Reply With Quote
Old 09-11-2012, 04:40 PM   #50
Books
Books's Avatar
+1 for this too. My stereo was set to the default setting. Thankfully, I already knew about this fix when I got it and fixed it right up.
Old 09-12-2012, 01:34 PM   #51
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
I feel so fortunate to have a trouble free BRZ so far.
slizoth is offline   Reply With Quote
Old 09-14-2012, 03:08 AM   #52
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
Thanks!
That sounds similar to something described here:
I had this happen today.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 09-27-2012, 10:55 PM   #53
fistpoint
Drives: Supercharged Golf Cart
List needs to be updated to include TSB's.
fistpoint is offline   Reply With Quote
Old 10-10-2012, 11:06 PM   #54
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
You can also add fuel pump problems (CEL code P1235) to the list:http://www.ft86club.com/forums/showthread.php?t=12428
FutureFT86 is offline   Reply With Quote
Old 10-12-2012, 05:52 PM   #55
jongpau
Drives: Toyota 86 GTS Auto
Originally Posted by WTF View Post
I don't know if you guys get the same head units, but mine is doing weird stuff where sometimes the music is really faint, but calls come through loud.. Have to reboot headunit..
Conversely, sometimes the music comes through loud and the calls come through quiet.. same thing - reboot.
Weirdly enough as well, to get music playing, I have to hit 'volume up' on my iphone..
these are all just quirks, mainly with the headunit I think.
Hey fellow Aussie,
The head unit in my GTS does weird stuff too. If I happen to change music volume when GPS is just about to "say" something it seems to loose my equaliser settings and the sound goes flat. Sometimes it takes 30 minutes for the GPS to find satellites. It plays my iPod on random. When I go into settings to switch to normal play its ok until next time i start the car and its on random again.
Also hate that it always announces school zones, regardles of the time and/or day. And somehow it cant stack warnings after announcements. When its giving directions a red light camera warning will just go straight over the top of the directions. Great way to get lost
And dont you just love you cant make a call while driving unless you (illegally) use your phone to dial?
Definitely some very bad programming and weird decision making in there
>>> END RANT <<<
You say you reboot the head unit, how do you do that? I hope that may fix my random play issue
Thanks,
Paul
jongpau is offline   Reply With Quote
Old 10-26-2012, 12:57 AM   #56
Huss
Drives: 2010 civic Si
holy crap so many problems.....
Huss is offline   Reply With Quote
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 10:21 PM
Problems with detailing Nezz AUSTRALIA 23 06-28-2012 09:08 AM
Forum Problems TRD-X Site Announcements / Questions / Issues 2 05-29-2012 10:45 AM
Do you think this car is going to have some problems? Huss Scion FR-S / Toyota 86 GT86 General Forum 45 03-21-2012 01:48 PM
