Old 12-17-2012, 03:06 PM   #43
nashsnazzy
Drives: 2013 Scion FR-S White Out
That sucks about the exhaust being lower than the factory. The only other exhaust I like is the super sprint and it costs way too much.
nashsnazzy is offline   Reply With Quote
Old 12-17-2012, 03:29 PM   #44
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Already decided on putting the Borla Catback on my FR-S. Each time I see a new video it makes me want it even more. Probably be around March before I get it.
L3P47 is offline   Reply With Quote
Old 12-17-2012, 04:23 PM   #45
LIKEABOSS
LIKEABOSS's Avatar
Drives: 2013 Boss 302 & 2013 FR-S
I'm curious to the accuracy of this and will know by the end of the week when I get mine installed. Borla got on here and said that on it's project car it sat I think around a 1/2 inch lower which is a big difference. No clearance issues with the car that is also lowered.
LIKEABOSS is offline   Reply With Quote
Old 01-02-2013, 05:17 PM   #46
nashsnazzy
If it's only a 1/2" lower let me know. I would be game for that.
Old 01-02-2013, 05:38 PM   #47
PRORICAN
PRORICAN's Avatar
I didn't measure mine but it doesn't sit too low. I'm on eibach sportlines (1.4") and haven't scraped on anything yet and doesn't seem like I will.
PRORICAN is offline   Reply With Quote
Old 01-03-2013, 11:54 AM   #48
nashsnazzy
Glad to hear it @PRORICAN , I'll pick up one of these for the car I reckon.
The Following User Says Thank You to nashsnazzy For This Useful Post:
PRORICAN (01-03-2013)
Old 01-11-2013, 08:58 AM   #49
frsinpa
Drives: fr-s!
Got my Borla exhaust installed this weekend and man is it awesome. It gives the car a completely different feel without the excessive drone of some other exhausts. I am really enjoying it so far!
frsinpa is offline   Reply With Quote
The Following 3 Users Say Thank You to frsinpa For This Useful Post:
LIKEABOSS (01-15-2013), number1Tango (01-11-2013), tdoggy57 (01-11-2013)
Old 01-15-2013, 10:23 PM   #50
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
I installed a Borla today. Easiest catback I've ever done, took less than a half-hour with jack stands.
Mine does hang lower than stock, by close to two inches. Actually the lowest part is the 'under axle' loop, but the muffler itself is lower too. However, the way you adjust the tips affects how the muffler hangs.
I have mine set so I have about a finger's worth of clearance between the top of the tip and the bottom of the valence cutout. If I lowered the tips - rotated the pipe joint downward - that would cantilever the muffler up. So your ground clearance is gonna be dictated by how you adjust it. I have a bit less than 4.5 inches under the rear of the muffler, but if I was willing to point the tips down I could get about an inch back.
It sounds good. It's a little loud for my taste at high throttle positions, but the tone is proper and there's absolutely no resonance at highway speeds.
Admiral Ballsy is offline   Reply With Quote
The Following 2 Users Say Thank You to Admiral Ballsy For This Useful Post:
number1Tango (01-16-2013), tdoggy57 (01-16-2013)
Old 01-16-2013, 01:11 PM   #51
tdoggy57
tdoggy57's Avatar
Drives: Asphalt Scion FR-S
Just ordered mine, should be here by the end of the month...can't wait!!!!
tdoggy57 is offline   Reply With Quote
Old 01-16-2013, 01:19 PM   #52
Admiral Ballsy
Shorter of breath
I've seen references to the ground clearance as published by Subaru as being 4.9 inches. That must reference some other part of the car (LCAs, maybe), because the stock exhaust doesn't hang that low.
So the Borla only drops a bit less than a half inch from the overall clearance - but it does hang significantly lower than the stock exhaust. If that makes sense - the exhaust is now the lowest point on the car, and stock, it isn't.
Old 01-16-2013, 01:23 PM   #53
tdoggy57
tdoggy57's Avatar
Have you noticed any difference other than the sound? I guess it would be worth noting if you have any other performance mods also.
Old 01-16-2013, 01:50 PM   #54
Admiral Ballsy
Shorter of breath
Nope, no other modifications.
I'm not sure what you mean by other differences...nothing bad (it doesn't rattle or rub or bang on anything), anyway. I'm not expecting anything other than more sound - it's just an exhaust pipe, after all.
Old 08-20-2016, 05:15 AM   #55
JoshGT86
Drives: 2012 GT 86
This is the solution for anyone who has ground clearance issue.
JoshGT86 is offline   Reply With Quote
borla, exhaust, fr-s, scion
Magnaflow exhaust installed w/video@JRP Stav Engine, Exhaust, Transmission 37 07-13-2016 08:21 PM
Borla Cat-Back Exhaust short sound clip!!! JohnnyP Engine, Exhaust, Transmission 130 02-10-2014 03:40 AM
New! Borla cat-back for FR-S/BRZ Mach V Dan Engine, Exhaust, Bolt-Ons 9 02-06-2013 08:57 AM
***Borla Exhaust Sale*** Titanmotorsports Engine, Exhaust, Bolt-Ons 36 11-26-2012 05:42 PM
Borla Exhaust in the works DAZE752 Engine, Exhaust, Transmission 14 06-13-2012 02:27 AM
