Old 05-10-2020, 06:53 PM   #589
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Originally Posted by gpvecchi View Post
How to run the flexible hose in this case? Going down to the heater pipe is quite straight, if I understand, this should run around the engine to its back...
It should run across the top of the engine and connect just under the intake manifold.
Thanks again Nikitopo. Probably won't run it that way but it's a comfort that someone else thought of it.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
nikitopo (05-11-2020)
Old 05-11-2020, 03:18 AM   #590
gpvecchi
gpvecchi's Avatar
I find It to be more clean with the heater pipe, as the cooler pipe is oriented to the fender. You should run between the injectors cover and fender and then back under the manifolds with the AT way.
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
Capt Spaulding (05-11-2020)
Old 05-17-2020, 05:41 AM   #591
Mattia M.
Mattia M.'s Avatar
Drives: BRZ my18
Hi guys,
i read in this post https://www.ft86club.com/forums/show...&postcount=228 and this https://www.ft86club.com/forums/show...&postcount=229 that this 2 codes 14050AA970 and 14050AB090 are the same. Could you confirm?
Thank you.
Mattia M. is offline   Reply With Quote
Old 06-13-2021, 01:51 AM   #592
AnthonyBRZAus
Drives: 2014 BRZ
Originally Posted by CARNZ View Post
Done, uploaded all of the pics to TinyPic and edited my post to link to those photos now, shouldn't have anymore issues.
Any chance someone downloaded these pics, and can re-post them?
The OP posted them to TinyPic... but the website has been taken down now
thanks in advance
AnthonyBRZAus is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) -- General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) -- General Topics 12 02-01-2013 12:29 PM
