Old 11-15-2011, 11:17 AM   #547
Longhorn248
Hook 'em
Longhorn248's Avatar
Originally Posted by tripjammer View Post
2013 genesis 2.0t is now 271hp and 275 ft/lbs torque. If they can keep the weight at 3294 pounds, that's a power to weight ratio of 12.15 to 1. And it has a 8 speed automatic or 6 speed manual.
The reason why I bring it up is because the price is supposedly gonna be the same...$22k base.
Even though there is no real completion to the ft86, the genesis coupe 2.0t is the closest.
There is no way they are going to price the FRS/BRZ at $28k. I have always said $24k for the high-spec trim 6 speed manual, I am going to stick with that.
And a fully loaded BRZ 6 speed manual will be cheaper than a base WRX.
I am hoping the real engine specs are 220hp and 170 ft/lbs torque
Maybe they'll drop the bomb at TMS and give up a number around 215-220hp for the FR-S rather than all the rumored 197-200hp numbers popping up in magazines.
I'm not real familiar with Toyota when it comes to new cars, have they under-rated HP in the past? Perhaps the specs will list 200hp but once someone gets it on a dyno we'll be pleasantly surprised with a HP bump?
Longhorn248 is offline   Reply With Quote
Old 11-15-2011, 02:28 PM   #548
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
200/170 is possible based on D4-S and friction reduction gains on the auto-tuned 3S BEAMS motor.
The GT5 220/170 numbers are possible with those gains applied to the more aggressively tuned manual 3S BEAMS motor. Possibly the STI or 'R' version will have numbers like GT5.
Just wait and watch.
It's also entirely possible (and likely) that the established numbers are correct.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-15-2011, 03:25 PM   #549
Dimman
Kuruma Otaku
Dimman's Avatar
No. Peak torque is tuned for 6600 and just drops like crazy? I don't buy it.
This thing has more compression, likely better combustion, and likely less friction than an F20C which still manages an 800 rpm spread. At the rpms they both run for their peaks the friction is going to be way less on the FA20. That and the fact that a 2GRFSE can push a BMEP 196 psi makes the 151 lb-ft just not make sense.
151 peak @ 6600 is terrible when paired with the 197 bhp @ 7000.
Because titanium.
Old 11-15-2011, 03:26 PM   #550
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
HIDS head lights now standard across the entire 2013 mustang lineup, including the V6!
http://www.autoblog.com/2011/11/15/2...aging-updates/
Ford even offers HID fog lights as a option...I never heard of HID fog lights...
So this makes it even a better chance that the HIDs will be standard in the Scion version of the FRS...ie High Spec based...but it depends on how they price the vehicle...
tripjammer is offline   Reply With Quote
Old 11-15-2011, 03:28 PM   #551
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The torque doesn't drop that much until past redline.
I just don't think they are printing fake materials to leak just to say at TMS "HAHA We fooled you!".
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-15-2011, 03:31 PM   #552
Longhorn248
Hook 'em
Maybe they're under promising with the leaks in order to really floor everyone when they do the official release in two weeks?
Old 11-15-2011, 03:34 PM   #553
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Are we really going to be floored by 19 more ftlbs? Sure, I wouldn't mind it, but I'm fine with 151 too.. that's still more than my current cars have (stock) :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-15-2011, 05:24 PM   #554
tripjammer
tripjammer's Avatar
170 still better and will make a difference but until we drive it we won't know.
Old 11-15-2011, 05:53 PM   #555
Allch Chcar
Drives: N/A
200PS(HP) is set in stone now. So no.
If it's not underrated it might be de-tuned. Remember Toyota is really pushing MPG and emissions marketing. The test drives were done on LRR eco tires.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-15-2011, 06:13 PM   #556
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It's possible they leaned the fuel way out, retarded timing and added a bunch of EGR... Hey, I can dream can't I?
old greg is offline   Reply With Quote
Old 11-15-2011, 06:58 PM   #557
Allch Chcar
Drives: N/A
More like pigrich under load, retarded(the correct usage) timing at low RPM, EGR, PCV, and 3 catalytic converters with one mounted just off the exhaust manifold.
So yeah, 100% possible.
-Allch Chcar
Old 11-15-2011, 07:06 PM   #558
serialk11r
Drives: '06 AM V8V Coupe
pigrich under load? How they gonna pass emissions :confused: If emissions standards are getting stricter...they have to be going more lean right?
Old 11-15-2011, 07:30 PM   #559
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That's what I'm talking about. If they're looking for low fuel consumption and low emissions, they would lean the mix out (more MPG, more NOx, less CO2) and use a bunch of EGR (less NOx).
Old 11-15-2011, 07:32 PM   #560
Allch Chcar
Drives: N/A
They run Stoich, which gives a cleaner burn, at lower loads and go rich under moderate-heavy loads. It varies.
Go read a guide to OBDII ECUs and current emission systems.
Edit: Lean burn would only be done under light loads like cruising. And it would require a separate NoX cat and only for limited amounts of time. The US has very strict NoX emission regulations.
-Allch Chcar
Last edited by Allch Chcar; 11-15-2011 at 07:37 PM. Reason: couldn't get my thoughts straight.
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 02:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 06:35 PM
