Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-06-2020, 07:56 PM | #57 |
Drives: 2015 Firestorm Scion FRS
For anyone who has never been on coilovers before as a daily driver, I don't think the majority really have a baseline on what rides 'comfortably' or 'good' on the streets. It's also really subjective as to what every individual tolerates as 'harsh' or 'comfy' depending on public road conditions. Also, if I'm in a good/relaxed mood, a semi-shitty road say on lowering springs/stock struts won't bother me at all compared to me in bad/stressed/aggravated mood where even bump will make me curse and yell like a raging Jeremy Clarkson in a Grand Tour special.
As an average enthusiast who rarely tracks my FRS, I would rather suggest something a bit above entry entry level to mid-range if you're on a budget just to experience and feel it out first and tinker with the suspension to your hearts content to learn about dampening, rebound, preload, etc. What may 'suck' or is 'harsh' for people with $1500+ coils may be tolerable for folks who never had any experience with coils if they decide to buy an 'average' set. The exception is if budget isn't a problem then by all means, go for $2k+ sets for the ultimate performance and comfort! Not sure if folks are willing to rebuild their coilovers after 2+ years too once it exceeds its shelf life. By then, if you still have the FRS, you can upgrade to higher end ones if you choose to. Or you may even get a new car by then..who knows? Just my two cents. |
The Following User Says Thank You to G-awesome For This Useful Post: | MasterBandit (01-10-2020) |
01-06-2020, 09:14 PM | #58 | ||
Drives: FR-S Whiteout
But yes.. if a a shock is built using different internals, better QC and better R&D built by better trained people in an entirely different location using different machines to test and assemble them... is it still a BC shock? Yes.. but not really. lol If fitment and reliability is no longer a variable, then it's all in the valving. Edit: how much are flex z selling for? you can buy a set to install and another set for back up with $1500 budget. Flex-A fits in the sub $1500 as well and "slam-able". Not for the 86, but Meisters with their new piston I've demoed a set of their current ND valving which was damn near perfect on RSRR tires comfort and performance. Meister's 86 versions should be more than decent for about $1500. the ST's I've tried can ride pretty well with a pretty broad range of adjustment retailing about $1500. Pretty good choices with that budget.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 01-06-2020 at 10:03 PM. |
01-10-2020, 07:33 PM | #59 |
Drives: DGM BRZ MT
man this thread is a shitshow. OP just asked for coilover suggestions for 1) comfort and 2) a tad low.
the first reply recommends a complete drop on BC coils. that's the exact opposite of what OP wants. and then further talks about fuel starvation when tracking the car? and now everyone is arguing about BC coils and fuel starvation and tracking. The OP wants COMFORT and a TAD LOW. IMO he doesn't need 1500 coils... heck just a Tein Basis Z will do the job. |
The Following User Says Thank You to cywinr For This Useful Post: | G-awesome (01-11-2020) |
01-10-2020, 09:05 PM | #60 | |
Weight Weenie
Drives: 15 FR-S
Or spend $150 and get a similar result. https://www.ft86club.com/forums/showthread.php?t=138523 |
01-10-2020, 11:16 PM | #61 |
Drives: 2019 BMW ///M4
Tein Flex A or Tein Flex Z. Both are great options around $1000. Height Adjustable as well.
Tein Flex A is more comfortable as it has a Hydraulic Bump Stop -- Can take bumps better.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
01-11-2020, 02:09 PM | #62 | |
One could spend over $3-4K on some shiny CNC machined bling and still be unhappy with the performance, and is actually rather common. Conversely you can have an cheap set of dampers, rebuild/valve them and have them perform better than anything available OTS. It's all in the valving.
Intent > Content
cowardice is the mother of cruelty. |
01-11-2020, 02:54 PM | #63 |
Drives: Crapcan
The ST’s are well within the OP’s price range. KW built, and much more street oriented then the Tein’s. I have Flex Z’s on my car now. I’ve run them everywhere from fully slammed to almost as high as they will go. They are a bit rough still on the street even raised up. Base spring rate is 6kg. Can’t wait to get them off the car and get my T2’s on.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Griever423 (01-16-2020) |
01-12-2020, 03:34 PM | #64 |
Drives: 2015 FRS
New to the thread, but with the last few posts, thought I'd post my opinion. I recently installed the Koni sport yellows on my car, with a coil-over modification to the strut tubes, and applied 225 lb/in 8" front, 250 lb/in 7" rear (~ 4kg and 4.5kg). With the Koni adjusted to 60% stiffness (single adjustable), and lowered about 1" front, 3/4" rear, I have finally found a stiffness and balance for the car (a daily driver) that is a significant improvement over OEM, without being too rigid. I did some other things to ensure I had equal to, or better than OEM shock compression travel with the lowering (which all but eliminated the obvious and frequent bump-stop issue on a lowered FRS/BRZ).
Total cost was very close to $1500, which includes the Koni dampers, Ground Control coilover kit, Ground Control camber plates, camber bolts, and various other small things that enhanced the final setup. I went this route only because cost was reasonable, and Koni is a reputable name that I've used for decades on other cars. I'm saddened by what appears to be Koni's termination in producing the yellow inserts, and relying solely on the full strut replacements. What this means is the loss of a middle-spectrum modification that allows a lot of flexibility and quality for the DIYer, at lower costs. Last edited by blueovalz; 01-12-2020 at 03:59 PM. |
The Following 2 Users Say Thank You to blueovalz For This Useful Post: | NoHaveMSG (01-12-2020), strat61caster (01-12-2020) |
01-13-2020, 05:37 PM | #65 | |
Drives: DGM BRZ MT
Tags |
brz, coilovers, comfort |
Similar Threads | ||||
What coilovers should I purchase? | 403 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 71 | 05-20-2017 03:09 AM |
Ohlins Coilovers - $1500 Shipped | Bobby@Forged | Brakes, Suspension, Chassis | 1 | 09-28-2016 05:38 PM |
isc n1 coilovers and 19x9.5 rays 57extremes 1500 miles mint | kingkai23 | NY / NJ / CT / PA | 1 | 08-10-2014 11:11 AM |
Eibach Multi PRO R2 Coilovers: $1500 | FRSdrive | Brakes, Suspension, Chassis | 11 | 02-24-2014 07:00 PM |
$1500 budget coilover - what would you choose? | smbstyle | Tracking / Autocross / HPDE / Drifting | 27 | 11-17-2013 09:35 PM |
