08-20-2016, 11:37 AM | #659 |
If they do a visual & are aware our car has TWO cats you may fail. Yet, I believe most places are not aware we have TWO cats.
So, don't take it to the dealership. Find some other place. Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
08-20-2016, 11:41 AM | #660 | |
Drives: 15' Limited BRZ
Nah the guy is my friend (local mom and pop) but in NY you can't scam the system because its OBD2 and if it says not ready you can't pass. He doesn't personally care, I would just use someone elses car for a sticker but NY checks inspection to renew the registration. |
The Following User Says Thank You to mulekr1 For This Useful Post: | alxtheoreo (08-20-2016) |
08-20-2016, 05:16 PM | #661 | |
The Following User Says Thank You to steve99 For This Useful Post: | Skyllz (08-20-2016) |
08-20-2016, 05:23 PM | #662 | |
Mate im not accross all the different inspections in usa. But yes if they want ALl readyness checks to pass that wont happen if you have disabled the cel code. I beloeve some places allow one check to say not ready or fail. so yes theoreticly to pass with all readyness showing pass you going to need to put stock header back and stock tune or at least a tune with P0420 not disabled, then drive it till readyness checks complete. If you can get away with jist one cat on visual, you might be able to reenable the P0420 code in your catless header tune then install an 02 spacer in REAR O2 sensor bung then drive till readyness goes good, and hopefully cel wont trip, spacers can be a bit hit and miss with cel code, if no cel you likely get readness to pass and hence be able to pass inspection. |
08-20-2016, 05:33 PM | #663 | |
You might be able to enable P0420 in your catless header tune and add 02spacer to rear 02 sensor, if your lucky you wont get cel and readyness will pass after 50 miles or so. |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | everythingsablur (08-22-2016), Teseo (08-20-2016) |
08-22-2016, 10:39 AM | #664 |
Drives: 15 BRZ LTD, 05 FXT
@steve99 Quick question! I am currently running the stage 2 EL tune and have been thinking about adding a Wideband O2 sensor to run an AFR gauge. Does the Stage 2 EL tune make use of the rearmost O2 sensor? Can I simply remove it from the header, unplug it from the harness, and pop the aftermarket wideband sensor in without fear of a code or issue from the Stage 2 tune?
Thanks!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
08-22-2016, 12:26 PM | #665 | |
The Stig's German cousin
The Following User Says Thank You to renfield90 For This Useful Post: | alxtheoreo (08-22-2016) |
08-22-2016, 05:35 PM | #666 | |
you can also rescale the stock front o2 sensor to read quite well down to 10 afr. if you remove the stock rear o2 sensor your goung to also need to disable the rear 02 sensor trims AF#3 and disable some more cel codes for rear 02 heater and some other i carnt remember. |
The Following User Says Thank You to steve99 For This Useful Post: | Teseo (08-22-2016) |
08-22-2016, 05:46 PM | #667 | |
its possible if the ecu sees data from the two 02 sensors that is close enough to the stock readings it expects. its more dependant on the header than the tune, it depends on the placement of the 02 sensors, some headers the rear o2 is placed in a bung that has a built in spacer almost similar to the openflah header, generally if the data is out enough to throw a P0420 cel then it wont pass readyness, so regardless of wether you have disabled cel you wont pass readyness as the data is outside what the ecu expects. yes they check several other systems as well |
08-23-2016, 09:16 AM | #668 | |
I'm a firm believer in using an aftermarket wideband, can that feed inputs into the ECU and help, as well as power a gauge or is that more trouble than it's worth, and easier to just weld a bung into the header? Thanks!
08-23-2016, 12:55 PM | #669 |
Drives: White frs
My oft is not connecting to the open flash manager, what should i do?
08-23-2016, 07:16 PM | #670 | |
in order to send additional inputs to ecu your going to need to write actual ecu program code or buy ecutek system. yes it will be far easier to just weld in extra bung and not have to fiddle with didabling rear sensor. |
The Following User Says Thank You to steve99 For This Useful Post: | JazzleSAURUS (08-24-2016) |
08-23-2016, 07:27 PM | #671 |
Drives: frs
Flashed the car with oft with stage 2 uel 91 oct but oft did not came with 93 uel tune, need to download via open flash manager?
08-23-2016, 07:37 PM | #672 | |
The Following User Says Thank You to alxtheoreo For This Useful Post: | Teseo (08-23-2016) |
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
