Old 01-16-2015, 09:01 AM   #43
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Basic tech info: spring rates, rear suspension, motion ratios, and you.
If you think this is amazing from scratch just keep it like this.
Or if you want a little drop maybe yes RCE yellow can do a good job without sacrificing too much the handling.
Correct me if am wrong but I think RCE yellow make the car feel more neutral vs OEM.
This is my feeling also on Mach V springs.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 04-10-2015, 09:24 AM   #44
Nissota
Nissota's Avatar
Drives: Subaru BRZ, Nissan 240sx
Thanks for the thread!
Nissota
2013 Subaru BRZ DD
1997 Toyota Supra MKIV
1990 Nissan 240sx
www.revvolution.com
Nissota is offline   Reply With Quote
The Following User Says Thank You to Nissota For This Useful Post:
Racecomp Engineering (04-16-2015)
Old 04-16-2015, 11:01 AM   #45
Originally Posted by joez28ls1 View Post
I'm curious if RCE has done any R&D on the 2015 FRS? Reports seem to point to the 2015 FRS as having revised springs & dampers. I had a 2013 and moved to a 2015 and am quite happy with how the 2015 feels even compared to the 2013. I want to lower my 2015 but it would suck to change negatively in anyway how it handles...because it's amazing!
Same springs as before, shocks are slightly different. Not a very large change.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
chaoskaze (04-30-2015)
Old 06-13-2015, 12:49 AM   #46
Maxwell
Maxwell's Avatar
Drives: 2015 Subaru BRZ Limited 6MT
Question
- Andy
Is this the same case with the 2015 BRZ?
Maxwell is offline   Reply With Quote
Old 06-13-2015, 09:46 AM   #47
Yes.
Old 09-17-2015, 10:18 AM   #48
KidRed
Drives: 2015 FRS
So if I just want to lower my car around an inch, as I love the driving dynamics, would the RS-R S/Down do me well? Or would I also need to upgrade other areas of the suspension as well like sways, LCAs, ert?
KidRed is offline   Reply With Quote
Old 09-18-2015, 12:50 AM   #49
Mikepage
Mikepage's Avatar
Only a good set of springs and an good alignment will be fine to start.
No need LCA for around one inch, I don't have LCA and am dropper 1" 3/8...
Of course adjustable LCA are better, but this is to fine tune your alignment.
You can run only lowers springs without any problems don't worry...and if you want, in the near future you have always the time to upstage others suspensions depend on what you will need concerning the handling of this car.
o= FR-S =o
The Following User Says Thank You to Mikepage For This Useful Post:
KidRed (09-21-2015)
Old 09-21-2015, 10:44 AM   #50
KidRed
Drives: 2015 FRS
^ Cool thanks. I've had coilovers before, but not sure if I want/need them if I really have no current plans on dropping below 1 1/2".
Old 10-30-2015, 12:02 PM   #51
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I've been reading up on dampers lately (and have a crapload more reading up to do still) but I wanted to post up some good links/info here in one place. Feel free to add to this list, or if there's something that contains bad info, let me know (prove it though!) and I'll remove it. Some of these links (most maybe?) have already been posted on here but they are all over the place..
List:
Far North Racing - Shock Buyers Guide
Far North Racing has other good info on their site also.
So which vendors here will provide dyno plots for individual shocks...?
Also thanks for the list, some great reading!
GeorgeJFrick is offline   Reply With Quote
Old 10-30-2015, 05:14 PM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Vendors? Probably few. Some manufacturers will.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-15-2018, 11:04 PM   #53
notout86
Drives: GTS 86 auto
I love our 2013 GTS86 auto but at 70+ years of age the wife in particular hates the hard ride. Can anyone advise on modification to make it like (for instance) a Golf GTI which seems about the right amount of suppleness for our taste please.
I am thinking trying different springs first then dampers but have no idea about rates.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 04-16-2018, 10:59 AM   #54
A set of new or lightly used 2017 or 2018 BRZ standard shocks would be my recommendation.
Bilstein B6 will ride well too, but a little more "sport" in comparison.
If ride quality is your main goal, I would stick with OEM springs.
BUT the new version of the Ohlins coilovers would also work well, at quite a bit more cost.
- Andrew
notout86 (04-17-2018)
Old 04-16-2018, 02:03 PM   #55
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
I'm also in the 70+ age range. Believe it or not, sticking with the non-PP wheels, tires, suspension AND using a good gel pillow for my wife (who weighs less than 100 lbs), works best. It turns out that the thin padding on the seats transfers the jarring and when that is subdued, the ride seems a lot smoother. I'm thinking about having extra padding put in the bottom of the seat. We actually have a similar problem in our SUV, believe it or not, and she uses the cushion there as well.
rvoll is offline   Reply With Quote
The Following User Says Thank You to rvoll For This Useful Post:
Old 04-17-2018, 01:39 AM   #56
notout86
Drives: GTS 86 auto
Thanks & a simple enough solution to try. She would like to sit higher too.
MotoIQ: Tech Look at FR-S Underside - Suspension, Chassis, Brakes, Differential oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 93 09-22-2017 10:47 AM
Is anyone going to motion car show? Pekingduck Southern California 15 05-20-2012 11:46 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 02:30 PM
TRD 86 MSB (Motor Sports Basic) Race Packages Announced switchlanez Scion FR-S / Toyota 86 GT86 General Forum 49 03-27-2012 08:31 AM
Crazy idea... the Rear Seat info ? MRZ415 Scion FR-S / Toyota 86 GT86 General Forum 78 01-27-2012 12:19 PM
