12-27-2018, 01:09 PM | #57 | |
Drives: 13 FRS Firestorm
Sent from my SM-G9600 using Tapatalk |
12-28-2018, 12:37 AM | #58 |
Drives: Asphalt FRS <3
Subd
I will be going this route with a buddy of mine who tunes Honda's here in Montreal.
12-28-2018, 05:00 PM | #59 |
Drives: 2013 FRS Whiteout
These are truly art!
Kheaderfinal by Brady Johnson, on Flickr Pre Order is up : https://www.pureautomotiveperformanc...-frs-brz-gt86/ |
The Following 7 Users Say Thank You to Pure Automotive For This Useful Post: | BatStig (12-31-2018), Draco_PR23 (01-08-2019), gtengr (12-28-2018), Irace86.2.0 (12-28-2018), Kodename47 (12-28-2018), surfwaxsmitty (01-02-2019), venturaII (12-30-2018) |
12-28-2018, 05:02 PM | #60 |
Here's a quick video showing out it mates up to FACTORY catback position!
https://www.facebook.com/SwapYour86/...63321160903109 |
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post: |
12-28-2018, 06:46 PM | #61 | |
Drives: Q5 + BRZ + M796
It would seem that a smaller displacement motor would naturally rev higher, so a smaller displacement head on a larger block would help that motor rev higher, but isn't it more about the block that will determine max rpms in this case and not the head? Shouldn't the larger stroke (higher piston speeds) determine the limit? If not, what is special about the K20A head? I'm a novice with understanding bench flowing heads or understanding fluid dynamics, but it seems that a head built for a smaller displacement motor would be restrictive at the top end if it was matted to a larger motor, even if it was designed to handle higher revs. If anything, a restricted/smaller head would make for more low end torque than allowing high flow for peak horsepower. Am I completely off? Does the smaller head actually have better flow? If I remember correctly (it has been a while since I owned a MKIV Supra), the NA head flowed better than the TT head, but that may have been intentional to get the turbos spooling or something. Nevertheless, it demonstrates that a small head can outflow one for a larger or more powerful engine.
12-28-2018, 08:27 PM | #62 |
Drives: 2017 BRZ
12-31-2018, 04:12 AM | #63 | |
building life
Drives: Raven Black, 6MT
Will you make a adapter for a intake manifold, or are you planning to run it with the F20 intake manifold,tb, etc ? For everyone who is interested in this, A adapter plate for the trans/motor will be needed (adapter plate link) http://www.balladesports.com (they also have the flywheel for sale) F2K clutch master flywheel (flywheel link) http://www.clutchmasters.com/aluminu...eel-fw-k2f-al/ Also if you take a look at the Upper Radiator hose it will have very minimal room as its close to the firewall..will there be a fix for that ? maybe CNC a plate along with either AN fitting, or 90* welded on. CORRECT me if im wrong on any of this information above but overall still should be a fairly easy swap if you have fabrication skills. Look forward to seeing a PNP for this. |
12-31-2018, 05:43 AM | #64 | |
Drives: BRZ, WRX
https://kmiata.com/collections/plumb...r-coolant-neck
The Following 2 Users Say Thank You to DIY For This Useful Post: | PolishFrs13 (12-31-2018), Pure Automotive (12-31-2018) |
12-31-2018, 06:43 AM | #65 | |
building life
thanks, that might actually be perfect |
12-31-2018, 08:52 AM | #66 |
We looked at a lot of FWD dyno graphs when trying to design it. So kind of yes to both, yes it is a swap header but yes we did try to optimize it both in runner size and length. It's big enough to flow some bigger HP (300+) and the runners should be conducive to higher RPM flow. But to be 100% honest, as we have not actually put one together yet, it is a best guess until we test.
The Following User Says Thank You to Pure Automotive For This Useful Post: | gtengr (12-31-2018) |
12-31-2018, 09:52 PM | #67 | |
building life
will there be a FI setup soon ? |
01-01-2019, 08:53 AM | #68 |
K-swapped and BOOSTED FRS with S2000 cluster. Looks sick.
He starts talking about the swap here: Says he uses an AEM infinity ECU. No A/C, but has traction control. He doesn't mention ABS; I'm assuming it doesn't work. I also don't know if that's an AP1/AP2 cluster. AP2 clusters switched to CAN in 06. Last edited by BertoFT; 01-01-2019 at 09:23 AM. Reason: More youtube links |
The Following User Says Thank You to BertoFT For This Useful Post: | PolishFrs13 (01-01-2019) |
01-01-2019, 03:13 PM | #69 | |
01-01-2019, 10:59 PM | #70 | |
building life
something ill have to take a look at when im off work.. does he have a build thread on here ? |
Similar Threads | ||||
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! | Pure Automotive | Engine Swaps | 29 | 01-10-2018 01:20 AM |
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:57 AM |
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:49 AM |
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:23 AM |
Pure Auto's 2JZ Swap Thread - The DRAGFRS | Pure Automotive | Engine Swaps | 153 | 06-20-2016 06:33 PM |
